Page 2 of 2 FirstFirst 1 2
Results 13 to 15 of 15
Thread: Article: Coating in Petroleum storage tank
  1. #13
    Nov 2009
    All over EGPET
    Blog Entries
    1
    Thks
    See More: Article: Coating in Petroleum storage tank
    My threads; npsrinivasarao :
  3. The above reference "Tank_Linings_for_Chemical_Process_Industries" is unlikely to be suitable for fuel as it is for rubber linings. Petrol, diesel and Jet A-1 (kerosene) storage tanks, if to be lined are lined with an epoxy coating, and Jotun will make one. The epoxy should not (a) deteriorate in contact with petroleum fuels; and (b) affect the fuel that is being stored. The paint manufacturer should state this on his data sheet. In the case of Jet A-1 it is usual to ask the paint manufacturer of evidence that the internal coating has been tested and approved by a major international oil company. Sometimes it says this on the data sheets.
    Externally the coating is different, (one of the reasons being that epoxy deteriorates in sunlight.
    Often petrol and diesel storage tanks are not lined at all on the inside, but can be. Often the floor only with the first 500 mm up the wall only is lined. For Jet A-1 the floor at least should be lined. Lining allows the corrosion allowance to be reduced or a situation that is borderline according to API 653 to be arrested.
    External coating is traditionally a three coat system, namely inorganic zinc / epoxy / polyurethane (acrylic modified). The inorganic zinc is suited to a shop applied system (needs abrasive blast preparation, can require moisture to cure), and so epoxy zinc can be substituted instead. The epoxy can have a miscellaneous filler, or MIO (micaceous iron oxide) or glass flake, depending on the weather exposure and price. MIO can also be the top coat (even though epoxy), if a grey colour is acceptable). Another alternative is to have a polysiloxane system (polysiloxane can be epoxy modified - PPG brand, or acrylic modified - International brand). A left field is a water bourne inorganic zinc and overcoat with water bourne acrylic (requires blast surface to start with). With the polysiloxane versus traditional urethane, the polysiloxane is more expensive, but the manufacturer may be able to design a two coat system rather than three coat system, saving labour. Coating choice may depend on coating application method, eg blast versus roller, encapsulating the tank to capture spray drift and/or quick drying selection.
    If the tanks have an existing external coating on them and sound coating is to remain, then the answer may be different.
    Manufacturers can be Jotun, International, PPG, for example.
    Jiminy
    My threads; Jiminy Cricket :
  5. Enilson, podrias enviarme una copia, por favor. Gracias
    marcant622@yahoo.com. Gracias Ednilson
    My threads; marcant622 :
    1. API Petroleum Storage Tank Design
      By surendra.bhatkar in forum Safety And Environment
      Last Post: 02-05-2014, 09:12 AM
    2. Article: Coating in storage tank
      By sumon emam in forum Home Articles
      Last Post: 03-23-2011, 09:43 AM
    3. Coating in storage tank
      Last Post: 03-22-2011, 01:26 AM
    4. Article: Coating in storage tank
      Last Post: 01-22-2011, 12:52 PM
    5. Coating in Petroleum storage tank
      Last Post: 01-18-2011, 05:05 PM
