Results 1 to 12 of 12
Thread: COMSOL a Tool for Engineering
    Re: COMSOL a Tool for Engineering
    he COMSOL Multiphysics simulation software environment facilitates all steps in the modeling process − defining your geometry, meshing, specifying your physics, solving, and then visualizing your results. Model set-up is quick, thanks to a number of predefined physics interfaces for applications ranging from fluid flow and heat transfer to structural mechanics and electromagnetic analyses. Material properties, source terms and boundary conditions can all be arbitrary functions of the dependent variables. Predefined multiphysics-application templates solve many common problem types. You also have the option of choosing different physics and defining the interdependencies yourself. Or you can specify your own partial differential equations (PDEs) and link them with other equations and physics.
    COMSOL 4.2 Release Highlights
    COMSOL Multiphysics 4.2 represents a significant expansion of the software’s applications, features, and functionality. Version 4.2 empowers current users to do more with their simulation environments, while new industries will now be able to leverage the innovation of multiphysics simulation. With this release, COMSOL continues to deliver on its promise to supply the science and engineering markets with the state-of-the-art simulation products for an expanding set of applications.
    Microfluidics Module brings easy-to-use tools for the study of microfluidic devices and rarefied gas flows.
    Geomechanics Module enables multiphysics modeling in geotechnical applications such as tunnels.
    Electrodeposition Module brings the power of COMSOL to electrochemical processes for chrome plating.
    LiveLink for AutoCAD makes COMSOL Multiphysics simulations in 3D available for AutoCAD users.
    LiveLink for SpaceClaim brings the fusion of direct modeling and multiphysics simulation in a tightly integrated environment.
    One Window Interface for the LiveLink for SolidWorks allows SolidWorks user to stay inside of the SolidWorks environment and work synchronously with COMSOL Multiphysics.
    Fast multiphysics assembly brings faster and more memory efficient computations on virtually any type of computer platform, from laptop to cluster.
    Report Generator creates HTML reports for models of varying degrees of detail, from brief to complete.
    Compressible High-Mach Number Flow for designing nozzles, pipe networks, and valves, and for modeling aerodynamic phenomena.
    Virtual Geometry tools allow for modification of CAD models without changing the underlying surface curvature and enable very efficient meshing.
    Time-dependent adaptive meshing automatically resolves sharp diffusion fronts in two-phase flow simulations, bringing faster and more accurate simulations.
    For additional materials in COMSOL
    Link:
    Contain:
    Models
    0128 Induced Eddy Currents in a Cylinder Surrounded by a Coil
    0131 Forces on Parallel Current-Carrying Wires
    0213 One-Sided Magnet
    0492 Thin-Layer Diffusion
    1840 Joule Heating in a MEMS Device
    0328 Fuel Cell Stack
    8550 Mass Transport Analysis of a High Temperature PEM Fuel Cell
    0690 MOS Transistor Model
    8640 DC Glow Discharge
    8658 Thermal Plasma
    8661 3D Model of an ICP Reactor with Argon Chemistry
    8649 GEC ICP Reactor. Argon Chemistry
    0197 Magnetic Drug Targeting
    0483 Biot Poroelasticity
    0989 Stresses in the Soil Surrounding a Traffic Tunnel
    2199 Sheet Metal Forming by a Spherical Punch
    2203 Flexible and Smooth Strip Footing on a Stratum of ClayFlexible and Smooth Strip Footing on a Stratum of Clay
    4485 Viscoelastic Structural Damper
    0126 Cold Crucible
    0249 Boat Reactor for Low Pressure Chemical Vapor Deposition
    0945 Chemical Vapor Deposition of GaAs
    2139 The Two-Term Boltzmann Equation
    9663 Surface Chemistry Tutorial
    0472 Perforated Well
    0499 Two-Phase Flow in Porous Media
    0666 Open-Hole Multilateral Well
    0723 Conical Quantum Dot
    0616 Swirl Flow Around a Rotating Disk
    1445 Inkjet Nozzle Level Set
    2152 Modeling Nonisothermal Flow with Gravity Volume Forces
    4398 Turbulent Two-Phase Flow Benchmark
    0110 Marangoni Convection
    0382 Continuous Casting
    0105 A Magnetic Brake Modeled in 2D
    0106 Thermal Controller, Simulink Simulation
    0186 Critical Frequencies for a Rotor
