Thread: ASME Section II Part D Table 1A
  1. ASME Section II Part D Table 1A
    Can somebody please tell me if in Table 1A of ASME Section II Part D, there is just written "PIPE" in product form, what does it mean? I mean, will the pipe be Seamless or Welded?
    For Example, take the case of SA-333 Grade 4 K11267, the product form is JUST "PIPE", not "SMLS or WELDED Pipe" as already written for SA-333 Grade 6 K03006. So, will grade 4 be in SMLS or welded, or both?
    it's not important.As a matter of fact your construction code shall be one of ASME B31 series or etc. in those construction code it is mentioned for example in ASME b31.3 table 302.3.4
    that what is "longitudinal weld joint quality factor" for each kind of manufacturing process. Then this factor will affect relevant equations in designs.
  4. @ Siamak! Thanks for your comment, but i don't agree with this. As you can see, ASTM A106 is always manufactured Seamless and so, you can't apply any of the factors as defined in ASME B31.3 Table 302.3.4. Rather, you have to take E = 1.00.
    Same is the case with SA-333 Grade 4 K11267, i can't refer ASME B31.3 Table 302.3.4 before i know its fabrication, i.e., SMLS, ERW, FBW or so on.
  5. @ Siamak! Thanks for your comment, but i don't agree with this. As you can see, ASTM A106 is always manufactured Seamless and so, you can't apply any of the factors as defined in ASME B31.3 Table 302.3.4. Rather, you have to take E = 1.00.
  1. ASME PTB-3-2013 asme section viii div.2 ,example problem manual
    By lois in forum Mechanical Engineering
    Last Post: 02-25-2025, 01:20 PM
  2. Asme section ii & asme section v - 2010
    By d.manikyarao in forum Oil And Gas Process
    Last Post: 11-02-2018, 10:22 AM
  3. Replies: 1
    Last Post: 07-29-2014, 10:26 PM
  4. Asme section i and asme section iv 2011 edition required
    By muzammil in forum Mechanical Engineering
    Last Post: 03-20-2013, 08:12 PM
  5. REQUIRED : ASME Section II (Part A To D) 2007
    By simpanbuku in forum Mechanical Engineering
    Last Post: 07-17-2012, 04:18 PM
