Page 1 of 3 1 2 3 LastLast
Results 1 to 12 of 28
    IEC standards compilation
    IEC 60027 Letter symbols to be used in electrical technology
    IEC 60028 International standard of resistance for copper
    IEC 60034 Rotating electrical machinery
    IEC 60038 IEC Standard Voltages
    IEC 60041 Field acceptance tests to determine the hydraulic performance of hydraulic turbines* storage pumps and pump-turbines
    IEC 60044 Instrument transformers
    IEC 60045 Steam turbines
    IEC 60050 International Electrotechnical Vocabulary
    IEC 60051 Recommendation for direct acting indicating analogue electric measuring instruments and their accessories
    IEC 60055 Paper-insulated metal-sheathed cables for rated voltages up to 18/30 kV
    IEC 60060 High-voltage test techniques
    IEC 60062 Marking codes for resistors and capacitors
    IEC 60063 Preferred number series for resistors and capacitors
    IEC 60061 Lamp caps and holders together with gauges for the control of interchangeability and safety
    IEC 60064 Tungsten filament type GLS (General Lighting Solutions) bulbs
    IEC 60065 Audio* video and similar electronic apparatus – Safety requirements
    IEC 60068 Environmental Testing
    IEC 60071 Insulation Co-ordination
    IEC 60073 Basic Safety principles for man-machine interface* marking and identification - coding principles for indicators and actuators
    IEC 60076 Power transformers
    IEC 60077 Railway applications - Electric equipment for rolling stock
    IEC 60079 Explosive Atmospheres
    IEC 60083 Plugs and socket-outlets for domestic and similar general use standardized in member countries of IEC
    IEC 60085 Electrical insulation
    IEC 60086 Primary batteries
    IEC 60092 Electrical installations on ships
    IEC 60094 Magnetic tape sound recording and reproducing systems
    IEC 60095 Lead-acid starter batteries
    IEC 60096 Radio-frequency cables
    IEC 60098 Rumble measurement on Vinyl Disc Turntables
    IEC 60099 Surge arresters
    IEC 60119 The Electrical Performance of Semiconductor Rectifiers (Metal Rectifiers)
    IEC 60134 Absolute maximum and design ratings of tube and semiconductor devices
    IEC 60137 Bushings for alternating voltages above 1000V
    IEC 60146 Semiconductor Converters
    IEC 60156 Dielectric Strength
    IEC 60169 Radio-frequency connectors
    IEC 60183 Guide to the selection of high voltage cables
    IEC 60193 Hydraulic turbines* storage pumps and pump-turbines - Model acceptance tests
    IEC 60204 Safety of machinery
    IEC 60214 On-load tap changers
    IEC 60228 Conductors of insulated cables
    IEC 60233 Tests on Hollow Insulators for use in Electrical Equipment
    IEC 60238 Edison screw Lampholders
    IEC 60239 Graphite electrodes for electric arc furnaces – Dimensions and designation
    IEC 60245 Rubber-Insulated Cables
    IEC 60254 Lead-acid traction batteries
    IEC 60255 Electrical Relays
    IEC 60268 Sound system equipment
    IEC 60269 Low voltage fuses
    IEC 60270 High-Voltage Test Techniques – Partial Discharge Measurements
    IEC 60273 Characteristics of indoor and outdoor post insulators for systems with nominal voltages greater than 1000V
    IEC 60287 Calculation of permissible current in cables at steady state rating
    IEC 60296 Mineral Insulating oils for transformers & switchgear
    IEC 60297 Dimensions of mechanical structures of the 482.6 mm (19 in) series
    IEC 60298 high voltage switchgear in metallic enclosure
    IEC 60308 Hydraulic turbines - Testing of control systems
    IEC 60309 Plugs* socket-outlets and couplers for industrial purposes
    IEC 60317 Specifications for particular types of winding wires
    IEC 60320 Appliance couplers for household and similar general purposes
    IEC 60331 Tests for Electric Cables under Fire Conditions
    IEC 60332 Flame Retardant vs Fire Rate Cables
    IEC 60335 Safety of electrical household appliances
    IEC 60364 Electrical installations of buildings
    IEC 60397 Test methods for batch furnaces with metallic heating resistors
