Hi All,
Anyone have set of questions which usually used to ask during interview for Static Equipment design engineer?
Please share for me..
Praphulla
praphulla.dp@gmail.com
Hi All,
Praphulla
Hi Praphulla Madam,
Did you get the questionaire? please supply me the same. iam starting my career in this field, so it will be helpful for me.
Please help me.
my phone: 9902200050 & krishnakmk@rediffmail.com
thank you.
Hi everybody,
You can see same topic at the side bar of this site. You can find out some thing same your questions or use search box or this site.
Apart from that, you also can ref more resources at:[link Point to another website Only the registered members can access]
Best rgs
i too required it
Please can any one send me static equipment design interview questions on my mail (equbalkhan72@gmail.com). I have been working in the same field for last 2 yrs and now looking to switch. I haven't appreared for such interwiew before .
I suppose it's different from company to company so it's very hard for anyone to tell you the right answer cause true answer probably not exist.. but always it depends; if you have experience in your scope, your earlier experience and knowledge will play the major role in whole thing...if you're just fresh from the college - then it's another story..
anyway, good luck![]()
i too required it. u can give pv and heatexchangers questionare because it is common.
Some questions which i face during interview,
1) What is diff betn code and standard?
2) How many codes are used when u design a PV.?
3) How do u decide max pad size for a large nozzle??
4) As per theory hoop stress is PD/2t but ASME section 8 Div 1 uses not same equation. why?
5) Do you use section 2 ever? if yes then when do we use it?
6) what is MDMT? how Value of MDMT is useful to designer/fabricator?
7) what is PWHT? when to apply it? and by which clause?
8) which material's do till date used to make PV?
9) what is diff betn SA 516 gr 65 & gr 70? what is diff betn SA 515 & SA 516?
10) Do u use SA-36 for Dish head ? if yes is there any other special requirement for use it??
11) What is Max size of dish head do u fabricate?? what is finished thickness and design thickness??
12) Which clause do u use for nozzle area calculation? explain its general logic.
13) How do u calculate welding strength/stress?
14) How do u decide crown radius and knuckle radius for dish heads?
and then another questions on PVelite software's bugs and limitations....
