Thread: Volumetric OIP Calculations
    Sep 2007
    Alexandria, Egypt, Egypt
    Hello everybody, i have a question about calculating oip whether using "net pay map" or "gross rock volume" method, which is more accurate and should the results from these method be different ?
    Re: Volumetric OIP Calculations
    Hey, you should use the net pay thickness for those calculations. This does not mean you cant use gross volumes, it means you would need a NTG map to use along the gross volume. If you used the net pay map, then you would not require a NTG map because its already accounted for.
  1. Replies: 215
    Last Post: 08-10-2018, 06:00 AM
  2. Volumetric calculations of OOIP
    By amahaminer in forum Reservoir
    Last Post: 01-19-2016, 11:33 AM
  3. Volumetric Reservoirs
    By Ahmed Essam Tawfik in forum Reservoir
    Last Post: 07-16-2014, 02:52 PM
  4. Piping Calculations Manual (Mcgraw-Hill Calculations) by SShashi
    By rioca57 in forum Pipeline And Fluid Flow
    Last Post: 11-19-2013, 09:01 PM