    0976 Forced Turbulent Convection Cooling of a Hot Plate
    10569 Assembly with a Hinge
    0144 Photonic Micro Prism
    4473 Waveguide Optimization
    6141 RF Introductory Tutorial. Step by Step Modeling of a Periodic Structure
    8610 Periodic Boundary Condition
    10032 Plasmonic Wire Grating
    0190 Stress-Optical Effects - with Generalized Plane Strain and in a Photonic Waveguide
    9702 Triaxial Test
    9747 Deep Excavation
    0881 Electromagnetic coils. Multi-turn without skin effect
    0916 Electromagnetic coils. Multi-turn with fixed total current and skin effect
    0951 How do I calculate the capacitance matrix of a multiconductor system
    0953 Error message. Singular Matrix
    10407 Transonic Flow in a Sajben Diffuser
    8625 Oxygen Boltzmann Analysis
    0140 Waveguide Adapter
    0143 Photonic Crystal
    0145 Step Index Fiber
    1863 Coaxial to Waveguide Coupling
    2190 Absorbed Radiation (SAR) in the Human Brain
    2192 Microstrip on a Printed Circuit Board
    8559 Laminar Flow in a Baffled Stirred Mixer
    3459 Mie Scattering off Plasmonic Nanoparticle and Radar Cross-Section Computations
    0933 Troubleshooting graphics adapter problems
    0952 Avoiding negative concentrations
    0970 Deformed meshes tips for success
    1036 Error 9040 Type NullPointerException
    1052 Troubleshooting MATLAB interface problems
    1056 Warning New constraint force nodes detected
    1064 Missing or incomplete model documentation
    1068 I cannot start COMSOL 4
    1069 Unexpected error when opening a model file
    1070 Failed to load library
    1071 Cannot start COMSOL 40 with MATLAB on Windows
    1073 Evaluation of particle tracing failed
    1077 COMSOL Installation Companion
    1082 Error message File could not be opened while importing a CATIA V5 file
    1084 Error message Assertion failure
    1085 Error message File contains no model
    1086 Installing COMSOL 4 on Linux
    1111 Updating the COMSOL model library
    0122 Heat Transfer by Free Convection
    1448 Natural Convection Cooling of a Thermos
    4434 Cooling of a Circuit Board through Forced Convection
    0195 Free Convection in a Water Glass
    0955 Propagation of a 3D Gaussian Beam Laser Pulse
    0956 Second Harmonic Generation of a Gaussian Beam
    0078 The Magnetic Field from a Permanent Magnet
    0124 Induction Currents from Circular Coils
    0148 Inductive Heating of Copper Cylinder
    0171 Non-Newtonian Flow
    0207 Thermally Induced Creep Analysis
    0212 Inductance and Resistance
    0970 Induced Eddy Currents in a Metal Plate
    0990 Inductor in an Amplifier Circuit
    0198 Liquid Chromatography
    0657 Buoyant Darcy Flow The Elder Problem
    0972 RF-Heated Hot Wall Furnace for Semiconductor Processing
    Comsol Knowledgebase
    0973 My flux calculation seems wrong
    1010 Error. System matrix is zero
    1018 Error. UnsatisfiedLinkError. Cannot handle TLS data
    1022 Updating the COMSOL License Manager
    1025 Level Set method for two-phase flow and how does it compare with the Volume of Fluid (VOF) method
    1031 Flux through interior boundaries
    1033 Error. 2058 Failed to connect to SolidWorks
    1035 Rubber band selection displays gray box in Windows Vista
    1037 Error. Timeout waiting for client
    1042 Tips and Tricks, COMSOL News 2009
    1044 Issue with the CAD Import ----- installation
    1045 Error. 9040 ClassCastException
    1055 MATLAB 2009b interface problems
    1057 Error. LMCOMSOL exited with status 0 signal = 17
    1058 Combining network license files (license.dat)
    1059 Error. Licensed number of users already reached
    1060 Error. 9160 Property. linemethod
    1078 Problems running a classkit license (CKL)
    1079 Error. An error occurred while automatically activating bundle
    1094 GLIBCXX_3.4.9 not found error message when calling an external MATLAB function
    1098 Uploading files to the COMSOL ftp site
    1106 Installer halts before finished when using the automated (silent) installation option
    1114 Command-line switches to the COMSOL command
    1115 Oblique incidence with Floquet boundary conditions
    1116 Selecting hardware for clusters
    1118 Resolving time-dependent waves
    1119 Missing Material Library for Batteries and Fuel Cells module
    1120 Problems on Mac OS X 10.7 Lion
    1121 Error. Failed to connect to Inventor
    1122 Error. Failed to connect to SolidWorks
