Hi mattegm,
I agree with you that normally hydrocyclones can receive 1000 ppm and produce an underflow with 25-30 ppm if the condition* below is satisfied:
*the optimum flow per liner and a reject/underflow dP ratio between 1,6 - 2,5 depending on the type of the liners. I presume that the booster pump and the cyclones are already designed according to these parameters.
I also presume that since you are mentioning the 'safety issue', either you have a spec brake across your feed to the cyclones and actuallly you want to use the oil skimmer like a knock-out drum provided with a PSV (as per P&ID) OR your client wants some extra residence time to ensure that the required OIW quality is always achievable. Please clarify this point.
Moreover, unless you are dealing with an oil with very low API, it seems 20 minutes residence time are more than enough. I normally treat my produced water (inlet 30 ppm - outlet 5-8 ppm oil density ~750 kg/m3) with a residence time of 3 - 4 minutes (water clarifier and demulsifier in injected upstream) with a simple oil skimmmer (degasser). 20 minutes would be a gift
For your information, to my knowledge, hydrocyclones are only capable of removing oil with diameters larger than 10 microns. So, if I were you, I would certainly check the expected particle size distribution of my produced water feed just to be sure before kick-off the design work.
Furthermore, it would be a good idea to reduce set pressure of the skimmer as low as possible to the limit where it corresponds to the maximum NPSH required of your booster pump. The more degassing you have, the more natural gas flotation you will apply.
Based on your design constraints, I understans that your skimmer is actually 25% loaded as per the desing flows you specified. So, once you install the calming baffle plates, a simple inlet flow distributor, a V-notch type skimmer, carefully calibrated level instruments and a small dosage of demulsifier injection upstream the skimmer, your skimmer shall work quite OK. Note that you may even not need any internals I specifed since 10 meters is alredy a very good distance to calm the water. But, this depends on the budget you have and the conditions of your contract with the client. Also to the water chemistry. Is there any emulsion expected in the skimmer?
Also, have a careful look on where the reject stream of the cyclones are routed normally. Sometimes they can be routed to the upstream of the feed and you have to consider this negative impact in your design.
Finally, what is the fuction the nutshell filters? Normally I always considered them as polishing units but not a unit to treat the skimmed oil from the oil skimmer. Maybe I will learn something.
