Page 1 of 5 1 2 3 ... LastLast
Results 1 to 12 of 56
Thread: ANSI HI - Hydraulic Institute Standards
    We need some of the new ones, I will post all that I have
    Here are the recent needed:
    2016
    • Rotary Pump Tests (ANSI/HI 3.6–2016)
    • Air-Operated Pumps (ANSI/HI 10.1-10.5–2016)
    • Air-Operated Pump Tests (ANSI/HI 10.6–2016)
    2015
    • Reciprocating Pumps (ANSI/HI 6.1-6.5–2015)
    • Reciprocating Pump Tests (ANSI/HI 6.6–2015)
    • Direct Acting Pumps (8.1-8.5–2015)
    • Pumps - General Guidelines (9.1-9.5–2015)
    • Rotodynamic Pumps for Assessment of Applied Nozzleloads (ANSI/HI 9.6.2–2015)
    2014
    • Rotodynamic Pumps — Guidelines for Dynamics of Pumping Machinery (ANSI/HI 9.6.8–2014)
    • Methods for Rotodynamic Pump Efficiency Testing (HI 40.6–2014)
    Re: ANSI HI - Hydraulic Institute Standards
    ANSI HI 1.1-1.2-2008 Rotodynamic (Centrifugal) Pumps for Nomenclature and Definitions
    ANSI HI 1.4-2010 Rotodynamic (Centrifugal) Pumps for Manuals Describing Installation, Operation, and Maintenance
    ANSI HI 1.3-2013 Rotodynamic Centrifugal Pumps for Design and Application
    ANSI HI 2.1-2.2-2008 Rotodynamic (Vertical) Pumps for Nomenclature and Definitions
    ANSI HI 2.1–2.2-2014 Rotodynamic Vertical Pumps of Radial, Mixed, and Axial Flow Types for Nomenclature and Definitions
    ANSI HI 2.4-2008 Rotodynamic (Vertical) Pumps for Manuals Describing Installation, Operation, and Maintenance
    ANSI HI 2.3-2013 Rotodynamic Vertical Pumps of Radial, Mixed, and Axial Flow Types for Design and Application
    ANSI HI 3.1-3.5-2008 Rotary Pumps for Nomenclature, Definitions, Application and Operation
  11. #9
    ANSI HI 3.6-2010 Rotary Pump Tests
  12. #10
    ANSI HI 5.1-5.6-2010 Sealless Rotodynamic Pumps for Nomenclature, Definitions, Application, Operation, and Test
  13. #11
    ANSI HI 6.1-6.5-2000 Reciprocating Power Pumps for Nomenclature, Definitions, Application, and Operation
  14.    Spons.
  15. #12
    ANSI HI 7.1-7.5-2013 Controlled-Volume Metering Pumps for Nomenclature, Definitions, Application, and Operation
  1. HI-Hydraulic Institute Standards
    By gasenilahmad in forum Mechanical Engineering
    Last Post: 01-21-2019, 01:49 AM
  2. Hydraulic Institute Standards
    By sslovinsky in forum Mechanical Engineering
    Last Post: 06-28-2015, 09:26 PM
  3. ANSI HI Standards (hydraulic institute)
    By magdy_eng in forum Mechanical Engineering
    Last Post: 01-27-2014, 08:08 PM
  4. Hydraulic institute standards
    By andresmonacho in forum Oil And Gas Production
    Last Post: 05-09-2013, 01:34 AM
  5. Hydraulic Institute Standards
    By setak in forum Pipeline And Fluid Flow
    Last Post: 04-05-2011, 09:07 PM