    1123 Error. Failed to connect to AutoCAD
    1125 Error. Vendorstring is not correct
    1126 Error. Error contacting the update server
    1128 Thermoacoustics interface yields unexpected results
    1129 Transparency does not work
    1130 Model Library Update for Linux NSL users
    1132 I cannot change language when using a trial license
    1030 Error. Out of memory
    1127 Improving convergence in nonlinear time dependent models
    0878 Should I use the RMS, the peak, or the instantaneous value to specify sources for electromagnetic fields
    0895 Can COMSOL Multiphysics handle left-handed materials
    0902 Thin film approximation, contact resistance
    0903 Could not obtain license for COMSOL Multiphysics GUI
    0905 Smoothed step transitions in COMSOL Multiphysics
    0909 Can COMSOL Multiphysics be used for TEM mode analysis
    0923 Installation of COMSOL Multiphysics with hardware lock (dongle)
    0935 Data import
    0939 Can COMSOL Multiphysics handle polar, spherical, and cylindrical coordinates. And how is this done
    0947 License manager error. TCP port number
    0955 Optimization
    0964 Error message. Failed to find a solution. No convergence
    0966 Background and Theory References on Equation-Based Finite Element Analysis Used in COMSOL Multiphysics
    0968 Error message. FLEXnet Licensing error-103
    0980 How can I run COMSOL Multiphysics computations in batch mode
    0982 Axisymmetric plot swept to 3D
    0986 Error messages, general
    0987 MATLAB compatibility
    1001 Running COMSOL in parallel on clusters
    0913 Computing Time and Space Integrals
    0103 Convergence problems at high reaction rates (large source terms)
    0107 Command line associative geometry
    0114 Plot of contour lines on different surface plots in 2D and 3D
    0120 Meshing a thin geometry.pdf
    0125 Integration over arbitrary cross section
    0768 3D slice plot of arbitrary shape
    0786 Where can I purchase COMSOL Multiphysics
    0816 How do I solve a PDE with space derivatives of order higher than two
    0828 Obtaining a Hostid for licensing.pdf" "0830 Handling memory intensive models
    0838 Can COMSOL Multiphysics import images
    0850 Is there an open-boundary condition for electrostatic or magnetostatic simulations
    0866 What hardware platform do you recommend for COMSOL Multiphysics
    0875 What does degrees of freedom (DOFs) mean in COMSOL Multiphysics
    0983 Error message Internal Error in Geometry Decomposition in 3_5a
    1038 Using symmetries in COMSOL Multiphysics
    1039 A declared function in COMSOL Multiphysics model seems to give wrong answer
    1043 Equilibrium reactions in Reaction Engineering Lab
    1048 Error 9040 Type IllegalArgumentException
    1050 Error 2058 Failed to connect to Inventor
    1051 Incident field with arbitrary angle
    1053 Error 9040 Fatal Error NoClassDefFounderror
    1062 BDF vs Generalized Alpha time discretization
    1074 Error 1095 Failed to load model
    1080 Backward compatibility of COMSOL 4_1
    1083 Error message An error has occurred. See the log file C_Users
    1087 Failed to create animation
    1089 Error Internal error in geometry decomposition
    1091 Error message No CAPE-OPEN property package
    1092 LiveLink for MATLAB I run out of memory or simulations take more and more time to run
    1093 MATLAB function calls fail after installing a new MATLAB version
    1095 Error Cannot open native file
    1096 COMSOL and multithreading
    1099 Manual handling of geometric entity numbers for selections
    1100 Transport of Concentrated Species a tutorial
    1101 Time derivatives in boundary conditions
    1102 Improve the stability of your contact model
    1103 Frequency-dependent meshing
    1104 Stabilization schemes in COMSOL
    1105 Difference between Solute Transport and Species Transport in Porous Media
    1108 Error message Expected End of Central Directory Record Signature
    1112 How to recover your work from an interrupted simulation
    1113 COMSOL does not start with the latest MATLAB version
    A lot of information that we can use with comsol, pack one:
    Here is pack two:
    Here is last pack upto now:
  8. Re: COMSOL a Tool for Engineering
    Hello aadamx
    your link is broken or expired.would you please upload it again.
    or even just upload this model "0499 Two-Phase Flow in Porous Media" or send it to my email:golestan1369@gmail.com
