Results 1 to 8 of 8
Thread: Safety Instrumented Systems- comprehensive e-learning course
    A comprehensive e-learning course (with free online exam & Certification)on
    Covering more than any other course available today at a price that is less than any other!
    Dear Friend,
    You are here, reading this page, because you are well aware of the role of Safety Instrumented Systems (SIS), in protection of assets and people. In recent years, there have been extensive studies on the best ways of making our process plants safer and the conclusion is that by just doing one thing right, which is -increasing the reliability of the Instrumentation and Control systems in a plant, can make these plants much safer.
    On the other hand, negligence in respect of Safety Instrumented Systems (SIS) can be really disastrous, literally. Look at just a few recent cases below.
    What are Safety Instrumented Systems?
    Basic Ideas about SIS
    Functional Safety
    Instrumented Systems & Safety Instrumented Systems
    BPCS
    BPCS and SIS
    Safety Instrumented Function
    Safety Instrumented Function-2
    Safety Instrumented Function-3
    Emergency Shutdown Systems
    Need for a separate SIS
    Simulation exercise
    Learnings from the exercise
    Typical architecture
    Integrated BPCS & SIS
    Integrated BPCS & SIS-2
    Examples
    Differences between BPCS & SIS
    MODULE 2-Hazards, Risks & their analysis
    Hazards & Risks
    Types of hazards- Fire & Explosions
    Types of hazards-Toxic Material
    The Safety Lifecycle
    Steps in analysis
    Preliminary Hazard Analysis
    HAZOP
    HAZAN
    Consequence Analysis
    Risk
    Risk graph
    Risk Reduction
    Risk Reduction-2
    The ALARP principle
    Risk Reduction in process plants
    Risk Reduction explained
    Risk reduction using an SIF
    Layers of Protection
    Layers of Protection in the process industries
    Preventive & Mitigative layers
    Safety Requirement Specification
    Safety Requirement Specification-2
    Diversity
    MODULE 3-Failures & Reliability
    Failures
    Types of failures
    Types of failures-2
    Types of failures-3
    Dangerous & Safe failures
    Safe Failure Fraction
    SFF Pie Chart
    Proof Test Interval
    Diagnostic Coverage
    Common Cause Failures
    Common Cause Failures-2
    CCF Example
    Diversity
    Reliability
    Failure Rate
    MTTF
    MTTR
    MTBF
    Failure Data
    Software Reliability & fault injection
    Reliability Block Diagrams
    Reliability Block Diagrams-2
    Reliability Block Diagrams-3
    Redundancy and Reliability
    Fault Tree Analysis
    Fault Tree Analysis Example- 1
    FTA and RBD
    Fault Tree Analysis Example-2
    Fault Tree Analysis-Probabilities
    Event Trees
    Event Tree Components
    Event Tree Analysis Example
    Fail-Safe and Fail Danger modes
    FMEA
    FMEDA
    FMEDA report
    How to use the FMEDA report
    Redundancy
    Redundancy and Voting
    Voting Systems 1oo1
    Voting Systems 1oo2
    Voting Systems 1oo2D
    Voting Systems 2oo2
    Voting Systems 2oo3
    Spurious Trips
    Concept of Demand
    Low Demand & High Demand
    Demand in a plant
    PFD
    MODULE 4-Safety Integrity Level
    Introduction to Safety Integrity Level
    What SIL is not
    Is SIL applicable to me?
    SIL 1 to SIL 4
    SIL for Demand Mode
    SIL for Demand Mode-Example
    SIL for Continuous/High Demand Mode
    The SIL process
    Common SIL questions
    Common SIL questions-2
    Target SIL-Qualitative & Quantitative methods
    Risk Reduction Factor-1
    Risk Reduction Factor-2
    Safety Availability and PFDavg
    SIL calculation Example
    SIL calculation Example (contd)
    SIL Calculation example-(modification)
    SIL Calculation example-additional layers
    SIL Calculation example-caution
    Consequence Only Method
    Hazard Matrix Method
    Hazard Matrix Method- (contd)
    Hazard Matrix Method-Example
    Risk Parameter Graph-1
    Risk Parameter Graph-2
    Risk Parameter Graph-3
    LOPA method
    Conducting a LOPA
    LOPA method
    LOPA Example
    LOPA Example contd
    LOPA Example contd 2
    LOPA Example contd 3
    SIL verification basics
    PFD of simple loop
    SIF design process
    SIL verification
    Architectural Constraints
    Architectural Constraints IEC 61508
    Hardware Fault Tolerance-IEC61508
    Architectural Constraints-Example
    Hardware Fault Tolerance (contd)
    Hardware Fault Tolerance-IEC61511
    SIL verification methods
    Simplified Equations
    Use of Simplified Equations-Example
    Markov Modeling-1
    Markov Modeling-2
    Markov Modeling-3
    Markov Modeling-4
    SIL verification example
    SIL verification example-2
    MODULE 5-SIS Standards
    Introduction to Standards in SIS
    AK 1 to AK 8
    IEC Standards
    IEC 61508
    IEC 61508-Safety Life Cycle
    IEC 61511-Basics
    Relationship between IEC 61508 & IEC 61511
    ISA S84 Background
    Practical applications
    What standards apply to me?
