Thread: gas volume shrinkage due to liquids extraction
  1. gas volume shrinkage due to liquids extraction
    Dears,
    I am working on a gas exploration prospect, about 120bcf (recoverable) CGR of about 100, and pressures in the range of 3500 psi.
    For the sake of sales gas calculations what sort of gas volume shrinkage due to liquids extraction should I assume.
    Is there a thumb rule to this.
    Can anyone help please?
    No PVT available!
    VJsin
    Nov 2008
    Australia
    I'm unaware of any widely accepted rule of thumb, which is why when I went through a similar exercise I ended up fitting some rough relationships myself - but they were for a gas under almost twice the pressure and with less than half the CGR, so please use caution in applying to your situation
    Gas Shrinkage was ~0.08% per bbl/mmcf of condensate (ie in your case CGR of 100 bbl/mmcf, would result in 8% shrinkage of the wet gas)
    CGR reduced from initial value to 25% of the initial value, linearly with fraction of EUR produced (ie in your case, CGR would start at 100, and reduce to 25 over the life of the asset linearly with cum production)
    Hope this helps
  4. Dear Vino,
    Thanks, most helpful.
  1. The Technology of Artificial Lift Methods volume Volume 3
    By sami22 in forum Oil And Gas Production
    Last Post: 03-11-2019, 11:50 AM
  2. gas evolving from oil shrinkage
    By raaj13feb in forum Reservoir
    Last Post: 08-01-2013, 09:06 AM
  3. Replies: 0
    Last Post: 02-16-2012, 11:42 AM
  4. How to calculate shrinkage factor manually ?
    By uttarasachin in forum Oil And Gas Production
    Last Post: 07-05-2010, 08:09 AM
  5. shrinkage factor calculation
    By uttarasachin in forum Oil And Gas Process
    Last Post: 10-18-2009, 09:13 PM
