Page 1 of 5 1 2 3 ... LastLast
Results 1 to 12 of 55
    NEW API publications List - Help us find them
    Here is a list of the newer API publications from their site. Some are out there. Lets try to find and post them here.
    New Exploration and Production Publications
    API Standard 6ACRA
    Age-hardened Nickel-based Alloys for Oil and Gas Drilling and Production Equipment, First Edition, August 2015
    xxxAPI Standard 7CW
    Casing Wear Tests, First Edition, June 2015
    API Specification 7K
    Drilling and Well Servicing Equipment, Sixth Edition, December 2015
    API Recommended Practice 9B
    Application, Care, and Use of Wire Rope for Oil Field Service, Fourteenth Edition, October 2015
    API Recommended Practice 10B-3
    Testing of Well Cements Used in Deepwater Well Construction, Second Edition, January 2016
    API Recommended Practice 10B-4
    Preparation and Testing of Foamed Cement Formulations at Atmospheric Pressure, Second Edition, October 2015
    API Technical Report 10TR6
    Evaluation and Testing of Mechanical Cement Wiper Plugs, First Edition, July 2015
    xxxAPI Specification 11AX
    Specification for Subsurface Sucker Rod Pump Assemblies, Components, and Fittings, Thirteenth Edition, May 2015
    API Recommended Practice 14B
    Design, Installation, Operation, Test, and Redress of Subsurface Safety Valve Systems, Sixth Edition, September 2015
    API Specification 16RCD
    Specification for Rotating Control Devices, Second Edition, September 2015
    xxxAPI Recommended Practice 17S
    Recommended Practice for the Design, Testing, and Operation of Subsea Multiphase Flow Meters, First Edition, June 2015
    API Technical Report 17TR10
    Subsea Umbilical Termination (SUT) Design Recommendations, First Edition, December 2015
    API Technical Report 17TR11
    Pressure Effects on Subsea Hardware During Flowline Pressure Testing in Deep Water, First Edition, September 2015
    API Technical Report 18TR1
    Guidance on Changes to API Q1, Ninth Edition, First Edition, June 2015
    API Standard 20C
    Closed Die Forgings for Use in the Petroleum and Natural Gas Industry, Second Edition, November 2015
    API Specification 20F
    Corrosion Resistant Bolting for Use in the Petroleum and Natural Gas Industries, First Edition, June 2015
    API Standard 20H
    Heat Treatment ServicesóBatch Type for Equipment Used in the Petroleum and Natural Gas Industry, First Edition, October 2015
    API Bulletin 92L
    Drilling Ahead Safely with Lost Circulation in the Gulf of Mexico, First Edition, August 2015
    API Recommended Practice 100-1
    Hydraulic FracturingóWell Integrity and Fracture Containment, First Edition, October 2015
    ANSI/API Recommended Practice 100-2
    Managing Environmental Aspects Associated with Exploration and Production Operations Including Hydraulic Fracturing, First Edition, August 2015
    API OSRC
    Proceedings of the 2014 Offshore Structural Reliability Conference, First Edition, December 2015
    New Manual of Petroleum Measurement Publications
    API MPMS Chapter 8.2
    Standard Practice for Automatic Sampling of Petroleum and Petroleum Products, Third Edition, October 2015
    ASTM/API MPMS Chapter 8.5
    Standard Practice for Manual Piston Cylinder Sampling for Volatile Crude Oils, Condensates, and Liquid Petroleum Products, First Edition, December 2015
    API MPMS Chapter 11.3.3
    Miscellaneous Hydrocarbon Product PropertiesóDenatured Ethanol Density and Volume Correction Factors, Second Edition, November 2015
    API MPMS Chapter 17.12
    Procedures for Bulk Liquid Chemical Cargo Inspections, Second Edition, August 2015
    ANSI/API MPMS Chapter 22.1
    General Guidelines for Developing Testing Protocols for Devices Used in the Measurement of Hydrocarbon Fluids, Second Edition, August 2015
    ANSI/API MPMS Chapter 22.3
    Testing Protocol for Flare Gas Metering, First Edition, August 2015
    API MPMS Chapter 22.6
    Testing Protocol for Gas Chromatographs, First Edition, August 2015
    New Marketing Publications
    xxxAPI Recommended Practice 1640
    Product Quality in Light Product Storage and Handling Operations, First Edition, August 2013
    New Pipeline Publications
    API Recommended Practice 1111
    Design, Construction, Operation, and Maintenance of Offshore Hydrocarbon Pipelines (Limit State Design), Fifth Edition, September 2015
    API Technical Report 1149
    Pipeline Variable Uncertainties and Their Effects on Leak Detectability, Second Edition, September 2015
    API Technical Report 1166
