Page 2 of 2 FirstFirst 1 2
Results 13 to 24 of 24
Thread: ASME MFC std
  1. #13
    Re: ASME MFC std
    ASME MFC-1M-1991 Glossary of Terms Used in the Measurement of Fluid Flow In Pipes
    ASME MFC-1M-2003 Glossary of Terms Used in the Measurement of Fluid Flow in Pipes
    ASME MFC-1M-2003 R2008 Glossary of Terms Used in the Measurement of Fluid Flow in Pipes
    ASME MFC-2M-1983 Measurement Uncertainty for Fluid Flow in Closed Conduits
    ASME MFC-3M-1989 R1995 Measurement of Fluid Flow in Pipes Using Orifice, Nozzle & Venturi
    ASME MFC-3M-1990 Errata to 1989
    ASME MFC-3M-2004 Measurement of Fluid Flow in Pipes Using Orifice, Nozzle, and Venturi
    ASME MFC-3Ma-2007 Addenda to ASME MFC-3M–2004 Measurement of Fluid Flow in Pipes Using Orifice, Nozzle, and Venturi
    ASME MFC-4M-1986 Measurement of Gas Flow by Turbine Meters
    ASME MFC-5.1-2011 Measurement of Liquid Flow in Closed Conduits Using Transit-Time Ultrasonic Flowmeters
    ASME MFC-5.3-2013 Measurement of Liquid Flow in Closed Conduits Using Doppler Ultrasonic Flowmeters
    ASME MFC-5M-1985 Measurement of Liquid Flow in Closed Conduits Using Transit-Time Ultrasonic Flowmeters
    ASME MFC-6M-1998 Measurement of Fluid Flow in Pipes Using Vortex Flowmeters
    ASME MFC-6M-1998 R2005 Measurement of Fluid Flow in Pipes Using Vortex Flowmeters
    ASME MFC-7M-1987 Measurement of Gas Flow by Means of Critical Flow Venturi Nozzles
    ASME MFC-8M-2001 Fluid Flow in Closed Conduits; Connections for Pressure Signal Transmissions Between Primary and Secondary Devices
    ASME MFC-9M-1988 Measurement of Liquid Flow in Closed Conduits by Weighing Method
    ASME MFC-10M-2000 Method for Establishing Installation Effects on Flowmeters
    ASME MFC-11M-2003 Measurement of Fluid Flow by Means of Coriolis Mass Flowmeters
    ASME MFC-11M-2006 Measurement of Fluid Flow by Means of Coriolis Mass Flowmeters
    ASME MFC-12M-2006 Measurement of Fluid Flow in Closed Conduits Using Multiport Averaging Pitot Primary Elements
    ASME MFC-13M-2006 Measurements of Fluid Flow in Closed Conduits; Tracer Methods
    ASME MFC-14M-2003 Measurement of Fluid Flow Using Small Bore Precesion Orifice Meters
    ASME MFC-16M-1995 Measurement of Fluid Flow in Closed Conduits by Means of Electromagnetic Flowmeters
    ASME MFC-18M-2001 Measurement of Fluid Flow Using Variable Area Meters
    ASME MFC-19G-2008 (Technical Report) Wet Gas Flowmetering Guideline
    ASME MFC-21.2–2010 Measurement of Fluid Flow by Means of Thermal Dispersion Mass Flowmeters
    ASME MFC-22-2007 Measurement of Liquid by Turbine Flowmeters
    ASME MFC-26-2011 Measurement of Gas Flow by Bellmouth Inlet Flowmeters
    zip, Pass: egpet.net
    See More: ASME MFC std
    Re: ASME MFC std
    password plzzzzzz
    Re: ASME MFC std
    password plzzzzzz
  6. #16
    Re: ASME MFC std
    Quote Originally Posted by sja View Post
    password plzzzzzz
    Dear Sir
    Read the final text in the post#13 Pass: egpet.net
    My threads; zapata :
    • #17
      Re: ASME MFC std
      password plzzzzzz
      Dear Sir
      •    Spons.
      • Re: ASME MFC std
        Can anyone please re-share this? link no longer working. Thanks in advance!
        My threads; HiTMaN-239 :
        • Re: ASME MFC std
          Bumping in the hopes that someone would reupload these files.
          My threads; wharwood :
          • #20
          • Re: ASME MFC std
            Thank you!
            • #22
              Re: ASME MFC std
              Quote Originally Posted by gtpol57 View Post
              Try
              thanks, dear friends the link is active.
              My threads; cvz240159 :
            • Re: ASME MFC std
              The link is still active. Thank you for re-posting.
              My threads; ntdanh :
              •    Spons.
              • Re: ASME MFC std
                Thank you
                My threads; Alternsti :
              1. ASME PTB-3-2013 asme section viii div.2 ,example problem manual
                By lois in forum Mechanical Engineering
                Last Post: 10-01-2018, 03:02 PM
              2. Replies: 1
                Last Post: 07-29-2014, 10:26 PM
              3. Difference between ASME IX 2013 and ASME IX 2010 Add.2011
                By yakkidudu in forum Oil And Gas Production
                Last Post: 02-06-2014, 01:48 PM
              4. Need Guide For Asme Stamp Holders ASME A15100
                By PINTAIUS in forum Mechanical Engineering
                Last Post: 10-07-2012, 10:09 PM
              5. ASME PTB-3-2010 asme section viii div.2 ,example problem manual
                By sharmilasu in forum Mechanical Engineering
                Last Post: 04-22-2012, 06:57 AM
