Page 1 of 33 1 2 3 11 ... LastLast
Results 1 to 12 of 389
Thread: API standards
    API standards
    API amirican petroleum institute
    API 06AM 2nd ed 09 95 Material Toughness
    API 006D Pipeline Valves
    API 510 8th Ed Incl Add3 Dec 2001 Pres Vessel Inspection Code
    API 526 flanged steel pressure Relief valves
    API 527 for seat tightness of pressure relife valves
    API 560 3rd Ed May 2001 Fired Heaters for general Refinery Services
    API 594 Check Valves 5th ed 1997
    API 598 7th ED Oct 1996 Valve Inspection and Testing
    API 610 8th Ed, Aug 1995 Cent Pumps
    API 611 4th Ed, Jun 1997 Steam Turb
    API 612 4th Ed, Jun 1995 Spec Purp Steam Turb
    API 613 4th Ed, Jun 1995 Spec Purp Gear Units
    API 614 4th Ed, Apr 1999 Lub, Shaft Seal, Control Oil Sys and aux
    API 616 4th Ed, Aus 1998 Gas Turbines
    API 617 6th Ed, Feb 1995 Centrifugal Compressors
    API 618 4th Ed, Jun 1995 Recip Compressors
    API 619 3rd Ed, Jun 1997 Pos Disp Compressor
    API 620 10th ed Feb 02 Design and Construction of Large Welded LP Storage Tanks
    API 650 Welded Tanks for Oil Storage 10th Ed Add1 Mar 2000
    API 653 3rd Ed Dec 01 Tank Insp Repair Alteration and Reconstruction
    API 660 Feb 2001 6th Ed Shell and Tube Heat Exchangers
    API 661 Nov 1997 4th ed Air Cooled Heat Exchangers
    API 670 4th Ed Dec 2000 Machinery Prot Sys
    API 530 4th ed Ocy 1996 Calc of Heater Tube Thickness
    API 671 3rd Ed Oct 1998 Spec Purp Couplings
    API 672 3rd Ed Sep 1996 Integ Geared Centrif Air Comp
    API 674 2nd Ed Jun 1995 Pos Disp Pumps
    API 675 2nd Ed Oct 1994 Pos Disp Pumps Controlled Vol
    API 677 2nd Ed Jul 1997 Gear Units
    API 681 1st Ed Feb 1996 Liq Ring Vac Pumps and Compressors
    API 682 1st Ed Oct 1994 Shaft Sealing Sys for Cent and Rotary Pumps
    API 683 1st Ed Sep 1993 Quality Improvement Manual for Mech Equipment
    API 2510 8th Ed May 2001 Design and Construction od LPG Facilities
    API 2510a 2nd Ed May 2001 Fire Protection of LPG FacilitiesAPI
    API PUB 534 1st Ed Jan 95 Heat Recovery Steam Generators
    API PUB 684 1st Ed Feb 1996 Rotoro Dynamics and Balancing
    API PUB 760 2nd Ed Jun 1998 Model Risk Management Plan
    API Pub 938 May 1996 1 1 4 Cr 1 2 Mo ***** Repairs
    API Pub 959 May 1982 Temper Embrittlement of Cr Mo Steels
    API RP 500 2nd Ed 1997 Area Classification
    API RP 505 1st Ed 1997 Area Classification
    API RP 521 4th Ed Mar 97 Guide for Pres Rel and Depres Sys
    API RP 540 4th Ed Apr 99 Electrical Inst
    API RP 572 Management of Hazards Associated with Location of Process PLants and Buildings
    API RP 573 1st Ed Oct 91 Inspection of Fired Boilers and Heaters
    API RP 574 2nd Ed Jun 98 Inspection Practices for Piping System Components
    API RP 576 2nd Ed Dec 00 Inspection of Pressure Relieving devices
    API RP 579 1st Ed Mar 00 Fitness for Service
    API RP 686 1st Ed Apr 1996 Machinery Inst Guide
    API RP 934 1st Ed Dec 2000
    API RP 945 2nd Ed Oct 97 Avoiding Environment *****ing In Amine Units
    API RP 1104 19tht Ed Oct 01 Welding of pipelines and related facilities
    API RP 2028 3rd Ed Feb 02 Flame Arrestors in Piping Systems
    API 579 1st Ed Revised Mar 2000 Fitness for service 1 - 100
    API RP 2350 2nd Ed 1996 Overfill Prot For Storage Tanks
    [link Point to another website Only the registered members can access] ___
  2. Thank you
    Thank You
    Please I need books and materials on Riser Engineering.
  6. pls re upload those file ,because all of them are dead link.
    Thx alot
    Dear Mr. Muhammad Elhagar
    Very nice collection but unfortunately links are dead so kindly reupload the files.
    If possible load in few zip files instead of so many individual files.
    Thanks in advance.
  9. Yes all links are deleted. Pls reupload the links. these are very good documents for engineering industry. thanks in adv.
  10. Please upload API650 API620 again...
  11. #9
    http://rapidshare.com/files/68145138...rators__1_.pdf
    please reupload this link i need it
    iam doing design of 2 and 3 separator design please help me
  12. #10
    Dear sudharshanan,
    dear i hav al stds(including ASME,ASTM etc ) in pdf,but the folder size is near 1.5 GB so it is not possible for me to send them all.therefore u hav to specify which standards do u require so that i can easly mail to u....
  13. naeem_engr: Could u pl. upload the following (@mihd.net or ifile or 4share)
  14.    Spons.
  15. I need API RP 580 Risk Base Inspection please kindly upload them.
  1. API standards
    By ayoubhk in forum Safety And Environment
    Last Post: 12-15-2014, 02:29 AM
  2. ISA standards
    By kaicyem in forum Instrumentation & Control
    Last Post: 06-21-2014, 12:26 AM
  3. BS/DIN/EN - STANDARDS FOR P&ID's
    By ceeee83 in forum Engineering Certificates
    Last Post: 04-27-2013, 08:10 AM
  4. Need the following IEC standards
    By SA_FETY in forum Safety And Environment
    Last Post: 12-09-2011, 05:11 AM
  5. IEC Standards
    By sunset_eagle in forum Electrical & Power Engineering
    Last Post: 10-25-2010, 08:52 PM