    MODULE 6- SIS in practice
    Components of the Safety Loop
    Types of logic Solvers
    Hardwired logic solvers-Trip amplifiers
    Hardwired logic solvers-Gates
    Safety Relays-Electromechanical
    Safety Relays-Electromechanical-2
    Safety Relays-Electromechanical-3
    Safety Relays-Electromechanical-4
    Safety Relays-Electronic
    Safety Relays-Electronic-2
    Safety Relays-Electronic-3
    Programmable Logic Solvers
    Safety PLCs & General Purpose PLCs
    Fault Diagnostics
    Safety PLCs- Inputs
    Safety PLCs-Processors
    Safety PLCs- Outputs
    Safety PLCs-Software
    Safety PLCs-Software-2
    Safety PLCs-Software-Design
    Safety PLCs-Voting architecture
    Safety PLCs-TMR
    Safety PLCs-QMR
    Safety PLCs-Interface to BPCS
    Safety Networks-1
    Safety Networks-2
    HIPPS
    MODULE 7-SIS Testing & Maintenance
    Need for testing
    Testing-Example
    Breakup of failures
    Testing the components of a SIS
    Testing Sensors & Transmitters
    Testing Logic Solvers
    Testing valves
    Valve Testing-Bypass method
    Partial Stroke Testing
    Partial Stroke Testing-ISA method
    Valve Testing- Mechanical Stoppers
    Valve Testing-Smart Positioner method
    PST-Advantages & Disadvantages
    Self Assessment Test
    COURSE TABLE OF CONTENTS
    You have seen how detailed and comprehensive this course is, as compared to any other course anywhere. So what are you waiting for?
    Download it now!
    100 % satisfaction guaranteed.
    If you find that this course is not worth the price or it does not work for you for any reason within a period of 30 days, then we will refund you your full money back!
    Note:
    1. For companies and other organizations who wish to tweak this course, we also offer CUSTOMIZATION options. Please send your query to sales@abhisam.com
    2. We can also offer a HOSTED option. This allows learners to take the entire course ONLINE without DOWNLOADING any software at all. Reports of learner login times, scores can be provided.
    Includes how to assess and verify Safety Integrity Level (SIL)
    Caribbean Petroleum, Puerto Rico, 2009
    A massive fire and explosion sent huge flames and smoke plumes into the air at the Caribbean Petroleum Corporation near San Juan, Puerto Rico. The resulting pressure wave damaged surrounding buildings and impacted moving vehicles. Preliminary cause found, was non working of the overfill protection system (part of the Safety Instrumented System).
    Petrolia, Pennsylvania, USA, 2008
    Thousands of residents of surrounding areas had to be evacuated to safer places when there was a release of large quantities of Oleum (fuming Sulfuric acid), from a chemical plant. The root cause was determined to be non implementation of a proper Safety Instrumented System.
    Danvers, Massachusetts, USA, 2006
    Massive explosion at an ink processing plant causes destruction of plant as well as surrounding homes, injuring many residents of surrounding areas. Cause? Lack of safety interlocks and automatic shutdown systems (in other words a Safety Instrumented System) in the plant.
    Morgantown, North Carolina,USA, 2006
    Explosion at a polymer manufacturing plant led to total damage of the facility, with a human fatality and several injuries. Investigations found out that a lack of process safety standards and non implementation of automatic interlock systems (in other words, Safety Instrumented Systems) as the root causes of the disaster.
    Buncefield, UK, 2005
    The Buncefield industrial disaster was one of the biggest disasters to strike the chemical and petrochemical industry in Europe in recent years. The blasts that occurred were so loud, they were heard as far away as France! (Buncefield is in the UK) The root cause was found out to be a probable malfunctioning Safety Instrumented System in one of the plants on the site.