    IEC 60398 Installations for electroheating and electromagnetic processing - General test methods
    IEC 60417 Graphical symbols for use on equipment
    IEC 60439 Low voltage switchgear and controlgear assemblies
    IEC 60445 Basic and safety principles for man-machine interface
    IEC 60446 Wiring colours
    IEC 60457 Method of sampling insulating liquids
    IEC 60479 Effects of current on human beings and livestock
    IEC 60502 Power cables with extruded insulation and their accessories for rated voltages from 1kV up to 30kV
    IEC 60519 Safety in installations for electroheating and electromagnetic processing
    IEC 60529 Degrees of protection provided by enclosures (IP Code)
    IEC 60539 Directly heated negative temperature coefficient thermistors
    IEC 60545 Guide for commissioning* operation and maintenance of hydraulic turbines
    IEC 60546 Controllers with analogue signals for use in industrial-process control systems
    IEC 60571 Electronic equipment used on rail vehicles
    IEC 60574 Audio-visual* video and television equipment and systems
    IEC 60598 Luminaires
    IEC 60559 Binary floating-point arithmetic for microprocessor systems
    IEC 60601 Medical Electrical Equipment
    IEC 60603 Connectors for frequencies below 3 MHz for use with printed boards
    IEC 60609 Hydraulic turbines* storage pumps and pump-turbines - Cavitation pitting evaluation
    IEC 60617 Graphical symbols for diagrams
    IEC 60651 Sound level meters
    IEC 60662 High-pressure sodium lamp - Performance specifications
    IEC 60664 Insulation coordination for equipment within low-voltage systems
    IEC 60669 Switches for household and similar fixed-electrical installations
    IEC 60676 Industrial electroheating equipment - Test methods for direct arc furnaces
    IEC 60680 Test methods of plasma equipment for electroheat and electrochemical applications
    IEC 60683 Test methods for submerged arc furnaces
    IEC 60688 Electrical measuring transducers for converting AC electrical quantities to analogue or digital signals
    IEC 60694 Common Specifications For High-Voltage Switchgear and Controlgear Standards
    IEC 60703 Test methods for electroheating installations with electron guns
    IEC 60708 Low-frequency cables with polyolefin insulation and moisture barrier polyolefin sheath
    IEC 60715 Dimensions of low-voltage switchgear and controlgear. Standardised mounting on rails for mechanical support of electrical devices in switchgear and controlgear installations.
    IEC 60721 Classification of environmental conditions
    IEC 60726 Dry type power transformers
    IEC 60728 Cable networks for television signals* sound signals and interactive services
    IEC 60730 Class B certification requirements for appliances.
    IEC 60747 Semiconductor devices; Part 1: General
    IEC 60748 Semiconductor devices – integrated circuits
    IEC 60760 Flat* quick-connect terminations (merged into IEC 61210:2010-08)
    IEC 60774 VHS/S-VHS video tape cassette system
    IEC 60793 Optical fibres
    IEC 60779 Test methods for electroslag remelting furnaces
    IEC 60801 EMI and RFI Immunity
    IEC 60805 Guide for commissioning* operation and maintenance of storage pumps and of pump-turbines operating as pumps
    IEC 60809 Filament lamps for road vehicles - Dimensional* electrical and luminous requirements
    IEC 60811 Common test methods for insulating and sheathing materials of electric cables and optical cables
    IEC 60812 International Standard on Fault Mode and Effects Analysis
    IEC 60815 Selection and dimensioning of high-voltage insulators intended for use in polluted conditions
    IEC 60825 Laser safety
    IEC 60826 Design criteria of overhead transmission lines
    IEC 60849 Sound Systems for Emergency Purposes
    IEC 60865 Short Circuit Current: Calculation of Effects
    IEC 60870 Telecontrol equipment and systems
    IEC 60874 Connectors for optical fibres
    IEC 60884 Plugs and socket-outlets for household and similar purposes
    IEC 60898 Electrical accessories. Circuit breakers for overcurrent protection for household and similar installations.
