You can try stand pipe in place of vacuum breaker or combination of both if your system permits. In one sense stand pipes are more reliable since vacuum breaker valves may malfunction. I do not know how pump trip time can affect the solution, because surge phenomenon happens after the pump is tripped from steady state running. However more inertia for pump and motor by adding flywheel can give you some good result to reduce vacuum.
