Page 1 of 3 1 2 3 LastLast
Results 1 to 12 of 29
Thread: Aspen Engineering Suite 2004
    Aes 2004
    AES 2004
    New links inside archive for passwords check 'Info' or 'Comment' in archive...
    Don't suggest the file name...
    For open use WinRar...
    Good luck...
    very thanks , i hope that i can download it before it delete
  4. Thanks .
    Hi Mr. Mohamed and whom may help,
    Can anybody tell me the difference between AES 2004, AES 2006, AES 2006.5, AES v.11.1 and AES v.12 and even AES v.7?
    I see around other concepts of Aspentech as AspentechONE, Aspentech Plus and Aspentech Hysis and even Aspentech Hysis Dynamic.
    So which is the most covering the others? which items needed to download to cover all above concepts mentioned?
    Appreciate much your clear reply
  6. Dear Mr Ooromo
    I have downloaded this software, very thanks to You.
    But when I tried to install Aspen ProFES, the file is corrupt. Would You send me the program setup folder which contain only Aspen ProFES, or are there any comment from You?
  8. Dear Mr Ooromo
    @ wmpstl
    I tested this software on VirtualBox and installed Aspen ProFES from this ISO and works fine!
    Maybe this help you?
    Code:
    # MD5 checksums generated by MD5summer (
    And for all files:
    Code:
  10. is it possible if you upload it in other file sharing websites other than rapidshare, like mediafire? i always have problem downloading from rapidshare. thanks!
  11. #9
    Quote Originally Posted by Omnivon View Post
    I do not have such possibility unfortunately.
  12. It is better to download Aspen Suite by ******* then over rapidshare.
    I try it over rapidshere with adresses that I found here. No work.
    Now, i am seeding Aspen Suite 2006 which works.
    So, maybe it is better to try it over *******.
  13. i've tried ******* before but to no avail. i need version 2004 specifically and there are no seeders for the 2004 version
  14.    Spons.
  15. Quote Originally Posted by Omnivon View Post
    try version 2006
