Thread: I need these papers urgently
  1. I need these papers urgently
    Now I need the following ones:
    Millheim, K.K., Apostal, M.C.: “The Effect of Bottomhole
    Assembly Dynamics on the Trajectory of a Bit”, Journal of Petroleum
    Technology, Dec. 1981, S. 2323-2338.
    Heisig, G., Sancho, J., Macpherson, J.D.: “Downhole Diagnosis
    of Drilling Dynamics Data Provides New Level Drilling
    Process Control to Driller”, paper SPE 49206 prepared for
    presentation at the 1998 SPE Annual Technical Conference and
    Exhibition in New Orleans, planned for Sept 27-30, 1998.
    Dykstra, M.W.: “Nonlinear Drill String Dynamics”, PhDDissertation,
    University of Tulsa, Oklahoma, 1996.
    Bathe, K.: “Finite Element Procedures in Engineering Analysis”,
    Prentice Hall, Englewood Cliffs/NJ, 1982.
    Paslay, P.R., Bogy, D.B.: “The Stability of a Circular Rod Laterally
    Constrained to in Contact with an Inclined Circular Cylinder”,
    Journal of Applied Mechanics, Trans. ASME, Series A,
    31(1964), S. 605-610.
    and thanks
    Re: I need these papers urgently
  5. Re: I need these papers urgently
    Quote Originally Posted by selmagis View Post
    thanks a lot for the link
    you should clear out your inbox because when I wanted to send you a personal message , I can't.
    Could you provide me with the rest of the papers
  6. Re: I need these papers urgently
    I need the following papers urgently please help:
    [1] S.G. Lapierre, N. Seiler, D. C-K Chen, "Mitigating Vibration in Bi-Center Drilling
    Programs", IADC/SPE 87097, 2004
    [2] G. Heisig, M. Neubert, "Lateral Drillstring Vibrations in Extended-Reach Wells"
    IADC/SPE 59235, 2000
    [3] D. C-K Chen, M. Smith, S.G. Lapierre, "Advanced Drillstring Dynamics System
    Integrates Real-Time Modeling and Measurement", SPE 81903, 2003
    [4] M.W. Dykstra, M. Neubert, J.M. Hanson, M.J. Meiners, "Improving Drilling
    Performance by Applying Advanced Dynamics Models", SPE/IADC 67697, 2001
    [5] A.A. Besaiow, M. L. Payne, "A Study of Excitation Mechanisms and Resonance
    Inducing Bottomhole-Assembly Vibrations", SPE Drilling Engineering, March 1988
    [6] Z. Li, B. Guo, "Analysis of Longitudinal Vibration of Drillstring in Air and Gas
    Drilling", SPE 107697, 2007
    [7] P.N. Jogi, J.D. Macpherson, M. Neubert, "Field Verification of Model-Derived
    Natural Frequencies of a Drill String", Transactions of the ASME, Vol. 124, September 2002
    [8] B. Schmalhorst, M. Neubert, "Dynamic Modeling Software", AADE-03-NTCE-53,
    2003
    [9] P.D. Spanos, A.M. Chevalier, N.P. Politis, M.L. Payne, "Oil Well Drilling: A
    Vibrations Perspective", The Shock and Vibration Digest, Vol 35, No 2, March 2003
    [10] A.P. Christoforou, A.S. Yigit, "Dynamic Modelling of Rotating Drillstring with
    Borehole Interactions", Kuwait University, Department of mechanical and Industrial
    Engineering, 1997
    [11] A.P. Christoforou, A.S. Yigit, "Fully coupled vibrations of actively controlled
    drillstrings", Journal of Sound and Vibration, 2003
    [12] T. Richard, C. Germay, E. Detournay, "Self-excited stick-slip oscillations of drill
    bits", Comptes rendus MECANIQUE, 2004
    [13] P.D. Spanos, A.M. Chevalier, N.P. Politis, "Nonlinear Stochastic Drill-String
    Vibrations", Transactions of the ASME, Vol. 124, October 2002
    [14] E.W. Robnett, J.A. Hood, J.D. Macpherson, "Analysis of the Stick-Slip
    Phenomenon Using Downhole Drillstring rotation data", SPE/IADC 52821, 1999
    hal-00595365, version 1 - 24 May 2011
    68
    [15] J.D. Jansen, L. Van Den Steen, "Active Damping of Self-Excited Torsional
