Results 1 to 11 of 11
    CEN Standards Collection 73/370: CEN SS T01- Shipbuilding & Maritime Structures
    14 are missing
    EN ISO 4566:1995 Small craft with inboard engine - Propeller shaft ends and bosses with 1 : 10 taper (ISO 4566:1992)
    EN ISO 6185-1:2001 Inflatable boats - Part 1: Boats with a maximum motor power rating of 4,5 kW (ISO 6185-1:2001)
    EN ISO 6185-2:2001 Inflatable boats - Part 2: Boats with a maximum motor power rating of 4,5 kW to 15 kW inclusive (ISO 6185-2:2001)
    EN ISO 6185-3:2014 Inflatable boats - Part 3: Boats with a hull length less than 8 m with a motor rating of 15 kW and greater (ISO 6185-3:2014)
    EN ISO 6185-4:2011 Inflatable boats - Part 4: Boats with a hull length of between 8 m and 24 m with a motor power rating of 15 kW and greater (ISO 6185-4:2011, Corrected version 2014-08-01)
    EN ISO 7840:2013 Small craft - Fire-resistant fuel hoses (ISO 7840:2013)
    EN ISO 8099:2000 Small craft - Toilet waste retention systems (ISO 8099:2000)
    EN ISO 8469:2013 Small craft - Non-fire-resistant fuel hoses (ISO 8469:2013)
    EN ISO 8665:2006 Small craft - Marine propulsion reciprocating internal combustion engines - Power measurements and declarations (ISO 8665:2006)
    EN ISO 8666:2002 Small craft - Principal data (ISO 8666:2002)
    EN ISO 8847:2004 Small craft - Steering gear - Cable and pulley systems (ISO 8847:2004)
    EN ISO 8847:2004/AC:2005 Small craft - Steering gear - Cable and pulley systems (ISO 8847:2004)
    EN ISO 8849:2003 Small craft - Electrically operated direct-current bilge-pumps (ISO 8849:2003)
    EN ISO 9093-1:1997 Small craft - Seacocks and through-hull fittings - Part 1: Metallic (ISO 9093-1:1994)
    EN ISO 9093-2:2002 Small craft - Seacocks and through-hull fittings - Part 2: Non-metallic (ISO 9093-2:2002)
    EN ISO 9094:2015 Small craft - Fire protection (ISO 9094:2015)
    EN ISO 9097:1994 Small craft - Electric fans (ISO 9097:1991)
    EN ISO 9097:1994/A1:2000 Small craft - Electric fans (ISO 9097:1991)
    EN ISO 10087:2006 Small craft - Craft identification - Coding system (ISO 10087:2006)
    EN ISO 10088:2013 Small craft - Permanently installed fuel systems (ISO 10088:2013)
    EN ISO 10133:2012 Small craft - Electrical systems - Extra-low-voltage d.c. installations (ISO 10133:2012)
    EN ISO 10239:2014 Small craft - Liquefied petroleum gas (LPG) systems (ISO 10239:2014)
    EN ISO 10240:2004 Small craft - Owner's manual (ISO 10240:2004)
    EN ISO 10240:2004/A1:2015 Small craft - Owner's manual (ISO 10240:2004/Amd 1:2015)
    EN ISO 10592:1995 Small craft - Hydraulic steering systems (ISO 10592:1994)
    EN ISO 10592:1995/A1:2000 Small craft - Hydraulic steering systems (ISO 10592:1994)
    EN ISO 11105:1997 Small craft - Ventilation of petrol engine and/or petrol tank compartments (ISO 11105:1997)
    EN ISO 11192:2005 Small craft - Graphical symbols (ISO 11192:2005)
    EN ISO 11547:1995 Small craft - Start-in-gear protection (ISO 11547:1994)
    EN ISO 11547:1995/A1:2000 Small craft - Start-in-gear protection (ISO 11547:1994)
    EN ISO 11591:2011 Small craft, engine-driven - Field of vision from helm position (ISO 11591:2011)
    EN ISO 11592:2001 Small craft less than 8 m length of hull - Determination of maximum propulsion power rating (ISO 11592:2001)
    EN ISO 11812:2001 Small craft - Watertight cockpits and quick-draining cockpits (ISO 11812:2001)
    EN ISO 12215-1:2000 Small craft - Hull construction and scantlings - Part 1: Materials: Thermosetting resins, glass-fibre reinforcement, reference laminate (ISO 12215-1:2000)
