Originally Posted by
Ali366
Polka,
What is your design or construction code? Construction code Api 1104
Where is the welded joint? Is it in a pressure equipment, say piping, pressure vessel, etc. or in a storage tank or steel structure? These welds are for air release valves and for other components like valve,clappe or manholes
If in a pressure equipment, is the weld joint a longitudinal weld or a circumferential joint? Not a pressure equipment valves or clappes
What is the degree/type of NDT? 100% x-ray
Cheers,
