Thread: How to write the Report for the Repair Work - Heat Exchanger
  1. How to write the Report for the Repair Work - Heat Exchanger
    Dear Friend,
    I again need some help. Recently i had repaired one Heat Exchanger ( Air Cooler Type). We found a problem caused by the Thermal Expansion or vibration of the tubes causing the damage of the Tube- Tubesheet weld get worn out and the Tube material has been lost about few mm at the end portion. Finally we had Plugged the tubes to avoid the problem. I have asked to write a report for this work. i do not know whether their is any format or form as per ASME or NBIC, Our company has U, S, & R Stamp.
    So my dear Friends, Please help me in this problem, also if some one had any sample please give to me also. Also please suggest any other method of repairing the tubes.
    Thanks to everyone.
    friends can you please send me the book to the next email mahendrapal.rathore@gmail.com or mahendrapal.rathore@ril.com.
    i will remaining thank full to you for your support.
    kind regards;
    mahendra
    Re: How to write the Report for the Repair Work - Heat Exchanger
    is there a standard procedure format to carry out a repair work on a shell & tube exchanger?
  1. Replies: 3
    Last Post: 06-07-2017, 03:26 PM
  2. Replies: 11
    Last Post: 08-08-2016, 11:07 AM
  3. Heat Exchanger repair handbook
    By Thaksen79 in forum Mechanical Engineering
    Last Post: 12-11-2013, 10:04 PM
  4. Replies: 0
    Last Post: 12-03-2011, 09:17 PM
  5. Heat Exchanger Tubeside Repair by Plugging
    By daveodc in forum Mechanical Engineering
    Last Post: 01-27-2011, 01:21 PM
