Page 1 of 3 1 2 3 LastLast
Results 1 to 12 of 27
Thread: Problem Running ECLIPSE from PETREL
    Hi Eveyone
    I Have both Petrel 2010 and Eclipse 2005 (both with -------- ) installed on my Laptop and they both work Great .
    The problem is that, whenever I try to run eclipse from petrel ,it fails to run eclipse saying it can not find eclipse license. .
    (by right clicking on imported case in "cases" panel and select simulation run )
    However, if I use eclipse launcher to run eclipse ,it works fine and run my data file without any error.
    I suspect that this might have something with --------s .
    Do you ever encountered the same problem and is there any solution for this ?
    Any help or suggestion is greatly appreciated
    Cheers !
    Re: Problem Running ECLIPSE from PETREL
    suggest you use Eclispe2010
    Go to your environment variable setting. Try to put Petrel and Eeclipse under same variable name
    Example
    Variable name=LM_LICENSE_FILE
    Variable value=27007@LOCALHOST;c:\ecl\home\license.dat
    Variable value 27007@LOCALHOST for Petrel and c:\ecl\home\license.dat for Eclipse. Don't use separate variable name for eclipse and Petrel
    Quote Originally Posted by Alphino View Post
    Hi Eveyone
    Cheers !
    Example
    friend,have you solved the problem?when running the case from petrel?
    Thanks every one.After so many tries,I finally managed to solve this problem .and now I can launch eclipse from petrel (Eclipse 2009 and Petrel 2010.2 both 32 bit on windows 7 64 bit )
    Here is how I Solved it
    1) Do not use LMTOOLS.exe for setting the license files.Instead, use "SLBLicensing.exe" (yellow lock icon in flex folder ) and add both eclipse and petrel license files using this application.
    2) Remebrer to run "SLBLicensing.exe" "As Administrator" in windows 7 and vista.
    3) After adding licenses ,click start button . It will give you the "License successfully run" message.
    4) ****very important***
    Make Sure to use the same port number in both license files.
    open both your license files and find this line .It is usually the first line :
    SERVER computerName ANY 8888
    here is used the 8888 for license port number. this number should be exactly the same in both licnese files.
    5) got to C:\ecl\home and open "$eclrc.bat" using Notepad or any text editor. find the following line.
    :SET LM_LICENSE_FILE=8888@localhost;
    ***Important**** --> remove the : before this line, otherwise eclipse consider it as a comment line.
    I wrote my 8888 port number in that line . you should write your desired port number which you have already wrote in your license files.
    6) Save this changes.
    7) windows 7 does not allow you to "Save".Instead of "Save" use "Save As " option and Save the modified file in desktop( or wherever you like). Then copy it from desktop and replace it in the "home" folder.
    8) Enjoy running eclipse from Petrel Halesho bebarin!
  9. Re: Problem Running ECLIPSE from PETREL
    Hi friend,
    I am trying to run a simulation on Eclipse, but i get a license error when i press GO in the run window. The error is in the cmd saying license unavaliable.. I followed your steps regarding slblicensing but finally stuck at this point
    any advices?
    Cheers
    Quote Originally Posted by Jamesbond0087 View Post
    Hi friend,
    any advices?
    Cheers
    At which point exactly, you stuck ?
    1)Did you set your computer name in the license file ? (SERVER computerName ANY 8888 ) you need to change the ComputerName in here to your computer name )
    2)Paste the error message you get in here !
    3)does your license is only valid for a specific MAC address or it is valid for any system ? ( SERVER computerName ANY 8888 , Does your fist line in license look like line before? can you see "ANY" i it ? )
    Check these points and let me know
  11. #9
    good job my friends. Finally I got it solved
  12. #10
    licene eclipse is any 1700 and license petrel is only valid for a specific mac address. The first line in license "SERVER this_host 183da248acd8". Can you have me solve it?
  13. Re: Problem Running ECLIPSE from PETREL
    please I need lic file for ANY mac address fo eclipse 2010 help me help you > if my problem got solved ill give ******* petrel 2013 link and youtube video to setup please
  14.    Spons.
  15. Re: Problem Running ECLIPSE from PETREL
    Hi Junay,
    You follow above instruction or what's way? Please share with me. Thanks
  1. ECLIPSE2009.2 from PETREL2011 Running Problem
    By m.darweesh in forum Reservoir
    Last Post: 05-30-2013, 03:54 PM
  2. Eclipse 300 problem
    By Rafster in forum Reservoir
    Last Post: 04-30-2013, 02:11 AM
