Results 1 to 12 of 12
Thread: Substation Design Software
  1. Substation Design Software
    Hello all dears, Does anyone have Bentley substation V8i P********c-h or Primtech full setup+P********c-h or c.-r.-a.-c.-k or Substation Design Suite or 3d or 3D-DASl full ? these are electrical substation design and analysis softwares. If yes, please share them.
    Primtech is the best software for substation designing and it works with Autodesk Mep
    Autodesk Mep ******* Link:
    Autodesk Revit MEP 2015 x64:
    [link Point to another website Only the registered members can access] Autodesk Revit 2013 x86 & x64:
    Substation Design Suite is a powerful software, too. it works with Autodesk Inventor and is a excellent designing tool for substation designing.
    Autodesk Inventor ******* Link:
    Autodesk Inventor Pro 2015 x86:
    [link Point to another website Only the registered members can access] Autodesk Inventor Pro 2015 x64:
    3D-DASl is other software for substation design that work with Autodesk Autocad. It is a good software, too.
    And Autocad Electrical:
    Autodesk Autocad Electrical 2015 x86:
    [link Point to another website Only the registered members can access] Autodesk Autocad Electrical 2015 x64:
    All *******s from up links are good speed *******s.
    I just could download Bentley substation. If anyone has everyone of them, please share.
    Bentley substation V8i:
    Other Link (Older version):
    up links are good and this soft woks very well but it isn't full license.
    I found c.-r.-a.-c.-k link for substation design but i couldn't download it and I'm not sure about it. It need to survey and i couldn't to complete it and download.
    Please if everyone to be succeed to download it , share it on the other sharing site for example 4share.
    Regard
    See More: Substation Design Software
  3. Re: Substation Design Software
    [link Point to another website Only the registered members can access] I use subs08111275en
  5. Re: Substation Design Software
    Quote Originally Posted by abbasdivian View Post
    Regard
    Thanks for sharing the links.. I will pm you regarding the license of Bentley Substation
    Here you can get Bentley substation V8i full
    My threads; atoyo :
    • #7
      My threads; atoyo :
      • #8
        For *****ing have started try it now!.exe file.
        Have chosen C:\ProgramData\Bentley\Licensing path
        The error message generated was "Wrong path or license file".
        Please, help on *****ing Bentley Substation. Thanks.
      • #9
        For activating Bentley Substation have started try it now!.exe file.
        Please, help on activating Bentley Substation. Thanks.
      • Re: Substation Design Software
        or
        or
      • #11
        Regard
        do you have the Substation Design Suite and it's solution?
      •    Spons.
      • #12
      1. Electrical Design Software - Volts by Dolphin Software
        By surgeArrester in forum Electrical & Power Engineering
        Last Post: 01-07-2020, 04:35 PM
      2. Bentley Substation V8i
        By cemljxp in forum Electrical & Power Engineering
        Last Post: 08-04-2017, 03:25 AM
      3. 400 kV or above rated substation
        By Abu Monsur Ali in forum Electrical & Power Engineering
        Last Post: 09-07-2013, 11:37 AM
      4. Replies: 0
        Last Post: 05-17-2013, 10:44 PM
      5. Substation & control room design criteria as per NFPA
        By aniket00786 in forum Safety And Environment
        Last Post: 05-17-2013, 06:42 PM
