REFERENCE TOPIC: ETAP "Steady-State temp. calc. did not converge in the max. number of iterations"
Hello ETAP users,
Has anyone received a Cable Derating Error message while running the Steady State Temperature Calculation on the Under Ground Duct system:
"Steady-State temperature calculation did not converge in the maximum number of iterations"
I have increased the number of iterations to 10000 in etaps.ini. The error goes away if i reduce the RHO to lower than 90 value.
Please assist if you had anything like this.
Paralax
See More: ETAP "Steady-State temp. calc. did not converge in the max. number of iterations"
