ipt type="text/javascript"> (fun
Thread: Oil and gas flushing helps to maintained pipeline
    OIL AND GAS FLUSHING HELPS TO MAINTAINED PIPELINE
    Flushing is a routine process to maintain pipeline quality by moving high velocities of oil or gas through a hydrant, for a short duration to remove any particles or materials build up that may have been dislodged from the pipe.
    Oil and gas flushing remove harmful contaminants and keep your new rotating and hydraulic equipment and operating at peak performance; significantly reducing the potential for premature failure.
    Contaminants such as water, rust, loose scale, weld slag, sand, dirt, and oils are removed from the system with a proper pre-operational cleaning, reducing the wear, scoring, and damage bearings, control valves, instrumentation, and critical operating systems are subjected to. Insoluble particles can become trapped in the bearings of rotating equipment and cause significant damage.
    Some of the benefits of oil and gas flushing are as follows:
    Remove deposit build up
    Give your pipeline a clean slate
    Keep new oil and gas clean
    Clean up what the filter misses
    Clean engine parts
    We currently based in Port-Harcourt and hope to extend operation to other part of the country. Flushing is one of our works; we deliver home service if you want us to. For more information visit our website, Kezif Integrated Resources limited.or click on this link to visit our website
    See More: Oil and gas flushing helps to maintained pipeline
    Re: Oil and gas flushing helps to maintained pipeline
    Good..
    My threads; bar007 :
    •    Sponsored Links
    1. Heat Exchanger Flushing
      By praphulla.phirke in forum Materials Science &Corrosion
      Last Post: 07-14-2016, 04:11 PM
    2. Need your helps
      By nguyentb in forum Oil And Gas Production
      Last Post: 04-28-2015, 02:11 PM
    3. Seal Flushing Line
      By hammad_nrl in forum Oil And Gas Process
      Last Post: 03-27-2013, 01:45 AM
    4. Reservoir Water Flushing?
      By Hmida in forum Reservoir
      Last Post: 11-10-2009, 01:00 AM
    5. Reservoir Water Flushing
      By Hmida in forum Geology & Exploration
      Last Post: 11-10-2009, 12:59 AM
