Results 1 to 9 of 9
Thread: Steel Tank Institue Docs / API 341
    Here is the original STI SP001...
    STI SP001-00 STANDARD FOR INSPECTION OF IN-SERVICE SHOP FABRICATED ABOVEGROUND TANKS FOR STORAGE OF COMBUSTIBLE AND FLAMMABLE LIQUIDS.pdf 1.727 MB
    I need current STI docs older ones will help also
    SP001 Standard for The Inspection of Aboveground Storage Tanks, 4th Edition
    SP031 - Standard for Repair of Shop Fabricated Aboveground Tanks for Storage of Combustible & Flammable Liquids, 4th Edition
    Standard for Tanks Storing DEF - F091
    Also I need...
    API Publication 341, A Survey of Diked-area Liner Use at Aboveground Storage Tank Facilities
    and
    API Recommended Bulletin D16, Suggested Procedure for Development of a Spill Prevention Control
    and Countermeasure Plan
    Thanks very much for sharing
  4. Thanks for sharing !
    Quote Originally Posted by Nabilia View Post
    Also I need...
    and
    SP001 Standard for The Inspection of Aboveground Storage Tanks, ( 4th Edition July 2006)
    STORAGE TANK MANAGEMENT MANUAL ATTACHMENTS PUBLICATION 694A
    This file contains only a few pictures and brief information about SP001 and SP031.
    I found the first SP031..
    STI SP031 - STANDARD FOR REPAIR OF SHOP FABRICATED ABOVEGROUND TANKS FOR STORAGE OF COMBUSTIBLE AND FLAMMABLE LIQUIDS Final Draft April 2008.pdf 1.194 MB
    and the 3rd SP001
    STI SP001-03 - STANDARD FOR INSPECTION OF IN-SERVICE SHOP FABRICATED ABOVEGROUND TANKS FOR STORAGE OF COMBUSTIBLE AND FLAMMABLE LIQUIDS.pdf 0.234 MB
    and the 3rd SP001
    Ok .. I thought you needed: SP001 Standard for The Inspection of Aboveground Storage Tanks, ( 4th Edition July 2006)
    Just thought I'd help.
    Yes, Mr Welder you helped me greatly, I was trying to track the changes in the STI standard, I had heard that they originally allowed a 653 to do their inspections but changed in the 4th edition to require an Adjunct Certification to inspect small tanks according to their code.
    The direction to the Pennsylvania site was helpful also, they have a lot of info on their site.
    I am still looking for a newer sp031 and the API 341 and D16 as they are referenced in the sp001
    I am looking to API 341 and API D16. As soon as I to obtain share with you.
  11. Thanks everybody for your kind sharing. Very useful!
  1. The Aboveground Steel Storage Tank Handbook
    By Nabilia in forum Oil And Gas Process
    Last Post: 02-27-2019, 04:19 PM
  2. The Aboveground Steel Storage Tank Handbook
    By 5161440 in forum Mechanical Engineering
    Last Post: 02-22-2019, 07:31 PM
  3. Looking for Steel Tank Institute documents...
    By Chinaman in forum Mechanical Engineering
    Last Post: 04-14-2017, 06:27 PM
  4. Bolted Steel Tank design calculations
    By abhussain in forum Mechanical Engineering
    Last Post: 07-13-2014, 03:23 PM
  5. The Aboveground Steel Storage Tank Handbook
    By Azad in forum Petroleum Refining
    Last Post: 12-10-2012, 07:10 PM