    EN ISO 12215-2:2002 Small craft - Hull construction and scantlings - Part 2: Materials: Core materials for sandwich construction, embedded materials (ISO 12215-2:2002)
    EN ISO 12215-3:2002 Small craft - Hull construction and scantlings - Part 3: Materials: Steel, aluminium alloys, wood, other materials (ISO 12215-3:2002)
    EN ISO 12215-4:2002 Small craft - Hull construction and scantlings - Part 4: Workshop and manufacturing (ISO 12215-4:2002)
    EN ISO 12215-5:2008 Small craft - Hull construction and scantlings - Part 5: Design pressures for monohulls, design stresses, scantlings determination (ISO 12215-5:2008)
    EN ISO 12215-5:2008/A1:2014 Small craft - Hull construction and scantlings - Part 5: Design pressures for monohulls, design stresses, scantlings determination - Amendment 1 (ISO 12215-5:2008/Amd 1:2014)
    EN ISO 12215-6:2008 Small craft - Hull construction and scantlings - Part 6: Structural arrangements and details (ISO 12215-6:2008)
    EN ISO 12215-8:2009 Small craft - Hull construction and scantlings - Part 8: Rudders (ISO 12215-8:2009)
    EN ISO 12215-8:2009/AC:2010 Small craft - Hull construction and scantlings - Part 8: Rudders - Technical Corrigendum 1 (ISO 12215-8:2009/Cor 1:2010)
    EN ISO 12215-9:2012 Small craft - Hull construction and scantlings - Part 9: Sailing craft appendages (ISO 12215-9:2012)
    EN ISO 12216:2002 Small craft - Windows, portlights, hatches, deadlights and doors - Strength and watertightness requirements (ISO 12216:2002)
    EN ISO 12217-1:2015 Small craft - Stability and buoyancy assessment and categorization - Part 1: Non-sailing boats of hull length greater than or equal to 6 m (ISO 12217-1:2015)
    EN ISO 12217-2:2015 Small craft - Stability and buoyancy assessment and categorization - Part 2: Sailing boats of hull length greater than or equal to 6 m (ISO 12217-2:2015)
    EN ISO 12217-3:2015 Small craft - Stability and buoyancy assessment and categorization - Part 3: Boats of hull length less than 6 m (ISO 12217-3:2015)
    EN ISO 13297:2014 Small craft - Electrical systems - Alternating current installations (ISO 13297:2014)
    EN ISO 13590:2003 Small craft - Personal watercraft - Construction and system installation requirements (ISO 13590:2003)
    EN ISO 13590:2003/AC:2004 Small craft - Personal watercraft - Construction and system installation requirements (ISO 13590:2003)
    EN ISO 13929:2001 Small craft - Steering gear - Geared link systems (ISO 13929:2001)
    EN ISO 14509-1:2008 Small craft - Airborne sound emitted by powered recreational craft - Part 1: Pass-by measurement procedures (ISO 14509-1:2008)
    EN ISO 14509-2:2006 Small craft - Airborne sound emitted by powered recreational craft - Part 2: Sound assessment using reference craft (ISO 14509-2:2006)
    EN ISO 14509-3:2009 Small craft - Airborne sound emitted by powered recreational craft - Part 3: Sound assessment using calculation and measurement procedures (ISO 14509-3:2009)
    EN ISO 14895:2003 Small craft - Liquid-fuelled galley stoves (ISO 14895:2000)
    EN ISO 14945:2004 Small craft - Builder's plate (ISO 14945:2004)
    EN ISO 14945:2004/AC:2005 Small craft - Builder's plate (ISO 14945:2004)
    EN ISO 14946:2001 Small craft - Maximum load capacity (ISO 14946:2001)
    EN ISO 14946:2001/AC:2005 Small craft - Maximum load capacity (ISO 14946:2001)
    EN ISO 15083:2003 Small craft - Bilge-pumping systems (ISO 15083:2003)
    EN ISO 15084:2003 Small craft - Anchoring, mooring and towing - Strong points (ISO 15084:2003)
    EN ISO 15085:2003 Small craft - Man-overboard prevention and recovery (ISO 15085:2003)
    EN ISO 15085:2003/A1:2009 Small craft - Man-overboard prevention and recovery - Amendment 1 (ISO 15085:2003/Amd 1:2009)
