Thread: Minimum Distance Between Feed Nozzle and Tray Downcomer
  1. Minimum Distance Between Feed Nozzle and Tray Downcomer
    Hello all,
    Would any of you know the recommended distance (vertically) between the top of a feed nozzle and the bottom of the tray's above downcomer for a vapor feed stream in a distillation tower?
  2. Re: Minimum Distance Between Feed Nozzle and Tray Downcomer
    The inlet nozzle centerline to the bottom of the tray should not be less than 12 inches. For a vapor feed, where depending on the inlet velocity head you might need a vapor distribut&#246;r I would make that distance at least 18 inches.
  4. Re: Minimum Distance Between Feed Nozzle and Tray Downcomer
    That should vapor distributor
  1. What is the minimum distance between two welding joints?
    By polka in forum Mechanical Engineering
    Last Post: 02-17-2012, 09:42 PM
  2. restraint nozzle load &#62; allowable nozzle load
    By aankhaerudin in forum Mechanical Engineering
    Last Post: 09-27-2011, 05:24 AM
  3. 4 way downcomer
    By aakul1127 in forum Oil And Gas Production
    Last Post: 08-02-2010, 11:29 PM
  4. 4 way downcomer
    By aakul1127 in forum Pipeline And Fluid Flow
    Last Post: 07-15-2010, 08:50 AM
  5. Reaction furnace WHB w/ SD: downcomer nozzle location
    By Pete in forum Mechanical Engineering
    Last Post: 01-23-2010, 08:33 AM