    The list goes on and on.....
    Of course, you agree, that Safety Instrumented Systems are essential and are operational in many plants and facilities around the globe. But mere operation and existence of such a system, does not ensure, that it will always work as designed , is it not?
    You need to know it in depth, to make it work for you.
    To make it work for you, you need to know these systems thoroughly ( I mean not from a programming point of view but from a users point of view). You need to get trained in all the concepts and ideas of Safety Instrumented Systems. Note that here, when we refer to Safety Instrumented Systems(SIS), we also include Emergency Shutdown Systems (ESD), Safety Shutdown Systems, High Integrity Pressure Protection Systems (HIPPS) and all similar systems that are used to ensure the safe operation of plant and machinery, using instruments, electrical and pneumatic/hydraulic devices.
    However, the jargon associated with these sophisticated process control systems is so put-offing and even confusing, that even experienced professionals cringe at the mention of Triple Modular Redundant, 2oo3 voting, SIL 3 or IEC 61508.
    Does it really have to be this way?
    No! Not really.
    You can get this e-learning course on Safety Instrumented Systems(SIS) and learn all about these systems, in the comfort of your home or office.
    Just download this Safety Instrumented Systems e-learning course today and for a fraction of the price that you would otherwise pay for a classroom training course, learn everything that you wanted to know about SIS (but didn't know whom to ask).
    Of course, you could always pass this up and decide to go for that seminar or classroom training, whenever that is offered , or buy a book on this topic,
    but,
    remember that
    a) this early bird price will not last for long
    b) you will forget all about this, till the time comes for you to explain to somebody higher up, as to why you installed the 2oo3 Safety Logic Solver instead of the alternate 1oo2 Logic Solver , OR (God forbid)-you have to explain to a government inspector why you felt that SIL 1 was adequate for your Safety Instrumented function instead of a SIL 3 that he felt should have been required.
    c) you will , once again, be conned into buying a SIL 3 transmitter from that smooth talking vendor (there is no such thing as a SIL 3 transmitter BTW-find out why in the course)
    d) You forget about this e-learning course completely. Then you enroll yourself in an expensive $ 2500 classroom course, travel halfway around the globe to attend it, spend some more of your undernourished training budget on it and then forget whatever you learned when the time comes to finally apply the concepts learned in your work.
    e) You decide to skip this offer and opt to buy a book (or books) on this topic. However, there are a couple of problems. The first is that not a single book is available on the market, that covers all the topics that you need to know. On the other hand, there are a lot of things in every book, that you can safely skip, without missing anything. Thus, if you wish to source your knowledge of Safety Instrumented Systems from books, you will have to buy not one but several. They also cost a pretty penny (are not cheap at all). The cost of just two of them will be more than the price of this course
    So, why don't you simply download this first of its kind training course on Safety Instrumented Systems and
    a) Be assured that you have the best course on Safety Instrumented Systems in an e-learning format.
    b) Have access always, to the entire course (it will reside silently on your computer 24/7), for as long as you retain your computer. There is no recurring license fee. This means once you buy a license, you can access it for as long as you wish, on the same computer.
    c) Get a comprehensive course that has several Flash based animations and rich graphics, explained in a very simple to understand way, with accompanying text, that will remove all the "complexity" that is normally associated with this subject.
    Sep 2008
    Here only- EGPET
    Blog Entries
    5
    Dear
    It is a demo file, if you have complete package then please share.
    pls share
  5. Dear Ali
    please share the full version. my email is anwarussaeed@yahoo.com ... Tx
  6. please share dmnyapar@yahoo.com
    guys this course cost 400 USD.....and this is an advertising.....
    thank u
    Muhammad Khurram
  10. Re: Safety Instrumented Systems- comprehensive e-learning course
    Does anyone have the full version, if so pleaseeeeeee share it, thanks in advance!!
  1. Guidelines for Safe and Reliable Instrumented Protective Systems
    By Mohamed in forum Safety And Environment
    Last Post: 09-22-2014, 03:21 AM
  2. Replies: 2
    Last Post: 09-04-2014, 05:13 PM
  3. Safety Instrumented Systems: Design, Analysis, and Justification
    By ali in forum Instrumentation & Control
    Last Post: 05-30-2014, 01:21 PM
  4. ISA S84.01 Safety Instrumented Systems
    By colindlewis in forum Instrumentation & Control
    Last Post: 03-19-2014, 12:52 PM
  5. Replies: 2
    Last Post: 07-08-2013, 11:43 AM