    EN ISO 15584:2001 Small craft - Inboard petrol engines - Engine-mounted fuel and electrical components (ISO 15584:2001)
    EN ISO 15652:2005 Small craft - Remote steering systems for inboard mini jet boats (ISO 15652:2003)
    EN ISO 16147:2002 Small craft - Inboard diesel engines - Engine-mounted fuel and electrical components (ISO 16147:2002)
    EN ISO 16147:2002/A1:2013 Small craft - Inboard diesel engines - Engine-mounted fuel and electrical components - Amendment 1 (ISO 16147:2002/Amd 1:2013)
    EN ISO 16180:2013 Small craft - Navigation lights - Installation, placement and visibility (ISO 16180:2013)
    EN ISO 18854:2015 Small craft - Reciprocating internal combustion engines exhaust emission measurement - Test-bed measurement of gaseous and particulate exhaust emissions (ISO 18854:2015)
    EN ISO 19009:2015 Small craft - Electric navigation lights - Performance of LED lights (ISO 19009:2015)
    EN ISO 21487:2012 Small craft - Permanently installed petrol and diesel fuel tanks (ISO 21487:2012)
    EN ISO 21487:2012/A1:2014 Small craft - Permanently installed petrol and diesel fuel tanks - Amendment 1 (ISO 21487:2012/Amd 1:2014)
    EN ISO 21487:2012/A2:2015 Small craft - Permanently installed petrol and diesel fuel tanks - Amendment 2 (ISO 21487:2012/Amd 2:2015)
    EN ISO 25197:2012 Small craft - Electrical/electronic control systems for steering, shift and throttle (ISO 25197:2012)
    EN ISO 25197:2012/A1:2014 Small craft - Electrical/electronic control systems for steering, shift and throttle - Amendment 1 (ISO 25197:2012/Amd 1:2014)
    EN 28846:1993 Small craft - Electrical devices - Protection against ignition of surrounding flammable gases (ISO 8846:1990)
    EN 28846:1993/A1:2000 Small craft - Electrical devices - Protection against ignition of surrounding flammable gases (ISO 8846:1990)
    EN 28848:1993 Small craft - Remote steering systems (ISO 8848:1990)
    EN 28848:1993/A1:2000 Small craft - Remote steering systems (ISO 8848:1990)
    EN 29775:1993 Small craft - Remote steering systems for single outboard motors of 15 kW to 40 kW power (ISO 9775:1990)
    EN 29775:1993/A1:2000 Small craft - Remote steering systems for single outboard motors of 15 kW to 40 kW power (ISO 9775:1990)
    or
    See More: CEN Standards Collection 73/370: CEN SS T01- Shipbuilding & Maritime Structures
    Re: CEN Standards Collection 73/300: CEN SS T01- Shipbuilding & Maritime Structures
    update:
    EN ISO 9094:2015 Small craft - Fire protection (ISO 9094:2015) - added missing standard
    EN ISO 12217-1:2015 Small craft - Stability and buoyancy assessment and categorization - Part 1: Non-sailing boats of hull length greater than or equal to 6 m (ISO 12217-1:2015) - added missing standard
    EN ISO 12217-2:2015 Small craft - Stability and buoyancy assessment and categorization - Part 2: Sailing boats of hull length greater than or equal to 6 m (ISO 12217-2:2015) - added missing standard
    EN ISO 12217-3:2015 Small craft - Stability and buoyancy assessment and categorization - Part 3: Boats of hull length less than 6 m (ISO 12217-3:2015) - added missing standard
    EN ISO 19009:2015 Small craft - Electric navigation lights - Performance of LED lights (ISO 19009:2015) - added missing standard
    [link Point to another website Only the registered members can access] or
    update:
    EN ISO 11592-1:2016 Small craft - Determination of maximum propulsion power rating using manoeuvring speed - Part 1: Craft with a length of hull less than 8 m (ISO 11592-1:2016) - added new standard
    missing AC's or A1/A2:
    and missing standard:
    EN ISO 16315:2016 Small craft - Electric propulsion system (ISO 16315:2016)
