Page 1 of 2 1 2 LastLast
Results 1 to 12 of 17
Thread: ETAP 20.0.0 Isues
  1. ETAP 20.0.0 Isues
    I wonder if anyone can help with the SC issue on the ETAP 20.0.0 - It seems that the Etap 20 device duty evaluation for 1-phase is greyed out (disabled).
    Does anyone have any knwledge how could it be resolved?
    See More: ETAP 20.0.0 Isues
  5. Re: ETAP 20.0.0 Isues
    I did just that... I had working 19.0.1 ... then I have installed 20.0.0. Everything works fine for the exception of the 1-Phase short circuit module... Any idea ?
    also have a problem with the svg, or EMF file export for one line diagrams an tcc curves.
    other is that when you work with tcc and sequence of operation the curve is not plotted when use the SOP display on TCC graph.
    OK, interesting, u have Etap 20 pls share to discuss about the issues among different users. Iwork with 19.0.1 and make many 1Phase analysis, sc, vd, panelboards, and others
    My threads; Henryrcp :
    •    Spons.
    • #6
    • #7
      In Etap 19 can't use gis support, i watch any videos in youtube but not work in etap 19. Trying use google map, arcgis and qgis. If any forum meberr here can help me, pls.
      • Re: ETAP 20.0.0 Isues
        As before, the 19.0.1 version is perfect in the sence that most of the modules I have looked at, worked fine. The 20.0.0 version recently obtained with two ********d files, has couple of hickups, namely - 1ph Short Circuit and 1-ph Arc Flash. Can any one offer the solution...
        This is un-********d version:
        ____https://drive.google.com/u/0/uc?id=1gMtyBOBsYBtm-1De6TLVNQuTa2X2GXix&export=download______
      • #10
        Hi Parallax share the vaccine, I install with etap 19.0.1 and not work etap 20.0.0
        • #11
          Hi all, pls comment how make that etap 20 work with etap 19 installed. i have instaled de E19 but E20 not work
          •    Spons.
            I do not have a working ******** for the 20
          1. Etap 12.6
            By shengna in forum Electrical & Power Engineering
            Last Post: 03-08-2017, 05:09 AM
          2. Etap v12.5
            By alito_77 in forum Electrical & Power Engineering
            Last Post: 07-10-2015, 03:01 AM
          3. ETAP v12
            By smzakaullah in forum Electrical & Power Engineering
            Last Post: 02-20-2015, 04:19 PM
          4. Etap 11.0
            By maximiliano_capote in forum Electrical & Power Engineering
            Last Post: 02-09-2015, 10:39 AM
          5. Etap v.7
            By METHAQ in forum Electrical & Power Engineering
            Last Post: 10-18-2013, 10:49 PM
