Results 1 to 7 of 7
Thread: cadworx equipment
    Question cadworx equipment
    if any body can guide me how to generate 2D drawings from 3D model in cadworx equipment.
    See More: cadworx equipment
  3. This is made with commnd 2DREP
    My threads; severdeth :
    •    Sponsored Links
    • In the Layout of Autocad YOU GIVE THIS COMMAND ONCE YOU HAVE CREATED THE VIEWPORT and is not turning back once you have created 2DREP for 2d drawings to 3d models
      The solution is create another layout with your darwings and give there the commnd This is a recomandation for the modification for all the pahases of the project
      • For more information contact me
        • #5
          dear friend
          1st thanks for ur response, i tried the command 2DREP that u suggested to generate 2d drawings from 3d model while working in cadworx but it didnt work. this command is unknown to autocad. please suggest further
          with best wishes
          sangi
        •    Spons.
        • iF YOU GIVE THE COMMAND IN LAYOUT autocad The program is no now it .But if you open the Cadworx in Layout when you make the view is work When you give the command the Cadworx ask you to select the view You selected it and give ok A the program transform the 3d model in 2d drawings
          The cadworx is a program that ussuly defect when you give the commnd in a large file insert in the Layout And some time no whant to do the commnd
          How i say try the commnd in layout Cadworx not in model and not in the Autocad simple with not Cadworx
          And good look
          • Cadworx is a program is to easy to learn and easy to use in 3d modeling but in the GA DRAWINGS It's make you same time life so hard becouse is easyly defect And give a lot of error when you make deal with very large file for ex 30 file for drawings insert in Layout to make a GA and if you have lot of them large util 20MB you sure make a lot o pary to finish the job and I some cases this is when Cadworx is defect and it must by reinstal And make some strong upgarde your PC
            1. Intergraph CADWorx Plant Design Suite (Plant, P&ID, Equipment, IP) 2013 R2
              By guaspari in forum Engineering Software Tutorial
              Last Post: 05-28-2013, 09:31 AM
            2. Cadworx 2012 Equipment
              By ahaks120 in forum Engineering Software Tutorial
              Last Post: 05-18-2013, 05:19 PM
            3. CAdworx Fieldpipe or Cadworx Fieldpro
              By anonimou in forum Engineering Software Tutorial
              Last Post: 07-22-2011, 10:10 AM
            4. cadworx equipment tutorials
              By sangi in forum Engineering Software Tutorial
              Last Post: 11-19-2009, 11:03 AM
            5. cadworx equipment
              By sangi in forum Mechanical Engineering
              Last Post: 09-30-2009, 06:43 AM