    new links:
    or
    Re: CEN Standards Collection 73/340: CEN SS T01- Shipbuilding & Maritime Structures
    update:
    EN ISO 6185-4:2011 Inflatable boats - Part 4: Boats with a hull length of between 8 m and 24 m with a motor power rating of 15 kW and greater (ISO 6185-4:2011, Corrected version 2014-08-01) - added EN version
    EN ISO 7840:2013 Small craft - Fire-resistant fuel hoses (ISO 7840:2013) - added EN version
    EN ISO 8469:2013 Small craft - Non-fire-resistant fuel hoses (ISO 8469:2013) - added EN version
    EN ISO 8665:2006 Small craft - Marine propulsion reciprocating internal combustion engines - Power measurements and declarations (ISO 8665:2006) - added EN version
    EN ISO 9093-2:2002 Small craft - Seacocks and through-hull fittings - Part 2: Non-metallic (ISO 9093-2:2002) - added EN versionEN ISO 10087:2006 Small craft - Craft identification - Coding system (ISO 10087:2006) - added EN version
    EN ISO 10088:2013 Small craft - Permanently installed fuel systems (ISO 10088:2013) - added EN version
    EN ISO 10133:2012 Small craft - Electrical systems - Extra-low-voltage d.c. installations (ISO 10133:2012) - added EN version
    EN ISO 11591:2011 Small craft, engine-driven - Field of vision from helm position (ISO 11591:2011) - added EN version
    EN ISO 12215-5:2008 Small craft - Hull construction and scantlings - Part 5: Design pressures for monohulls, design stresses, scantlings determination (ISO 12215-5:2008) - added EN version
    EN ISO 12215-5:2008/A1:2014 Small craft - Hull construction and scantlings - Part 5: Design pressures for monohulls, design stresses, scantlings determination - Amendment 1 (ISO 12215-5:2008/Amd 1:2014) - added missing A1
    EN ISO 12215-6:2008 Small craft - Hull construction and scantlings - Part 6: Structural arrangements and details (ISO 12215-6:2008) - added EN version
    EN ISO 12215-8:2009 Small craft - Hull construction and scantlings - Part 8: Rudders (ISO 12215-8:2009) - added EN version
    EN ISO 12215-8:2009/AC:2010 Small craft - Hull construction and scantlings - Part 8: Rudders - Technical Corrigendum 1 (ISO 12215-8:2009/Cor 1:2010) - added EN version
    EN ISO 12215-9:2012 Small craft - Hull construction and scantlings - Part 9: Sailing craft appendages (ISO 12215-9:2012) - added EN version
    EN ISO 14895:2016 Small craft - Liquid-fuelled galley stoves and heating appliances (ISO 14895:2016) - added new version of standard
    EN ISO 15085:2003 Small craft - Man-overboard prevention and recovery (ISO 15085:2003) - added EN version
    EN ISO 15085:2003/A1:2009 Small craft - Man-overboard prevention and recovery - Amendment 1 (ISO 15085:2003/Amd 1:2009) - added EN version
    EN ISO 16147:2002/A1:2013 Small craft - Inboard diesel engines - Engine-mounted fuel and electrical components - Amendment 1 (ISO 16147:2002/Amd 1:2013) - added EN version
    EN ISO 16180:2013 Small craft - Navigation lights - Installation, placement and visibility (ISO 16180:2013) - added EN version
    EN ISO 21487:2012 Small craft - Permanently installed petrol and diesel fuel tanks (ISO 21487:2012) - added EN version
    EN ISO 21487:2012/A1:2014 Small craft - Permanently installed petrol and diesel fuel tanks - Amendment 1 (ISO 21487:2012/Amd 1:2014) - added missing A1
    EN ISO 21487:2012/A2:2015 Small craft - Permanently installed petrol and diesel fuel tanks - Amendment 2 (ISO 21487:2012/Amd 2:2015) - added missing A2
    missing list:
    EN ISO 8847:2004/AC:2005 Small craft - Steering gear - Cable and pulley systems (ISO 8847:2004) - missing AC
    EN ISO 10240:2004/A1:2015 Small craft - Owner's manual (ISO 10240:2004/Amd 1:2015) - missing A1
