Page 2 of 2 FirstFirst 1 2
Results 13 to 17 of 17
  1. #13
    Re: CEN Standards Collection 81/370: CEN TC 197 - Pumps
    full list 28.10.2017:
    EN 733:1995 End-suction centrifugal pumps* rating with 10 bar with bearing bracket - Nominal duty point* main dimensions* designation system
    EN 734:1995 Side channel pumps PN 40 - Nominal duty point* main dimensions* designation system
    EN 735:1995 Overall dimensions of rotodynamic pumps - Tolerances
    EN 809:1998+A1:2009 Pumps and pump units for liquids - Common safety requirements
    EN 809:1998+A1:2009/AC:2010 Pumps and pump units for liquids - Common safety requirements
    EN 1829-1:2010 High pressure water jet machines - Safety requirements - Part 1: Machines
    EN 1829-2:2008 High-pressure water jet machines - Safety requirements - Part 2: Hoses* hose lines and connectors
    EN 1829-2:2008/AC:2011 High-pressure water jet machines - Safety requirements - Part 2: Hoses* hose lines and connectors
    EN ISO 2858:2010 End-suction centrifugal pumps (rating 16 bar) - Designation* nominal duty point and dimensions (ISO 2858:1975)
    EN ISO 3661:2010 End-suction centrifugal pumps - Baseplate and installation dimensions (ISO 3661:1977)
    EN ISO 5198:1998 Centrifugal* mixed flow and axial pumps - Code for hydraulic performance tests - Precision class (ISO 5198:1987)
    EN ISO 5199:2002 Technical specifications for centrifugal pumps - Class II (ISO 5199:2002)
    EN ISO 9905:1997 Technical specifications for centrifugal pumps - Class I (ISO 9905:1994)
    EN ISO 9905:1997/AC:2006 Technical specifications for centrifugal pumps - Class I (ISO 9905:1994)
    EN ISO 9905:1997/A1:2011 Technical specifications for centrifugal pumps - Class I - Amendment 1 (ISO 9905:1994/AMD 1:2011)
    EN ISO 9906:2012 Rotodynamic pumps - Hydraulic performance acceptance tests - Grades 1* 2 and 3 (ISO 9906:2012)
    EN ISO 9908:1997 Technical specifications for centrifugal pumps - Class III (ISO 9908:1993)
    EN ISO 9908:1997/A1:2011 Technical specifications for centrifugal pumps - Class III - Amendment 1 (ISO 9908:1993/AMD 1:2011)
    EN 12157:1999 Rotodynamic pumps - Coolant pumps units for machine tools - Nominal flow rate* dimensions
    EN 12162:2001+A1:2009 Liquid pumps - Safety requirements - Procedure for hydrostatic testing
    EN 12262:1998 Rotodynamic pumps - Technical documents - Terms* delivery range* layout
    EN 12483:1999 Liquid pumps - Pump units with frequency inverters - Guarantee and compatibility tests
    EN 12756:2000 Mechanical seals - Principal dimensions* designation and material codes
    CEN/TR 13930:2009 Rotodynamic pumps - Design of pump intakes - Recommendations for installation of pumps
    CEN/TR 13930:2009/AC:2010 Rotodynamic pumps - Design of pump intakes - Recommendation for installation of pumps
    CEN/TR 13931:2009 Rotodynamic pumps - Forces and moments on flanges - Centrifugal* mixed flow and axial flow horizontal and vertical shafts pumps
    CEN/TR 13931:2009/AC:2010 Rotodynamic pumps - Forces and moments on flanges - Centrifugal* mixed flow and axial flow horizontal and vertical shafts pumps
    CEN/TR 13932:2009 Rotodynamic pumps - Recommendations for fitting of inlet and outlet on piping
    EN 13951:2012 Liquid pumps - Safety requirements - Agrifoodstuffs equipment; Design rules to ensure hygiene in use
    EN 14343:2005 Rotary positive displacement pumps - Performance tests for acceptance
    EN 14343:2005/AC:2008 Rotary positive displacement pumps - Performance tests for acceptance
    EN ISO 14414:2015 Pump system energy assessment (ISO/ASME 14414:2015)
    EN ISO 14414:2015/ A1:2016 Pump system energy assessment - Amendment 1 (ISO/ASME 14414:2015/Amd 1:2016)
    EN ISO 14847:1999 Rotary positive displacement pumps - Technical requirements (ISO 14847:1999)
    EN ISO 15783:2003 Seal-less rotodynamic pumps - Class II - Specification (ISO 15783:2002)
    EN ISO 15783:2003/A1:2008 Seal-less rotodynamic pumps - Class II - Specification - Amendment 1 (ISO 15783:2003/Amd 1:2008)
    EN 16297-1:2012 Pumps - Rotodynamic pumps - Glandless circulators - Part 1: General requirements and procedures for testing and calculation of energy efficiency index (EEI)
    EN 16297-2:2012 Pumps - Rotodynamic pumps - Glandless circulators - Part 2: Calculation of energy efficiency index (EEI) for standalone circulators
    EN 16297-3:2012 Pumps - Rotodynamic pumps - Glandless circulators - Part 3: Energy efficiency index (EEI) for circulators integrated in products
    EN ISO 16330:2003 Reciprocating positive displacement pumps and pump units - Technical requirements (ISO 16330:2003)
    EN 16480:2016 Pumps - Minimum required efficiency of rotodynamic water pumps
    EN 16644:2014 Pumps - Rotodynamic pumps - Glandless circulators having a rated power input not exceeding 200 W for heating installations and domestic hot water installations - Noise test code (vibro-acoustics) for measuring structure- and fluid-borne noise
    EN 16752:2015 Centrifugal pumps - Test procedure for seal packings
    EN ISO 17769-1:2012 Liquid pumps and installation - General terms* definitions* quantities* letter symbols and units - Part 1: Liquid pumps (ISO 17769-1:2012)
    EN ISO 17769-2:2012 Liquid pumps and installation - General terms* definitions* quantities* letter symbols and units - Part 2: Pumping System (ISO 17769-2:2012)
    EN ISO 20361:2015 Liquid pumps and pump units - Noise test code - Grades 2 and 3 of accuracy (ISO 20361:2015)
    complete
    See More: CEN Standards Collection 81/370: CEN TC 197 - Pumps
  3.    Sponsored Links
  4. #15
    thank you,,
    My threads; ariek :
    • #16
    • Re: CEN Standards Collection 81/370: CEN TC 197 - Pumps
      Thank you very much
      My threads; supergtworld :
      •    Spons.
      1. Replies: 8
        Last Post: 12-24-2017, 08:11 PM
      2. Replies: 8
        Last Post: 11-30-2017, 12:14 AM
      3. Replies: 0
        Last Post: 12-31-2016, 04:12 AM
      4. Standards for Pumps
        By Abo Khaled in forum Mechanical Engineering
        Last Post: 08-13-2012, 03:43 PM
