You can calculate the flow rate when CV fail to open by using the CV value at full open condition. Usually CV value is provided by the control valve manufacturer. You need to determine the upstream and downstream pressure and put in to the formula of CV value calculation to calculate flow rate. See control valve handbook for the formula.
Hope this will help you.
mskhadke