    EN ISO 13590:2003/AC:2004 Small craft - Personal watercraft - Construction and system installation requirements (ISO 13590:2003) - missing AC
    EN ISO 14945:2004/AC:2005 Small craft - Builder's plate (ISO 14945:2004) - missing AC
    EN ISO 14946:2001/AC:2005 Small craft - Maximum load capacity (ISO 14946:2001) - missing AC
    EN ISO 16315:2016 Small craft - Electric propulsion system (ISO 16315:2016) - missing standard
    EN ISO 25197:2012/A1:2014 Small craft - Electrical/electronic control systems for steering, shift and throttle - Amendment 1 (ISO 25197:2012/Amd 1:2014) - missing A1
    links:
    or
  7. #5
    update:
    EN ISO 8847:2004/AC:2005 Small craft - Steering gear - Cable and pulley systems (ISO 8847:2004) - added missing AC
    EN ISO 10240:2004/A1:2015 Small craft - Owner's manual (ISO 10240:2004/Amd 1:2015) - added missing standard
    EN ISO 13590:2003/AC:2004 Small craft - Personal watercraft - Construction and system installation requirements (ISO 13590:2003) - added missing AC
    EN ISO 14945:2004/AC:2005 Small craft - Builder's plate (ISO 14945:2004) - added missing AC
    EN ISO 14946:2001/AC:2005 Small craft - Maximum load capacity (ISO 14946:2001) - added missing AC
    EN ISO 25197:2012/A1:2014 Small craft - Electrical/electronic control systems for steering, shift and throttle - Amendment 1 (ISO 25197:2012/Amd 1:2014) - added missing standard
    missing list now is:
    EN ISO 8666:2016 Small craft - Principal data (ISO 8666:2016)
    links:
    or
  9. #6
    Re: CEN Standards Collection 73/350: CEN SS T01- Shipbuilding & Maritime Structures
    update:
    EN ISO 8666:2016 Small craft - Principal data (ISO 8666:2016) - added missing standard
    EN ISO 16315:2016 Small craft - Electric propulsion system (ISO 16315:2016) - was my mistake, this standard has been added last time
    sector complete now
    or
  10. #7
    update:
    better quality of:
    EN ISO 12215-5:2008/A1:2014 Small craft - Hull construction and scantlings - Part 5: Design pressures for monohulls* design stresses* scantlings determination - Amendment 1 (ISO 12215-5:2008/Amd 1:2014)
    EN version of:
    EN ISO 12215-1:2000 Small craft - Hull construction and scantlings - Part 1: Materials: Thermosetting resins* glass-fibre reinforcement* reference laminate (ISO 12215-1:2000)
    EN ISO 12216:2002 Small craft - Windows* portlights* hatches* deadlights and doors - Strength and watertightness requirements (ISO 12216:2002)
    EN ISO 15084:2003 Small craft - Anchoring* mooring and towing - Strong points (ISO 15084:2003)
    sector still complete
    new links:
    or
  11. #8
  12. #9
    Re: CEN Standards Collection 73/370: CEN SS T01- Shipbuilding & Maritime Structures
    update:
    better quality or EN versions:
    EN ISO 6185-1:2001 Inflatable boats - Part 1: Boats with a maximum motor power rating of 4*5 kW (ISO 6185-1:2001)
    EN ISO 6185-2:2001 Inflatable boats - Part 2: Boats with a maximum motor power rating of 4*5 kW to 15 kW inclusive (ISO 6185-2:2001)
    EN ISO 12215-2:2002 Small craft - Hull construction and scantlings - Part 2: Materials: Core materials for sandwich construction* embedded materials (ISO 12215-2:2002)
    EN ISO 12215-3:2002 Small craft - Hull construction and scantlings - Part 3: Materials: Steel* aluminium alloys* wood* other materials (ISO 12215-3:2002)
    still nothing missing here
  13. #10
    full list 28.10.2017:
    EN ISO 6185-4:2011 Inflatable boats - Part 4: Boats with a hull length of between 8 m and 24 m with a motor power rating of 15 kW and greater (ISO 6185-4:2011* Corrected version 2014-08-01)
