Thread: ETAP "Steady-State temp. calc. did not converge in the max. number of iterations"
  1. ETAP "Steady-State temp. calc. did not converge in the max. number of iterations"
    Hello ETAP users,
    Has anyone received a Cable Derating Error message while running the Steady State Temperature Calculation on the Under Ground Duct system:
    "Steady-State temperature calculation did not converge in the maximum number of iterations"
    I have increased the number of iterations to 10000 in etaps.ini. The error goes away if i reduce the RHO to lower than 90 value.
    Please assist if you had anything like this.
    Paralax
    See More: ETAP "Steady-State temp. calc. did not converge in the max. number of iterations"
    Re: ETAP "Steady-State temp. calc. did not converge in the max. number of iterations"
    Would it be possible if you share the project file? So that we can review it.
