Page 1 of 9 1 2 3 ... LastLast
Results 1 to 12 of 98
Thread: ISO Standards
  1. ISO Standards
    Dear Friends,
    I need the following standards, do any body has these:
    ISO 7066: Measurement of fluid flow:- assessment of uncertainty in the calibration and use of flow measuring devices
    ISO 6551: Petroleum Liquids and Gases – Fidelity and Security of Dynamic Measurement Cabled Transmission of Electrical and/or Electronic Pulsed Data
    ISO 4124: Statistical Control of Volumetric Metering Systems
    ISO 9300: Measurement of Gas Flows by Means of Critical Flow - Venturi Nozzles
    ISO TR 3313: Measurement of Fluid Flow in Closed Conduits – Guidelines on the Effect of Flow Pulsation on Flow Measurement Instruments
    ISO 4185: Measurement of liquid flow in closed conduits:- Weighing method
    ISO 2186 Fluid flow in closed conduits connections for pressure signal transmissions between primary and secondary elements.
    ISO 2714 Liquid Hydrocarbons – Volumetric Measurement by Displacement Meter Systems Other Than Dispensing Pumps
    Please upload.
    Shabbir
    ISO 9300-2005 Measurement of gas flow by means of critical flow Venturi nozzles.pdf 1.112 MB
    Quote Originally Posted by Achmad Nur Eddin View Post
    Dear Achmad Nur Eddin,
    Thanks a lot !
    thanks a lot
    Muhammad Khurram
  7. #5
    Sep 2008
    Here only- EGPET
    Blog Entries
    5
  9. #6
    Hi friend ... I need "ISO 179-1" Edition 2010 , do you have it available?
    please send to ahmadi_edu@yahoo.com
    Thanks alot
  10. Dear Achmad Nur Eddin,
    Thanks a lot.
  11. Hi All
    At least need
    ISO 6551, 2186, 3313 urgently.
  12. #9
    ISO 2186-1973 Connection f pressure between primary & secondary.pdf 0.906 MB
  13. Dear Achmad Nur Eddin,
    Thanks a lot !
  14. #11
    Here is some more :
    ISO 2186-1973 :
    ISO 2714-1980 :
    ISO 4124-1994 :
    ISO 4185-1980 :
    ISO TR 3313-1992 :
    Good Luck
  16. Thanks a million netspyking.
    Do you also have ISO 9464?
  1. API standards
    By ayoubhk in forum Safety And Environment
    Last Post: 12-15-2014, 02:29 AM
  2. ISA standards
    By kaicyem in forum Instrumentation & Control
    Last Post: 06-21-2014, 12:26 AM
  3. BS/DIN/EN - STANDARDS FOR P&ID's
    By ceeee83 in forum Engineering Certificates
    Last Post: 04-27-2013, 08:10 AM
  4. Need the following IEC standards
    By SA_FETY in forum Safety And Environment
    Last Post: 12-09-2011, 05:11 AM
  5. IEC Standards
    By sunset_eagle in forum Electrical & Power Engineering
    Last Post: 10-25-2010, 08:52 PM