    IEC 60904 Photovoltaic Devices (Part 1-10).
    IEC 60906 IEC system of plugs and socket-outlets for household and similar purposes
    IEC 60908 Compact disk digital audio system
    IEC 60909 Short-circuit currents in three-phase a.c. systems - Part 0: Calculation of currents
    IEC 60921 Ballasts for tubular fluorescent lamps – Performance requirements
    IEC 60929 AC-supplied electronic ballasts for tubular fluorescent lamps – Performance requirements
    IEC 60939 Passive filter units for electromagnetic interference suppression
    IEC 60942 Electroacoustics – Sound calibrators
    IEC 60945 Maritime Navigation and Radiocommunication Equipment and Systems – General Requirements – Methods of Testing and Required Test Results
    IEC 60947 Standards for low-voltage switchgear and controlgear
    IEC 60950 Safety of information technology equipment
    IEC 60958 Digital Audio Interface
    IEC 60994 Guide for field measurement of vibrations and pulsations in hydraulic machines (turbines* storage pumps and pump-turbines)
    IEC 61000 Electromagnetic compatibility (EMC)
    IEC 61008 Residual current operated circuit-breakers without integral overcurrent protection for household and similar uses (RCCBs)
    IEC 61009 Residual current operated circuit breakers with integral overcurrent protection for household and similar uses (RCBO's)
    IEC 61010 Safety requirements for electrical equipment for measurement* control and laboratory use
    IEC 61024 Protection of structures against lightning
    IEC 61025 Fault tree analysis]]
    IEC 61030 Domestic Digital Bus - a standard for a low-speed multi-master serial communication bus for home automation applications.
    IEC 61043 Sound intensity meters with pairs of microphones
    IEC 61058 Switches for Appliances
    IEC 61084 Cable trunking and ducting systems for electrical installations
    IEC 61097 Global maritime distress and safety system (GMDSS)
    IEC 61116 Electromechanical equipment guide for small hydroelectric installations
    IEC 61131 Programmable Logic Controllers
    IEC 61140 Protection against electric shock – Common aspects for installation and equipment
    IEC 61149 Safety of mobile radios
    IEC 61156 Multicore and symmetrical pair/qud cables for digital communications
    IEC 61158 Industrial communication networks – Fieldbus specifications
    IEC 61162 Maritime navigation and radiocommunication equipment and systems* Digital Systems
    IEC 61164 Reliability growth – Statistical test and estimation methods
    IEC 61174 Maritime Navigation and Radio Communications* Electronic Chart Display and Information System (ECDIS)
    IEC 61194 Characteristic parameters of stand-alone photovoltaic (PV) systems
    IEC 61210 Connecting devices – Flat quick-connect terminations for electrical copper conductors – Safety requirements
    IEC 61211 Insulators of ceramic material or glass for overhead lines with a nominal voltage greater than 1 000 V - Impulse puncture testing in air
    IEC 61215 Crystalline silicon terrestrial photovoltaic (PV) modules – Design qualification and type approval
    IEC 61226 Nuclear power plants - Instrumentation and control important to safety - Classification of instrumentation and control functions
    IEC 61238 Compression and mechanical connectors for power cables for rated voltages up to 30 kV
    IEC 61241 Electrical apparatus for use in the presence of combustible dust
    IEC 61277 Terrestrial photovoltaic (PV) power generating systems – General and guide
    IEC 61280 Field testing method for measuring single mode fibre optic cable
    IEC 61286 Character set with electrotechnical symbols
    IEC 61307 Industrial microwave heating installations – Test methods for the determination of power output
    IEC 61308 High-frequency dielectric heating installations – Test methods for the determination of power output
    IEC 61326 Electrical equipment for measurement* control and laboratory use – EMC requirements
    IEC 61334 Distribution automation using distribution line carrier systems - a standard for low-speed reliable power line communications by electricity meters* water meters and SCADA 1
