Thread: Article: Process Parameters in Consequence Analysis SafeSite3G
  1. Article: Process Parameters in Consequence Analysis SafeSite3G
    You can view the page at
    See More: Article: Process Parameters in Consequence Analysis SafeSite3G
  3. Re: Article: Process Parameters in Consequence Analysis SafeSite3G
    If the line has continuous source of supply i.e. pump or compressor and during release it will continually run then then take the max/pump rated flow, else if it is tank, or the tube/line rupture/leak then take the depressurization model i.e. what the simulation software is calculating for you. For depressurization model: if tank/line pressure is higher then it will lead to max discharge velocity i.e. Sonic velocity, and based on it simulation software will calculate release temperature.
    My threads; nahs001 :
  5. The leak flow rate can be higher than the PFD flow rates if the source pressure are higher and leak area is relatively bigger.
    Considering Upstream system is infinite and could supply the released flow for longer time, consider the steady statte flow rate estimated by the FRED or other software.
    Whereas if the system inventory is finite and leak lead to reduction in inventory, consider depressurising rates which will reduces with time. Depressurization rates can be estimated by HYSYS or PRO II.
    BR
    My threads; hmahesh :
    1. Process Parameters in Consequence Analysis SafeSite3G
      By hammad15 in forum Engineering Software Tutorial
      Last Post: 07-24-2019, 11:43 PM
    2. Replies: 7
      Last Post: 01-18-2017, 10:30 PM
    3. LNG RISK BASED SAFETY: Modeling and Consequence Analysis
      By Cecile_P in forum Safety And Environment
      Last Post: 11-18-2016, 05:44 AM
    4. Guidelines for Consequence Analysis of Chemical Releases
      By Mohamed in forum Safety And Environment
      Last Post: 08-18-2014, 11:49 PM
    5. Guidelines for Consequence Analysis of Chemical Releases
      By Kot in forum Safety And Environment
      Last Post: 01-18-2013, 06:31 PM
