Thread: I need these papers urgently
    Re: I need these papers urgently
  2. Re: I need these papers urgently
    Quote Originally Posted by selmagis View Post
    thanks a lot for the link
    you should clear out your inbox because when I wanted to send you a personal message , I can't.
    Could you provide me with the rest of the papers
  4. Re: I need these papers urgently
    I need the following papers urgently please help:
    [1] S.G. Lapierre, N. Seiler, D. C-K Chen, "Mitigating Vibration in Bi-Center Drilling
    Programs", IADC/SPE 87097, 2004
    [2] G. Heisig, M. Neubert, "Lateral Drillstring Vibrations in Extended-Reach Wells"
    IADC/SPE 59235, 2000
    [3] D. C-K Chen, M. Smith, S.G. Lapierre, "Advanced Drillstring Dynamics System
    Integrates Real-Time Modeling and Measurement", SPE 81903, 2003
    [4] M.W. Dykstra, M. Neubert, J.M. Hanson, M.J. Meiners, "Improving Drilling
    Performance by Applying Advanced Dynamics Models", SPE/IADC 67697, 2001
    [5] A.A. Besaiow, M. L. Payne, "A Study of Excitation Mechanisms and Resonance
    Inducing Bottomhole-Assembly Vibrations", SPE Drilling Engineering, March 1988
    [6] Z. Li, B. Guo, "Analysis of Longitudinal Vibration of Drillstring in Air and Gas
    Drilling", SPE 107697, 2007
    [7] P.N. Jogi, J.D. Macpherson, M. Neubert, "Field Verification of Model-Derived
    Natural Frequencies of a Drill String", Transactions of the ASME, Vol. 124, September 2002
    [8] B. Schmalhorst, M. Neubert, "Dynamic Modeling Software", AADE-03-NTCE-53,
    2003
    [9] P.D. Spanos, A.M. Chevalier, N.P. Politis, M.L. Payne, "Oil Well Drilling: A
    Vibrations Perspective", The Shock and Vibration Digest, Vol 35, No 2, March 2003
    [10] A.P. Christoforou, A.S. Yigit, "Dynamic Modelling of Rotating Drillstring with
    Borehole Interactions", Kuwait University, Department of mechanical and Industrial
    Engineering, 1997
    [11] A.P. Christoforou, A.S. Yigit, "Fully coupled vibrations of actively controlled
    drillstrings", Journal of Sound and Vibration, 2003
    [12] T. Richard, C. Germay, E. Detournay, "Self-excited stick-slip oscillations of drill
    bits", Comptes rendus MECANIQUE, 2004
    [13] P.D. Spanos, A.M. Chevalier, N.P. Politis, "Nonlinear Stochastic Drill-String
    Vibrations", Transactions of the ASME, Vol. 124, October 2002
    [14] E.W. Robnett, J.A. Hood, J.D. Macpherson, "Analysis of the Stick-Slip
    Phenomenon Using Downhole Drillstring rotation data", SPE/IADC 52821, 1999
    hal-00595365, version 1 - 24 May 2011
    68
    [15] J.D. Jansen, L. Van Den Steen, "Active Damping of Self-Excited Torsional
    Vibrations in Oil Well Drillstrings", Journal of Sound and Vibration, Vol. 179, p. 647-668,
    1995
    [16] V.A. Dunayevsky, A. Judzis, "Onset of Drillstring Precession in a Directional
    Borehole", SPE 13027, 1984
    [17] V.A. Dunayevsky, F. Abbassian, A. Judzis, "Dynamic Stability of Drillstrings Under
    Fluctuating Weight on Bit", SPE 14329, 1993
    [18] T.M. Burgess, G.L. McDaniel, "Improving BHA Tool Reliability With Drillstring
    Vibration Models: Field Experience and Limitations", SPE/IADC 16109, 1987
    [19] G.W. Halsey, A. Kyllingstad, D. Lysne, "Drillstring Torsional Vibrations:
    Comparison Between Theory and Experiment on a Full-Scale Research Drilling Rig", SPE
    15564, 1986
    [20] C.A. Zamudio, J.L. Tlustly, D.W. Dareing, "Self-Excited Vibrations in Drillstrings",
    SPE 16661, 1987
    [21] M.W. Dykstra, D. C-K Chen, T.M. Warren, S.A. Zannoni, "Experimental
    Evaluations of Drill Bit and Drill String Dynamics", SPE 28323, 1994
    [22] M-P. Dufeyte, H. Henneuse, "Detection and Monitoring of the Slip-Stick Motion",
    SPE/IADC 21945, 1991
    [23] F. Clayer, J.K. Vandiver, H.Y. Lee, "The Effect of Surface and Downhole Boundary
    Conditions on the Vibration of Drillstrings", SPE 20447, 1990
    [24] R.W. Tucker, C. Wang, "A Simple Cosserat Model For The Dynamics Of Drill-
    Strings", Lancaster University, Department of Physics
    [25] H. Melakhessou, A. Berlioz, G. Ferraris, "A Nonlinear Well-Drillstring Interaction
    Model", Transactions of the ASME, Vol.125, January 2003
    [26] A.S. Bakenov, T. Gabler, E. Detourmay, C. Germay, "Enhanced Drilling
    Performance Through Controlled DrillString Vibrations", AADE-03-NTCE-21, 2003
    [27] A.P. Christoforou, A. S. Yigit, "Active Control of Stick-Slip Vibrations: The Role of
    Fully Coupled Dynamics", SPE 68903, 2001
    [28] M.W. Dykstra, D. C-K Chen, T.M. Warren, J.J. Azar, "Drillstring Component
    Mass Imbalance: A Major Source of Downhole Vibrations", SPE Drilling & Completion,
    1996
    [29] F. Abbassian, V.A. Dunayevsky, "Application of Stability approach to Torsional and
    Lateral Bit Dynamics", SPE Drilling & Completion, June 1998
    [30] M. Birades, "Static and Dynamic Three-Dimensional Bottomhole Assembly
    Computer Models", SPE Drilling Engineering, June 1988
    69
    [31] P.R. Pasley, Yih-Min Jan, J.E.E. Kingman, J.D. Macpherson, "Detection of BHA
    Lateral Resonances While Drilling With Surface Longitudinal and Torsional Sensors", SPE
    24583, 1992
    [32] C. Putot, C. Mabile, "Conditions d'apparition et formes de rebond d'un outil de forage
    tricône Institut français du pétrole", Institut Français du Pétrole,1999
    [33] T. Richard, "Self-Excited Stick-Slip Oscillations of Drag Bits", PhD Thesis,
    University of Minnesota, 2001
    [34] M.W. Dykstra, "Nonlinear Drill String Dynamics", PhD Thesis, University of Tulsa,
    1996
    [35] J.P. Den Hartog, "Mechanical Vibrations", Dover Publications Inc.,1985
    [36] C.E. Brennen, "A Review of Added Mass and Fluid Inertial Forces", CR 82.010,
    Naval Civil Engineering Laboratory, Jan. 1982
  1. Urgently need these papers.Who can help?
    By spower in forum Reservoir
    Last Post: 03-14-2013, 12:03 PM
  2. Replies: 3
    Last Post: 10-20-2012, 03:14 PM
  3. Ipls i urgently need these papers
    By CFC_MELODY in forum Reservoir
    Last Post: 04-04-2010, 01:30 AM
  4. SPE papers
    By zhaoweidong in forum Reservoir
    Last Post: 02-01-2010, 11:53 AM
  5. SPE papers
    By The Master in forum Reservoir
    Last Post: 11-07-2009, 03:49 PM