    IEC 61345 UV test for photovoltaic (PV) modules
    IEC 61346 Industrial systems* installations and equipment and industrial products – Structuring principles and reference designations
    IEC 61347 Lamp Controlgear
    IEC 61355 Classification and designation of documents for plants* systems and equipment
    IEC 61360 Common Data Dictionary
    IEC 61362 Guide to specification of hydraulic turbine control systems
    IEC 61363 Electrical installations of ships and mobile and fixed offshore units
    IEC 61364 Nomenclature for hydroelectric powerplant machinery
    IEC 61366 Hydraulic turbines* storage pumps and pump-turbines - Tendering Documents
    IEC 61378 Converter Transformers
    IEC 61400 Wind turbines
    IEC 61439 Low-Voltage switchgear and controlgear assemblies
    IEC 61467 Insulators for overhead lines - Insulator strings and sets for lines with a nominal voltage greater than 1 000 V - AC power arc tests
    IEC 61499 Function blocks
    IEC 61508 Functional safety of electrical/electronic/programmable electronic safety-related systems
    IEC 61511 Functional safety – safety instrumented systems for the process industry sector
    IEC 61513 Functional safety – safety instrumented systems for the Nuclear Industries
    IEC 61523 Delay and Power Calculation Standards
    IEC 61537 Cable management – Cable tray systems and cable ladder systems
    IEC 61554 Panel-Mounted equipment - Electrical measuring instruments - Dimensions for panel mounting
    IEC 61557 Equipment for measuring electrical safety in low-voltage distribution systems
    IEC 61558 Safety of power transformers* power supplies* reactors and similar products
    IEC 61588 Precision clock synchronization protocol for networked measurement and control systems
    IEC 61603 Infrared transmission of audio or video signals
    IEC 61642 Industrial a.c. Networks Affected by Harmonics – Application of Filters and Shunt Capacitors
    IEC 61643 Surge protective devices connected to low-voltage power distribution systems
    IEC 61646 Thin-film terrestrial photovoltaic (PV) modules – Design qualification and type approval
    IEC 61672 Electroacoustics – Sound level meters
    IEC 61683 Procedure to Measure Efficiency
    IEC 61690 Electronic design interchange format* EDIF
    IEC 61701 Salt mist corrosion testing of photovoltaic (PV) modules
    IEC 61723 Safety Guidelines for grid connected photovoltaic Systems mounted on the building
    IEC 61724 Photovoltaic system performance monitoring – Guidelines for measurement
    IEC 61727 Photovoltaic (PV) systems – Characteristics of the utility interface
    IEC 61730 Photovoltaic modules
    IEC 61753 Fibre optic interconnecting devices and passive components performance standard
    IEC 61784 Industrial communication networks – Profiles
    IEC 61800 Adjustable speed electrical power drive systems
    IEC 61803 Determination of power losses in high-voltage direct current (HVDC) converter stations
    IEC 61829 Crystalline silicon photovoltaic (PV) array – On-site measurement of I-V characteristics
    IEC 61846 Ultrasonics – Pressure pulse lithotripters – Characteristics of fields
    IEC 61850 Communication Networks and Systems in Substations
    IEC 61857 Electrical insulation systems
    IEC 61883 Consumer audio/video equipment - Digital interface
    IEC 61892 Mobile and fixed offshore units* electrical installations
    IEC 61922 High-frequency induction heating installations – Test methods for the determination of power output of the generator
    IEC 61966 Multimedia systems -- Colour measurement
    IEC 61968 Application integration at electric utilities – System interfaces for distribution management
    IEC 61970 Application integration at electric utilities – Energy management system application program interface (EMS-API)
    IEC 61984 Connectors - Safety requirements and tests
    IEC 61992 Railway applications - Fixed installations - DC switchgear
    IEC 61993 Maritime navigation and radiocommunication equipment and systems.
