Originally Posted by
setyabudi
Follows are steps I was tried when install PVElite2010 and finally it look working. I am not sure which step make it work but you can try it and inform me.
1. Install pvelite 2010 demo from intergraph but there is limitation in internal pressure (not changeable value) ---> useless
2. Then I download "solution" PVelite 2010 from 4shared using SPLM option (follow thread "PVElite 2010 download link here" from egpet), but should buy licence code from "solution" --->not working
3. Copy files from installed PVElite 2010 Demo to installed non-demo --->not working
3. Install PVElite 2008 emulator only ---> still not working
4. Run C:\Program Files\COADE\PVElite 2010\Assidrv\trial-1.bat ---> still not working
5. Uninstall "solution" PVelite 2010 and reinstall it using "green dongle" option ---> LOOK WORKING, I can create, edit, open, etc but need more test to make it sure
Good luck