    EN ISO 8665:2017 Small craft - Marine propulsion reciprocating internal combustion engines - Power measurements and declarations (ISO 8665:2006)
    EN ISO 8846:2017 Small craft - Electrical devices - Protection against ignition of surrounding flammable gases (ISO 8846:1990)
    EN ISO 8847:2017 Small craft - Steering gear - Cable and pulley systems (ISO 8847:2004)
    EN ISO 8847:2017/AC:2005 Small craft - Steering gear - Cable and pulley systems (ISO 8847:2004)
    EN ISO 8848:2017 Small craft - Remote steering systems (ISO 8848:1990)
    EN ISO 9094:2017 Small craft - Fire protection (ISO 9094:2015)
    EN ISO 9097:2017 Small craft - Electric fans (ISO 9097:1991)
    EN ISO 9775:2017 Small craft - Remote steering systems for single outboard motors of 15 kW to 40 kW power (ISO 9775:1990)
    EN ISO 10088:2017 Small craft - Permanently installed fuel systems (ISO 10088:2013)
    EN ISO 10133:2017 Small craft - Electrical systems - Extra-low-voltage d.c. installations (ISO 10133:2012)
    EN ISO 10239:2017 Small craft - Liquefied petroleum gas (LPG) systems (ISO 10239:2014)
    EN ISO 10592:2017 Small craft - Hydraulic steering systems (ISO 10592:1994)
    EN ISO 11105:2017 Small craft - Ventilation of petrol engine and/or petrol tank compartments (ISO 11105:1997)
    EN ISO 11591:2011 Small craft* engine-driven - Field of vision from helm position (ISO 11591:2011)
    EN ISO 12215-5:2008 Small craft - Hull construction and scantlings - Part 5: Design pressures for monohulls* design stresses* scantlings determination (ISO 12215-5:2008)
    EN ISO 12217-1:2017 Small craft - Stability and buoyancy assessment and categorization - Part 1: Non-sailing boats of hull length greater than or equal to 6 m (ISO 12217-1:2015)
    EN ISO 12217-2:2017 Small craft - Stability and buoyancy assessment and categorization - Part 2: Sailing boats of hull length greater than or equal to 6 m (ISO 12217-2:2015)
    EN ISO 12217-3:2017 Small craft - Stability and buoyancy assessment and categorization - Part 3: Boats of hull length less than 6 m (ISO 12217-3:2015)
    EN ISO 13929:2017 Small craft - Steering gear - Geared link systems (ISO 13929:2001)
    EN ISO 15584:2017 Small craft - Inboard petrol engines - Engine-mounted fuel and electrical components (ISO 15584:2001)
    EN ISO 15652:2017 Small craft - Remote steering systems for inboard mini jet boats (ISO 15652:2003)
    EN ISO 16147:2017 Small craft - Inboard diesel engines - Engine-mounted fuel and electrical components (ISO 16147:2002)
    EN ISO 16147:2017/A1:2013 Small craft - Inboard diesel engines - Engine-mounted fuel and electrical components - Amendment 1 (ISO 16147:2002/Amd 1:2013)
    EN ISO 16180:2013 Small craft - Navigation lights - Installation* placement and visibility (ISO 16180:2013)
    EN ISO 25197:2012 Small craft - Electrical/electronic control systems for steering* shift and throttle (ISO 25197:2012)
    EN ISO 25197:2012/A1:2014 Small craft - Electrical/electronic control systems for steering* shift and throttle - Amendment 1 (ISO 25197:2012/Amd 1:2014)
    complete
  14. #11
    Dear collegues, someone who can spare ISO 11592-2:2019, ISO 10087:2019, ISO 12215-5:2019?
    My threads; CChris :
  1. CEN Standars Collection 67/370: CEN SS B02 - Structures
    Last Post: 11-25-2017, 03:50 AM
  2. ISO Collection 2/300: ISO/TC 167 - Steel and aluminium structures
    Last Post: 11-17-2017, 08:22 PM
  3. ISO Collection 138/300: ISO/TC 165-Timber structures
    Last Post: 07-09-2017, 01:41 AM
  4. Replies: 5
    Last Post: 07-03-2017, 03:47 AM
  5. CEN Standards Collection 217/370: CEN TC 124-Timber Structures
    Last Post: 06-18-2017, 01:31 AM
