Results 1 to 5 of 5
Thread: Shell and tube reactor
    Dear friends!
    I very need the method of calculating for shell and tube reactor, can you help me!!!.
    Thanks!
    my email: suchest@gmail.com
  2. Dear friend,
    For Thermal design, you may look in " Process Heat transfer by DQ Kern " . There are about 30 odd thermal design calculations for different cases in that book . You may look for an example more near to your case , and follow its calculation procedure . For Mechanical design you need to follow TEMA. If your objective is academic interest the above route is good for learning . If your requirement is for a commercial installation of the reactor , my suggestion is you may better assign the job to an experineced agency .
    Best regards
    Venugopal
    first you must know the temperature of reaction, endothermic or exothermic. for keep the constant temperature you must supply cooling water for exothermic reaction and steam for endothermic reaction. the ammount of heat deppend on capacity of reactant. for detail design of shell and tube, " Process Heat transfer by DQ Kern " is good reference (like A.Venugopal suggestion)
    Mar 2009
    Spain, Barcelona
    I upload Kern.
    Is the book most powerful to heat transfer.
    In fact, it is the Biblie to heat tranfer.
    I hope that it would be interest for us.
  6. Thanks
  1. Tube to tubesheet leakage in shell & tube heat exchangers
    By amitss_sam in forum Mechanical Engineering
    Last Post: 03-16-2016, 08:10 AM
  2. SHELL AND TUBE HEAT EXCHANGER (Tube Sagging Problem)
    By hammad_nrl in forum Mechanical Engineering
    Last Post: 04-10-2013, 06:06 AM
  3. Replies: 3
    Last Post: 04-03-2013, 07:00 AM
  4. Replies: 1
    Last Post: 12-11-2010, 11:36 PM
  5. tube sealing leakage in shell & tube heat exchanger
    By amitss_sam in forum Pipeline And Fluid Flow
    Last Post: 12-10-2010, 03:38 PM
