For a WET GAS compression application I am utilizing the method for polytropic stages with phase equilibria available in PRODE PROPERTIES,
the procedure allows to solve (in both design and rating modes) a polytropic stage with single phase or two phases flows (it calculates phase equliibria).
My version has two methods,
1) Huntington method which is applicable to gas phase only
2) Proprietary method which is applicable to gas, gas + liquid and liquid phases
option 2) for gas gives results very close to Huntington method.
However it is slower (it solves phase equilibria too) and it's better to utilize this option when there is some liquid.
With option 2) one can simulate different kind of equipments as centrifugal compressors, screw compressors, pumps etc.
In design mode the procedure requires a value for polytropic efficiency (which is available from manufacturers or can be estimated)
in rating mode the procedure calculates the values of polytropic efficiency based on measured data.
