Results 1 to 7 of 7
Thread: Can anybody post how to design reactive distillation
  1. Can anybody post how to design reactive distillation
    Hi Friends,
    Will you please help me to design the reactive distillation column for any reaction.
  2. This book can solve all of your problem regarding reactive distillation
    Reactive Distillation Design and Control by WILLIAM L. LUYBEN and CHENG-CHING YU
    Nov 2008
    Bronx, New York, United States
    Re: Can anybody post how to design reactive distillation
    title:Modelling and Simulation of ethyl
    acetate reactive distillation column
    using ASPEN PLUS
    aspenplus models
    1. Agrawal, Ankit Kumar (2012) Effect on naphtha yield, overall conversion and coke yield through different operating variables in FCC unit using Aspen-Hysys simulator. BTech thesis. file
    2. Bose, Arunim (2012) Simulation of air liquefaction using aspen plus. BTech thesis. file
    3. Panda, Chittaranjan (2012) Aspen plus simulation and experimental studies on biomass gasification. BTech thesis. file
    4. Sourav, Sagar (2012) Production of hydrogen enriched SYN-gas by absorption method. BTech thesis. file
    5. Dalai, Abhijit (2012) Nitrogen and helium liquefier design and simulation using aspen plus. BTech thesis. file
    6. Kaushik, Vishal (2011) Dynamics and Control of Distillation using Aspen. BTech thesis. file
    7. Sahoo, Prasanna Kumar (2011) Production of ethylbenzene by liquid-phase benzene alkylation. BTech thesis. file
    8. Sahu, Mohit Mohan (2011) Simulation of process parameters and bed-hydrodynamic studies for fluidized bed biomass gasification using aspen plus. BTech thesis. file
    9. Tewari, Krishna (2011) Design of Cumene Plant using Aspen Plus. BTech thesis. file
    10. Mahapatra, N (2010) Design and Simulation of Cumene Plant using Aspen Plus. BTech thesis.
    1. Bal, Kalinga Simant (2012) Performance appraisal of cryo‐treated tool by turning operation. MTech thesis. file
    2. Sutradhar, Bidyut Bikash (2012) Evaluation of bond between bituminous pavement layers. MTech thesis. file
    3. Shrivastava, Vinay (2012) Design and development of downdraft gasifier for operating CI engine on dual fuel mode. MTech thesis. file
    4. Agrawal, Ankit Kumar (2012) Effect on naphtha yield, overall conversion and coke yield through different operating variables in FCC unit using Aspen-Hysys simulator. BTech thesis. file
    5. Biswal, Bijayani (2012) Recovery of liquid fuels from cellulosic feedstock. BTech thesis. file
    6. Sinha, Rahul (2012) Recovery of liquid fuels from oil bearing seed. BTech thesis. file
    7. Mohanty, Maithili (2012) Performance based characterisation of bituminous binders. BTech thesis. file
    8. Mohanty, Rashmi Prava (2012) Fabrication and Characterization of Metal Organic
    Framework (MOF) Based Membrane. BTech thesis. file
    9. Das, Sukalyan and Rout, Satyajit (2012) Assessment of Water Quality Around Mine Sites. BTech thesis. file
    10. Nayak, Monalisha (2012) Design and simulation of a multiple-effect evaporator using vapor bleeding. BTech thesis. file
    11. Sahoo, Rashmi Rekha (2012) Antioxidant &antimicrobial efficacy of Ficus religiosa L. & Ficus benghalensis L. PLANT. MSc thesis. file
    12. Bose, Arunim (2012) Simulation of air liquefaction using aspen plus. BTech thesis. file
    13. Mishra, Manisha (2012) Analysis of dioxygenase gene in marine bacteria involved in polycyclic aromatic hydrocarbon degradation. MSc thesis. file
    14. Sourav, Sagar (2012) Production of hydrogen enriched SYN-gas by absorption method. BTech thesis. file
    15. Biswal, Chitta Ranjan and Seth, Madhabi (2012) Effect of solvent in azo-hydrazone tautomerism of 1 phenylazo-2-naphthol (Sudan I). MSc thesis. file
    16. Das, Kreeti (2012) Process Fault Analysis using Digraph Method. BTech thesis. file
    17. Vikash, Kumar (2012) Synthesis of Dibenzyl Thioether using H2S and Anion Exchange Resin as Triphase Catalyst. BTech thesis. file
    18. Nayan, Niraj Kumar (2011) Experimental studies on extraction of valuable fuels from karanja and neem seed by pyrolysis. BTech thesis. file
    19. Sahoo, Biranchi Narayan (2011) Effect of Cryogenic Treatment of Cemented Carbide Inserts on Properties & Performance Evaluation in Machining of Stainless Steel. MTech thesis. file
    21. Khare, P K (2011) Treatment of Phenolic Water Using Adsorption. MTech thesis. file
    22. Jaiswal, Abhash (2011) Effect of hydrogen induction on co mbustion, performance and emission behaviour of compression ignition engine using used transformer oil as a main fuel. MTech thesis. file
    23. Volli, Vikranth (2011) Recovery of bio-fuels from agricultural residues. MTech thesis. file