    IEC 62006 Hydraulic machines - Acceptance tests of small hydroelectric installations
    IEC 62014-4 IP-XACT - Standard Structure for Packaging* Integrating* and Reusing IP within Tool Flows
    IEC 62040 Uninterruptible power systems
    IEC 62041 EMC requirements for power transformers* power supplies* reactors and similar products
    IEC 62052 Electricity metering equipment (AC) General requirements* tests and test conditions
    IEC 62056 DLM/COSEM communication protocol for reading utility meters
    IEC 62061 Safety of machinery: Functional safety of electrical* electronic and programmable electronic control systems
    IEC 62076:2006* Industrial electroheating installations – Test methods for induction channel and induction crucible furnaces
    IEC 62087 Methods of measurement for the power consumption of audio* video and related equipment
    IEC 62097 Hydraulic machines* radial and axial - Performance conversion method from model to prototype
    IEC 62107 Super Video Compact Disc
    IEC 62108 Concentrator photovoltaic (CPV) modules and assemblies – Design qualification and type approval
    IEC 62138 Nuclear Power Plants - Instrumentation and control important for safety - Software aspects for computer-based systems performing category B or C functions
    IEC/TR 62157 Cylindrical machined carbon electrodes – Nominal dimensions
    IEC 62196 Plugs and sockets for charging electric vehicles
    IEC 62256 Hydraulic turbines* storage pumps and pump-turbines - Rehabilitation and performance improvement
    IEC 62262 Degrees of protection provided by enclosures for electrical equipment against external mechanical impacts (IK code)
    IEC 62264 Enterprise-control system integration
    IEC 62265 Advanced Library Format (ALF) describing Integrated Circuit (IC) technology* cells and blocks
    IEC 62270 Hydroelectric power plant automation – Guide for computer-based control
    IEC 62271 Standards for high-voltage switchgear and controlgear
    IEC 62278 Railway applications – Specification and demonstration of reliability* availability* maintainability and safety (RAMS)
    IEC 62282 Fuel cell technologies
    IEC 62301 Household electrical appliances – Measurement of standby power
    IEC 62304 Medical Device Software – Software Life Cycle Processes
    IEC 62305 Protection Against Lightning
    IEC 62325 Standards related to energy market models & communications
    IEC 62351 Power System Control and Associated Communications – Data and Communication Security
    IEC 62353 Medical electrical equipment - Recurrent test and test after repair of medical electrical equipment
    IEC/TR 62357 Power system control and associated communications - Reference architecture for object models* services and protocols
    IEC 62365 Digital audio – Digital input-output interfacing – Transmission of digital audio over asynchronous transfer mode (ATM) networks
    IEC 62366 Medical devices – Application of usability engineering to medical devices
    IEC 62379 Common control interface for networked digital audio and video products
    IEC 62386 Digital addressable lighting interface
    IEC 62388 Maritime Navigation and Radio Communications* Shipborne Radar
    IEC 62395 Electrical resistance trace heating systems for industrial and commercial applications
    IEC 62443 Industrial communication networks – Network and system security (DRAFT)
    IEC 62446 Grid connected photovoltaic systems – Minimum requirements for system documentation* commissioning tests and inspection
    IEC 62455 Internet protocol (IP) and transport stream (TS) based service access
    IEC 62464 Magnetic resonance equipment for medical imaging
    IEC 62471 Photobiological safety of lamps and lamp systems
    IEC 62474 Material declaration for products of and for the electrotechnical industry
    IEC 62481 Digital Living Network Alliance (DLNA) home networked device interoperability guidelines
