full list:
EN ISO 252:2007 Conveyor belts - Adhesion between constitutive elements - Test methods (ISO 252:2007)
EN ISO 283:2015 Textile conveyor belts - Full thickness tensile strength, elongation at break and elongation at the reference load - Test method (ISO 283:2015)
EN ISO 284:2012 Conveyor belts - Electrical conductivity - Specification and test method (ISO 284:2012)
EN ISO 340:2013 Conveyor belts - Laboratory scale flammability characteristics - Requirements and test method (ISO 340:2013)
EN ISO 505:1999 Conveyor belts - Method for the determination of the tear propagation resistance of textile conveyor belts (ISO 505:1999)
EN ISO 583:2007 Conveyor belts with a textile carcass - Total belt thickness and thickness of constitutive elements - Test methods (ISO 583:2007)
EN ISO 703:2007 Conveyor belts - Transverse flexibility (troughability) - Test method (ISO 703:2007)
EN ISO 1120:2012 Conveyor belts - Determination of strength of mechanical fastenings - Static test method (ISO 1120:2012)
EN 1554:2012 Conveyor belts - Drum friction testing
EN ISO 7590:2009 Conveyor belts - Drum friction testing
EN ISO 7622-1:2013 Steel cord conveyor belts - Longitudinal traction test - Part 1: Measurement of elongation (ISO 7622-1:2013)
EN ISO 7622-2:2015 Steel cord conveyor belts - Longitudinal traction test - Part 2: Measurement of tensile strength (ISO 7622-2:2015)
EN ISO 7623:2015 Steel cord conveyor belts - Cord-to-coating bond test - Initial test and after thermal treatment (ISO 7623:2015)
EN ISO 8094:2013 Steel cord conveyor belts - Adhesion strength test of the cover to the core layer (ISO 8094:2013)
EN ISO 9856:2003 Conveyor belts - Determination of elastic and permanent elongation and calculation of elastic modulus (ISO 9856:2003)
EN ISO 9856:2003/A1:2012 Conveyor belts - Determination of elastic and permanent elongation and calculation of elastic modulus (ISO 9856:2003)
EN 12881-1:2014 Conveyor belts - Fire simulation flammability testing - Part 1: Propane burner tests
EN 12881-2:2005+A1:2008 Conveyor belts - Fire simulation flammability testing - Part 2: Large scale fire test
EN 12882:2015 Conveyor belts for general purpose use - Electrical and flammability safety requirements
EN 13827:2003 Steel cord conveyor belts - Determination of the lateral and vertical displacement of steel cords
EN ISO 14890:2013 Conveyor belts - Specification for rubber- or plastics-covered conveyor belts of textile construction for general use (ISO 14890:2013)
EN 14973:2015 Conveyor belts for use in underground installations - Electrical and flammability safety requirements
EN ISO 15147:2012 Light conveyor belts - Tolerances on widths and lengths of cut light conveyor belts (ISO 15147:2012)
EN ISO 15236-1:2005 Steel cord conveyor belts - Part 1: Design, dimensions and mechanical requirements for conveyor belts for general use (ISO 15236-1:2005)
EN ISO 15236-2:2004 Steel cord conveyor belts - Part 2: Preferred belt types (ISO 15236-2:2004)
EN ISO 15236-3:2007 Steel cord conveyor belts - Part 3: Special safety requirements for belts for use in underground installations (ISO 15236-3:2007)
EN ISO 15236-4:2004 Steel cord conveyor belts - Part 4: Vulcanized belt joints (ISO 15236-4:2004)
EN ISO 16851:2013 Textile conveyor belts - Determination of the net length of an endless (spliced) conveyor belt (ISO 16851:2012)
EN ISO 21178:2013 Light conveyor belts - Determination of electrical resistances (ISO 21178:2013)
EN ISO 21179:2013 Light conveyor belts - Determination of the electrostatic field generated by a running light conveyor belt (ISO 21179:2013)
EN ISO 21180:2013 Light conveyor belts - Determination of the maximum tensile strength (ISO 21180:2013)
EN ISO 21181:2013 Light conveyor belts - Determination of the relaxed elastic modulus (ISO 21181:2013)
EN ISO 21182:2013 Light conveyor belts - Determination of the coefficient of friction (ISO 21182:2013)
EN ISO 21183-1:2006 Light conveyor belts - Part 1: Principal characteristics and applications (ISO 21183-1:2005)
EN ISO 21183-2:2006 Light conveyor belts - Part 2: List of equivalent terms (ISO 21183-2:2005)
EN ISO 22721:2007 Conveyor belts - Specification for rubber- or plastics-covered conveyor belts of textile construction for underground mining (ISO 22721:2007)
missing ones:
or
