Results 1 to 9 of 9
Thread: OLGA Buried pipe
    Jan 2009
    somewhere on the earth
    OLGA Buried pipe
    Dear Engineers
    How can I model the buried pipe in OLGA? Could I define the outer wall as soil with 1.5 m thickness?
    See More: OLGA Buried pipe
    Advertising world
  3. OLGA Buried pipe
    Following both options will give the same results.
    You can calculate equivalent burial depth using the equation from OLGA users manual
    OR
    Use the actual burial depth (if it is 1.5 m) and descretize the soil layer. When you descretize the wall, it should be noted that the ratio of adjacent wall thickness should be <=5
    Regards,
    FluidFlow
    Jan 2009
    Jan 2009
    Dear FluidFlow
    I've buried a pipe as the attached scheme (1 meter underground), then defined a soil wall with 1 meter thickness. my question is: what are the ambient T and K? note that the 3 sides of the pipes is surrounded by soil and the 4th side surrounded by air.
    thanx engineer
  7. #5
    Jan 2009
  9. interesting discussion
    My threads; its_iwan :
    • #7
      Dear motaleby,
      May I get other manual of OLGA 7? Thanks before
      My threads; AAN :
      • #8
        Jan 2009
      • Re: OLGA Buried pipe
        Hi Fluid flow,
        I came across same problem recently but didnt find a solution, pls. if you can tell the equations from olga manual for this as i am unable to find them. Also, if you can elaborate further on the soil descretize option.
        thanks in advance.
        Regards,
        Abhineet
        My threads; abhineet :
        1. Buried Flexible Pipe
          By kacu_88 in forum Pipeline And Fluid Flow
          Last Post: 12-19-2013, 01:06 PM
        2. buried pipe in stainless steel
          By giruffo in forum Materials Science &Corrosion
          Last Post: 06-15-2013, 03:27 PM
        3. Buried Pipe
          By Mr Welder in forum Mechanical Engineering
          Last Post: 03-24-2013, 10:15 AM
        4. Article: OLGA Buried pipe
          By motaleby in forum Home Articles
          Last Post: 12-19-2011, 04:22 AM
        5. protection for the buried pipe
          By cytech in forum Materials Science &Corrosion
          Last Post: 02-27-2011, 07:24 AM