    IEC 62502 Analysis techniques for dependability – Event tree analysis (ETA)
    IEC 62531 Property Specification Language (PSL)
    IEC 62606 General requirements for arc fault detection devices
    IEC 62680 Universal Serial Bus (USB) interfaces for data and power
    IEC 62682 Management of alarm systems for the process industries
    IEC 62684 Interoperability specifications of common external power supply (EPS) for use with data-enabled mobile telephones
    IEC 62693 Industrial electroheating installations – Test methods for infrared electroheating installations
    IEC 62700 DC Power supply for notebook computer
    IEC/TS 62796 Energy efficiency in electroheating installations
    IEC 62798 Industrial electroheating equipment – Test methods for infrared emitters
    IEC 80001 Application of risk management for IT-networks incorporating medical devices
    IEC 81346 Industrial systems* installations and equipment and industrial products - Structuring principles and reference designations
    See More: IEC standards compilation
    Attached Files Attached Files
  3. Re: IEC standards compilation
    how to download ******* there is no file
    My threads; ebadullahmomin :
    •    Sponsored Links
    • #3
    • #4
      Quote Originally Posted by ebadullahmomin View Post
      download torr-ent-- file and then using utorr-ent---- to download ...
      utorr-ent is free
    •    Spons.
    • #6
      You have to wait untill the downlod its complete at the to.rrent dowloader* if not the file will be invalid.
      the tor.rent program make the space in Hard Disk and in file folder size all the size* but is not true* you only can only use the file when you reach 100%
    • #7
      Thanks*
      Downloaded* currently reviewing
      My threads; Henryrcp :
      • #8
        can you post them in mediafire?
        Tks in advance
      • Re: IEC standards compilation
        Hi mate*
        I downloaded the torent and opened with u ******* but no one seems to be sharing.
        Is this shared on another platform as well?
        [link Point to another website Only the registered members can access] Thanks for your help.
        My threads; ale0016 :
        • #10
        • #11
          you can increase the speed of dowladoad with using this tor.r.ent trackers: copy and paste on this or each tor.r.re.nt this will add seeds and peers
          udp://191.101.229.236:1337/announce
          udp://89.234.156.205:80/announce
          udp://114.55.113.60:6969/announce
          udp://107.150.14.110:6969/announce
          udp://5.79.249.77:6969/announce
          udp://195.123.209.37:1337/announce
          udp://37.19.5.155:2710/announce
          udp://185.5.97.139:8089/announce
          udp://194.106.216.222:80/announce
          udp://51.254.244.161:6969/announce
          udp://188.165.253.109:1337/announce
          udp://128.199.70.66:5944/announce
          udp://195.123.209.40:80/announce
          udp://tracker.skyts.net:6969/announce
          udp://tracker.yoshi210.com:6969/announce
          udp://tracker.internetwarriors.net:1337/announce
          udp://tracker.ex.ua:80/announce
          udp://tracker.bittor.pw:1337/announce
          udp://tracker.kuroy.me:5944/announce
          udp://zer0day.ch:1337/announce
          udp://tracker.kicks-ass.net:80/announce
          udp://213.163.67.56:1337/announce
          udp://185.86.149.205:1337/announce
          udp://109.121.134.121:1337/announce
          udp://178.33.73.26:2710/announce
          udp://85.17.19.180:80/announce
          udp://tracker.mg64.net:6969/announce
          udp://tracker.opentrackr.o
          udp://tracker2.indowebster.com:6969/announce
          udp://tracker4.piratux.com:6969/announce
          udp://coppersurfer.tk:6969/announce
          udp://exodus.desync.com:6969/announce
          udp://open.demonii.com:1337/announce
