  1. Horizontal tank design
    Hello colleagues, I am developing a horizontal storage tank, my question is if it can be done with api 650 or if another standard should be used.
    I appreciate your response.
    See More: Horizontal tank design
    Re: Horizontal tank design
    You may use EN 12285-2 Workshop fabricated stel tanks, Part 2: Horizontal cylindrical single skin and double skin tanks for the aboveground storage of flammable and non-flammable water polluting liquids.
    In the scope of API 650 can find contradicting limits: ... for vertical ... tanks; ... entire bottom uniformly supported ... so this seems to be not applicable.
    But I am European and not so much familiar with the API range od standards, so you have to decide and find out,
    explosion
    By saladisa in forum Pipeline And Fluid Flow
    Last Post: 07-30-2019, 07:24 PM
  2. Code for aboveground horizontal storage tank
    By caca in forum Mechanical Engineering
    Last Post: 12-10-2018, 06:59 AM
  3. Stability check for the underground horizontal steel tank
    By Kavinda Bandara in forum Pipeline And Fluid Flow
    Last Post: 12-22-2013, 09:12 AM
  4. Replies: 0
    Last Post: 07-21-2011, 10:31 PM
  5. UL-142 Horizontal Tank
    By AbdNic in forum Mechanical Engineering
    Last Post: 04-08-2009, 05:15 AM