    Excavation Monitoring and Observation for Damage Prevention, Second Edition, October 2015
    xxxAPI Recommended Practice 1168
    Pipeline Control Room Management, Second Edition, February 2015
    API Recommended Practice 1170
    Design and Operation of Solution-mined Salt Caverns Used for Natural Gas Storage, First Edition, July 2015
    API Recommended Practice 1171
    Functional Integrity of Natural Gas Storage in Depleted Hydrocarbon Reservoirs and Aquifer Reservoirs, First Edition, September 2015
    ANSI/API Recommended Practice 1173
    Pipeline Safety Management Systems, First Edition, July 2015
    API Recommended Practice 1174
    Recommended Practice for Onshore Hazardous Liquid Pipeline Emergency Preparedness and Response, First Edition, December 2015
    API Recommended Practice 1175
    Pipeline Leak DetectionóProgram Management, First Edition, December 2015
    API Recommended Practice 2200
    Repairing Hazardous Liquid Pipelines, Fifth Edition, September 2015
    New Refining Publications
    xxxAPI Standard 520, Part 2
    Sizing, Selection, and Installation of Pressure-relieving Devices, Part IIóInstallation, Sixth Edition, March 2015
    xxxAPI Standard 530
    Calculation of Heater-tube Thickness in Petroleum Refineries, Seventh Edition, April 2015
    API Recommended Practice 538
    Industrial Fired Boilers for General Refinery and Petrochemical Service, First Edition, October 2015
    xxxAPI Standard 600
    Steel Gate ValvesóFlanged and Butt-welding Ends, Bolted Bonnets, Thirteenth Edition, January 2015
    xxxAPI Standard 602
    Gate, Globe, and Check Valves for Sizes DN 100 (NPS 4) and Smaller for the Petroleum and Natural Gas Industries, Tenth Edition, May 2015
    xxxAPI Standard 660
    Shell-and-Tube Heat Exchangers, Ninth Edition, March 2015
    xxxAPI Technical Report 938-C
    Use of Duplex Stainless Steels in the Oil Refining Industry, Third Edition, February 2015
    New Safety, Fire and Scientific Affairs Publications
    API Recommended Practice 2003
    Protection Against Ignitions Arising Out of Static, Lightning, and Stray Currents, Eighth Edition, September 2015
    API Standard 2015
    Requirements for Safe Entry and Cleaning of Petroleum Storage Tanks, Seventh Edition, May 2014
    xxxAPI Recommended Practice 2030
    Application of Fixed Water Spray Systems for Fire Protection in the Petroleum and Petrochemical Industries, Fourth Edition, September 2014
    New Transportation Publications
    xxxANSI/API Recommended Practice 3000
    Classifying and Loading of Crude Oil into Rail Tank Cars, First Edition, September 2014
    xxx = posted
    See More: NEW API publications List - Help us find them
    Re: NEW API publications List - Help us find them
    Thanks a lot!
    Hi Marty. I don't completely understand this post. I have some of the publications listed above, but you/ your posts in this website are probably the source of all or most of them. In any case, the ones I have are listed bellow. Please tell me if you would like me to upload any of them. Thanks.
    API Standard 7CW
    API Standard 530
    API Standard 600
    API Standard 602
    API Standard 660
    pmx, thank you,
    To clarify, it was just a list of what is new directly from the API website,
    The ones that you have have been posted by me and other members, there are others files that we have not seen though.
    If everyone could just post what they have access to, this would be truly the best standards resource site, but few contribute.
    Most are selfish and are here only to take.
    So, to answer, if you can repost here your files and others can post the remainder, then we can be further along in keeping up to date.
    I still request that if anyone has access but not the time to do so, please provide me access by password login or proxy to the AWS, API, ASTM, etc. sites so we can complete our library for all.
    Here we go:
    API Standard 7CW
    API Standard 602
  14. #11
    API Standard 660
  16. #12
  1. New EEMUA publications
    By mhenna in forum Oil And Gas Process
    Last Post: 03-26-2018, 04:06 AM
  2. Publications Required
    By mdjaved91 in forum Safety And Environment
    Last Post: 08-12-2015, 04:35 AM
  3. EEMUA Publications
    By Guniawala in forum Safety And Environment
    Last Post: 05-31-2015, 04:06 AM
  4. Where Can I Find Drlling Bit Price list Catalog
    By akmal_tm05 in forum Drilling And Workover
    Last Post: 07-30-2012, 02:25 AM
  5. Special Publications
    By rancio in forum Geology & Exploration
    Last Post: 07-18-2010, 01:21 AM