          udp://tracker.publicbt.com:80/announce
          udp://public.popcorn-tracker.org:6969/announce
          udp://p4p.arenabg.com:1337/announce
          udp://tracker.piratepublic.com:1337/announce
          udp://tracker.tiny-vps.com:6969/announce
          udp://tracker.filetracker.pl:8089/announce
          udp://182.176.139.129:6969/announce
          udp://open.stealth.si:80/announce
          udp://208.67.16.113:8000/announce
          udp://94.23.183.33:6969/announce
          udp://74.82.52.209:6969/announce
          udp://151.80.120.114:2710/announce
          udp://168.235.67.63:6969/announce
          udp://5.79.83.193:6969/announce
          udp://46.4.109.148:6969/announce
          udp://62.212.85.66:2710/announce
          udp://bt.xxx-tracker.com:2710/announce
          udp://eddie4.nl:6969/announce
          udp://shadowshq.eddie4.nl:6969/announce
          udp://shadowshq.yi.org:6969/announce
          udp://tracker.eddie4.nl:6969/announce
          udp://tracker.mg64.net:2710/announce
          udp://62.138.0.158:6969/announce
          udp://bt.firebit.co.uk:6969/
          udp://p4p.arenabg.ch:1337
          udp://p4p.arenabg.ch:1337/announce
          udp://tracker.coppersurfer.tk/announce
          udp://tracker.coppersurfer.tk:1337/announce
          udp://tracker.coppersurfer.tk:6969
          udp://tracker.ilibr.org:6969/announce
          udp://tracker.leechers-paradise.org:6969
          udp://tracker.opentrackr.org:1337
          udp://www.eddie4.nl:6969/announce
          udp://9.rarbg.com:2780/announce
          udp://9.rarbg.me:2780/announce
          udp://9.rarbg.to:2730/announce
          udp://tracker.dler.org:6969/announce
          udp://tracker.trackerfix.com:82/announce
          udp://tracker.pirateparty.gr:6969/announce
          udp://mgtracker.org:2710/announce
          udp://91.218.230.81:6969/announce
          udp://tracker.grepler.com:6969/announce
          udp://185.50.198.188:1337/announce
          udp://tracker4.itzmx.com:2710/announce
          udp://tracker2.wasabii.com.tw:6969/announce
          udp://tracker.mg64.net:6881/announce
          udp://182.190.3.68:6969/announce
          udp://mgtracker.org:6969/announce
          udp://asnet.pw:2710/announce
          udp://tracker.mgtracker.org:2710/announce
          udp://tracker1.wasabii.com.tw:6969/announce
          udp://tracker.yibis.com:6969/announce
          udp://tracker3.itzmx.com:6961/announce
          udp://198.98.49.217:6969/announce
          udp://tracker.opentrackr.org:1337/announce
          udp://tracker.mininova.org/announce
          udp://tracker.opentrackr.org:80/announce
          udp://tracker.mrdrsr.net:6969/announce
          udp://open.acgtracker.com:1096/announce
          udp://tracker.bluefrog.pw:2710/announce
          udp://www.mvgroup.org:2710/announce
          udp://stats.anisource.net:2710/announce
          udp://182.190.4.52:6969/announce
          udp://tracker.coppersurfer.tk:6969/announce
          udp://tracker.leechers-paradise.org:6969/announce
          udp://tracker.zer0day.to:1337/announce
          udp://182.190.4.38:6969/announce
          udp://explodie.org:6969/announce
          udp://opentrackr.org:1337/announce
        •    Spons.
          Thanks a lot Himmelstern*
          I have loaded the ******* in bittor.rent and waiting for some peers to connect. (see pic)
          [link Point to another website Only the registered members can access] Hopefully it will work.
          Thanks again
          1. Replies: 0
            Last Post: 12-31-2016, 04:12 AM
          2. Bonometto (ed). Modern cosmology 2001 (compilation)(482s)(T)
            By dongono in forum General Engineering
            Last Post: 01-21-2015, 12:39 AM
          3. Compilation of links for various free windows software
            By fepro in forum Computer & Internet
            Last Post: 02-17-2014, 07:00 PM