    Vibrations in Oil Well Drillstrings", Journal of Sound and Vibration, Vol. 179, p. 647-668,
    1995
    [16] V.A. Dunayevsky, A. Judzis, "Onset of Drillstring Precession in a Directional
    Borehole", SPE 13027, 1984
    [17] V.A. Dunayevsky, F. Abbassian, A. Judzis, "Dynamic Stability of Drillstrings Under
    Fluctuating Weight on Bit", SPE 14329, 1993
    [18] T.M. Burgess, G.L. McDaniel, "Improving BHA Tool Reliability With Drillstring
    Vibration Models: Field Experience and Limitations", SPE/IADC 16109, 1987
    [19] G.W. Halsey, A. Kyllingstad, D. Lysne, "Drillstring Torsional Vibrations:
    Comparison Between Theory and Experiment on a Full-Scale Research Drilling Rig", SPE
    15564, 1986
    [20] C.A. Zamudio, J.L. Tlustly, D.W. Dareing, "Self-Excited Vibrations in Drillstrings",
    SPE 16661, 1987
    [21] M.W. Dykstra, D. C-K Chen, T.M. Warren, S.A. Zannoni, "Experimental
    Evaluations of Drill Bit and Drill String Dynamics", SPE 28323, 1994
    [22] M-P. Dufeyte, H. Henneuse, "Detection and Monitoring of the Slip-Stick Motion",
    SPE/IADC 21945, 1991
    [23] F. Clayer, J.K. Vandiver, H.Y. Lee, "The Effect of Surface and Downhole Boundary
    Conditions on the Vibration of Drillstrings", SPE 20447, 1990
    [24] R.W. Tucker, C. Wang, "A Simple Cosserat Model For The Dynamics Of Drill-
    Strings", Lancaster University, Department of Physics
    [25] H. Melakhessou, A. Berlioz, G. Ferraris, "A Nonlinear Well-Drillstring Interaction
    Model", Transactions of the ASME, Vol.125, January 2003
    [26] A.S. Bakenov, T. Gabler, E. Detourmay, C. Germay, "Enhanced Drilling
    Performance Through Controlled DrillString Vibrations", AADE-03-NTCE-21, 2003
    [27] A.P. Christoforou, A. S. Yigit, "Active Control of Stick-Slip Vibrations: The Role of
    Fully Coupled Dynamics", SPE 68903, 2001
    [28] M.W. Dykstra, D. C-K Chen, T.M. Warren, J.J. Azar, "Drillstring Component
    Mass Imbalance: A Major Source of Downhole Vibrations", SPE Drilling & Completion,
    1996
    [29] F. Abbassian, V.A. Dunayevsky, "Application of Stability approach to Torsional and
    Lateral Bit Dynamics", SPE Drilling & Completion, June 1998
    [30] M. Birades, "Static and Dynamic Three-Dimensional Bottomhole Assembly
    Computer Models", SPE Drilling Engineering, June 1988
    69
    [31] P.R. Pasley, Yih-Min Jan, J.E.E. Kingman, J.D. Macpherson, "Detection of BHA
    Lateral Resonances While Drilling With Surface Longitudinal and Torsional Sensors", SPE
    24583, 1992
    [32] C. Putot, C. Mabile, "Conditions d'apparition et formes de rebond d'un outil de forage
    tricône Institut français du pétrole", Institut Français du Pétrole,1999
    [33] T. Richard, "Self-Excited Stick-Slip Oscillations of Drag Bits", PhD Thesis,
    University of Minnesota, 2001
    [34] M.W. Dykstra, "Nonlinear Drill String Dynamics", PhD Thesis, University of Tulsa,
    1996
    [35] J.P. Den Hartog, "Mechanical Vibrations", Dover Publications Inc.,1985
    [36] C.E. Brennen, "A Review of Added Mass and Fluid Inertial Forces", CR 82.010,
    Naval Civil Engineering Laboratory, Jan. 1982
  1. Urgently need these papers.Who can help?
    By spower in forum Reservoir
    Last Post: 03-14-2013, 12:03 PM
  2. Replies: 3
    Last Post: 10-20-2012, 03:14 PM
  3. Ipls i urgently need these papers
    By CFC_MELODY in forum Reservoir
    Last Post: 04-04-2010, 01:30 AM
  4. SPE papers
    By zhaoweidong in forum Reservoir
    Last Post: 02-01-2010, 11:53 AM
  5. SPE papers
    By The Master in forum Reservoir
    Last Post: 11-07-2009, 03:49 PM
