Results 1 to 12 of 12
Thread: Dynsim login in problem
    Re: Dynsim login in problem
    Hello Sidineik
    Have you install Dynsim 4.2.4 (what is the version ?) in win 7 64 bits in your stand-alone PC disconnected of any network? What is a version of flexlm? 7.5, 9.5 or 11?
    I have problems to tune the server and service. How you make that. i appreciate your help.
    Do you know any cr------ for Dynsim 5.0 with flexlm 9.5?
  2. Re: Dynsim login in problem
    Hello folks,
    I have installed and run Dynsim 4.2.4 in 32 Windows XP SP3 successfully without any problems. I don't know if it would work with Windows 7.
    In fact most of the technical software would not work with Windows 7 or Vista. If you intend to use any such technical software, I would say have a dual boot system with XP SP3 and I see no reason why you should have problems installing it.
    ChemicalGeek
  1. PRO/II 9.1 & dynsim 5.0
    By engr.saleem in forum Oil And Gas Process
    Last Post: 07-12-2014, 08:11 PM
  2. GatorLink login help
    By hswang2 in forum General Engineering
    Last Post: 08-27-2011, 03:18 AM