    24. Damarla, Seshu Kumar (2011) Multivariate Statistical Process Monitoring and Control. MTech thesis. file
    25. Saleh, Abdullah (2011) Study Of The Performance Of Batch Distillation Using gPROMS. BTech thesis. file
    26. Agrawalla, Ankit (2011) Thermal Pyrolysis of Groundnut De-Oiled Cake and Characterization of Bio-Oil Produced. BTech thesis. file
    27. Kaushik, Vishal (2011) Dynamics and Control of Distillation using Aspen. BTech thesis. file
    28. Mohanty, Chiranjiv (2011) Experimental investigation of the combustion, performance and emission parameters of a compression ignition engine using blends of vegetable oil and diesel fuel. BTech thesis. Item availablity restricted. file
    29. Rath, Saswat (2011) Performance & Emission Analysis of blends of Karanja Methyl Ester in a Compression Ignition Engine. BTech thesis. file
    30. Sahoo, Prasanna Kumar (2011) Production of ethylbenzene by liquid-phase benzene alkylation. BTech thesis. file
    31. Sahoo, Swati (2011) Study of Capillary Filling Dynamics in a Microtube. BTech thesis. file
    32. Bantraj, Kandi (2011) Studies on adsorption isotherms and heats of adsorption of CH4 on microporous and mesoporous adsorbents. BTech thesis. file
    33. Rath, Deepali (2011) Development of a gasifier for fueling of a diesel engine. BTech thesis. file
    34. S, Dinesh (2011) Development and Characterization Of Pellet Activated Carbon from New Precursor. BTech thesis. file
    35. Tewari, Krishna (2011) Design of Cumene Plant using Aspen Plus. BTech thesis. file
    36. Chidambaram, Allada (2011) CFD Analysis of Phase Holdup Behaviour in a Three Phase Fluidized Bed. BTech thesis. file
    37. Giri, Sindhushree (2011) Isolation and biochemical characterization of mercury resistant bacteria (MRB) from soil samples of industrially contaminated area of Rourkela, Orissa. MSc thesis. file
    38. S R, Shubham (2011) Wastewater minimization using aspen water. BTech thesis. file
    39. Samal, Amit (2011) Simultaneous Fermentation and separation using
    Pervaporation Technique of Acetone-Butanol-Ethanol Fermentation: A Mathematical Approach. BTech thesis. file
    40. Swain, Manisha (2011) Study of Capillary Filling Dynamics in a Microchannel. BTech thesis. file
    20. Chandrakar, Gaurav (2011) Studies on Improvement of Surface Characteristics and Stability of Cr, Cu and Zn Based Metal Organic Frameworks (MOFs). MTech thesis. file
    41. Rangarajan, Raghuraman (2011) Design and Simulation of a Multiple Effect Evaporator System. BTech thesis. file
    42. Alam, Rukhsar (2011) Studies on the properties of Karanja oil for probable industrial application. MSc thesis. file
    43. Mohapatra, Swapna Sarita (2011) Iron/Copper Co-Catalyzed C-C Cross-Coupling Reaction. MSc thesis. file
    44. Sahu, Ramesh Chandra (2011) Neutralization of Red Mud Using CO2 Sequestration and their Utilizations. PhD thesis. Item availablity restricted. file
    45. Kaushikaram, K S (2010) Partial Least Squares and Neural Network Based Identification of Process Dynamics & Design of Neural Controllers. BTech thesis. file
    46. Behera, Managobinda (2010) Vapour Liquid Equillibrium Modeling Using UNIFAC Group Contribution Method And Its Application In Distillation Column Design And Steady State Simulation. BTech thesis. file
    47. Kumar, S (2010) Modelling and Simulation of Ethyl Acetate Reactive Distillation Column using ASPEN PLUS. BTech thesis. file
    48. Mondal, Abhishek (2010) Preparation of CaO-SiO2-P2O5 glass by Sol-gel route. BTech thesis. file
    49. Mahapatra, N (2010) Design and Simulation of Cumene Plant using Aspen Plus. BTech thesis. file
    50. K, S Kumar (2010) Extraction of Essential Oil Using Steam Distillation. BTech thesis. file
    51. Mehra, Vaibhav Kumar (2010) Salt effect on Vapourliquid equilibrium for the binary system methanol +ethyl acetate. BTech thesis. file
    52. Padhi, Saroj Kumar (2010) Preparation and Characterization of Biodiesel from Non-Edible Oils. PhD thesis. file
    53. Javaji, S K (2009) Study of Dynamic Behavior of Ethyl Acetate Reactive Distillation Column Using ASPEN PLUS. BTech thesis. file
    54. Kumar, Chandranan (2009) Counter Current Flow Phenomenon & Pressure Drop Calculation in Annular Geometry. MTech thesis. file
  1. distillation column design
    By Bharath in forum Engineering Spreadsheets & Presentations
    Last Post: 09-04-2024, 07:27 PM
  2. distillation column design
    By Bharath in forum Oil And Gas Process
    Last Post: 12-28-2011, 05:44 PM
  3. Distillation Design
    By himanshu in forum Mechanical Engineering
    Last Post: 02-02-2010, 06:47 AM
  4. Reactive Distillation Design and Control
    By mkhurram79 in forum Petroleum Refining
    Last Post: 10-03-2009, 10:50 AM
