  1. Chemical Process Safety: Fundamentals with Applications, 3rd Edition
    Table of Contents
    Preface xv
    About the Authors xvii
    On the Cover xviii
    Nomenclature xix
    Chapter 1: Introduction 1
    1-1 Safety Programs 2
    1-2 Engineering Ethics 4
    1-3 Accident and Loss Statistics 4
    1-4 Acceptable Risk 12
    1-5 Public Perceptions 14
    1-6 The Nature of the Accident Process 15
    1-7 Inherent Safety 20
    1-8 Seven Significant Disasters 23
    Suggested Reading 31
    Problems 32
    Chapter 2: Toxicology 37
    2-1 How Toxicants Enter Biological Organisms 38
    2-2 How Toxicants Are Eliminated from Biological Organisms 41
    2-3 Effects of Toxicants on Biological Organisms 42
    2-4 Toxicological Studies 43
    2-5 Dose versus Response 44
    2-6 Models for Dose and Response Curves 50
    2-7 Relative Toxicity 56
    2-8 Threshold Limit Values 56
    2-9 National Fire Protection Association (NFPA) Diamond 58
    On-Line Resources 59
    Suggested Reading 60
    Problems 60
    Chapter 3: Industrial Hygiene 65
    3-1 Government Regulations 66
    3-2 Industrial Hygiene: Anticipation and Identification 78
    3-3 Industrial Hygiene: Evaluation 84
    3-4 Industrial Hygiene: Control 99
    On-Line Resources 109
    Suggested Reading 109
    Problems 110
    Chapter 4: Source Models 119
    4-1 Introduction to Source Models 119
    4-2 Flow of Liquid through a Hole 122
    4-3 Flow of Liquid through a Hole in a Tank 126
    4-4 Flow of Liquids through Pipes 131
    4-5 Flow of Gases or Vapors through Holes 140
    4-6 Flow of Gases or Vapors through Pipes 146
    4-7 Flashing Liquids 163
    4-8 Liquid Pool Evaporation or Boiling 169
    4-9 Realistic and Worst-Case Releases 170
    4-10 Conservative Analysis 172
    Suggested Reading 173
    Problems 174
    Chapter 5: Toxic Release and Dispersion Models 185
    5-1 Parameters Affecting Dispersion 186
    5-2 Neutrally Buoyant Dispersion Models 190
    5-3 Dense Gas Dispersion 209
    5-4 Dense Gas Transition to Neutrally Buoyant Gas 219
    5-5 Toxic Effect Criteria 225
    5-6 Effect of Release Momentum and Buoyancy 233
    5-7 Release Mitigation 234
    Suggested Reading 235
    Problems 236
    Chapter 6: Fires and Explosions 245
    6-1 The Fire Triangle 245
    6-2 Distinction between Fires and Explosions 247
    6-3 Definitions 247
    6-4 Flammability Characteristics of Liquids and Vapors 249
    6-5 Limiting Oxygen Concentration and Inerting 260
    6-6 Flammability Diagram 262
    6-7 Ignition Energy 270
    6-8 Autoignition 270
    6-9 Auto-Oxidation 271
    6-10 Adiabatic Compression 272
    6-11 Ignition Sources 273
    6-12 Sprays and Mists 274
    6-13 Explosions 275
    Suggested Reading 304
    Problems 305
    Chapter 7: Concepts to Prevent Fires and Explosions 317
    7-1 Inerting 318
    7-2 Static Electricity 333
    7-3 Controlling Static Electricity 356
    7-4 Explosion-Proof Equipment and Instruments 363
    7-5 Ventilation 367
    7-6 Sprinkler Systems 370
    7-7 Miscellaneous Concepts for Preventing Fires and Explosions 374
    Suggested Reading 374
    Problems 375
    Chapter 8: Chemical Reactivity 381
    8-1 Background Understanding 382
    8-2 Commitment,Awareness, and Identification of Reactive Chemical Hazards 384
    8-3 Characterization of Reactive Chemical Hazards Using Calorimeters 390
    8-4 Controlling Reactive Hazards 416
    Suggested Reading 418
    Problems 418
    Chapter 9: Introduction to Reliefs 429
    9-1 Relief Concepts 430
    9-2 Definitions 432
    9-3 Location of Reliefs 433
    9-4 Relief Types and Characteristics 436
    9-5 Relief Scenarios 443
    9-6 Data for Sizing Reliefs 444
    9-7 Relief Systems 444
    Suggested Reading 452
    Problems 453
    Chapter 10: Relief Sizing 459
    10-1 Conventional Spring-Operated Reliefs in Liquid Service 460
    10-2 Conventional Spring-Operated Reliefs in Vapor or Gas Service 466
    10-3 Rupture Disc Reliefs in Liquid Service 470
    10-4 Rupture Disc Reliefs in Vapor or Gas Service 471
    10-5 Two-Phase Flow during Runaway Reaction Relief 472
    10-6 Pilot-Operated and Bucking-Pin Reliefs 481
    10-7 Deflagration Venting for Dust and Vapor Explosions 481
    10-8 Venting for Fires External to Process Vessels 488
    10-9 Reliefs for Thermal Expansion of Process Fluids 492
    Suggested Reading 496
    Problems 497
    Chapter 11: Hazards Identification 505
    11-1 Process Hazards Checklists 508
    11-2 Hazards Surveys 508
    11-3 Hazards and Operability Studies 524
    11-4 Safety Reviews 530
    11-5 Other Methods 537
    Suggested Reading 538
    Problems 538
    Chapter 12: Risk Assessment 549
    12-1 Review of Probability Theory 550
    12-2 Event Trees 564
    12-3 Fault Trees 569
    12-4 QRA and LOPA 577
    Suggested Reading 588
    Problems 588
    Chapter 13: Safety Procedures and Designs 597
    13-1 Process Safety Hierarchy 598
    13-2 Managing Safety 599
    13-3 Best Practices 600
    13-4 ProceduresOperating 600
    13-5 ProceduresPermits 601
    13-6 ProceduresSafety Reviews and Accident Investigations 603
    13-7 Designs for Process Safety 604
    13-8 Miscellaneous Designs for Fires and Explosions 615
    13-9 Designs for Runaway Reactions 615
    13-10 Designs for Handling Dusts 616
    Suggested Reading 617
    Problems 618
    Chapter 14: Case Histories 621
    14-1 Static Electricity 622
    14-2 Chemical Reactivity 626
    14-3 System Designs 631
    14-4 Procedures 637
    14-5 Training 642
    14-6 Conclusion 645
    Suggested Reading 646
    Problems 646
    Appendix A: Unit Conversion Constants 649
    Appendix B: Flammability Data for Selected Hydrocarbons 653
    Appendix C: Detailed Equations for Flammability Diagrams 659
    Equations Useful for Gas Mixtures 659
    Equations Useful for Placing Vessels into and out of Service 664
    Appendix D: Formal Safety Review Report for Example 10-4 669
    Appendix E: Saturation Vapor Pressure Data 679
    Appendix F: Special Types of Reactive Chemicals 681
    Appendix G: Hazardous Chemicals Data for a Variety of Chemical Substances 687
    Index 695
    See More: Chemical Process Safety: Fundamentals with Applications, 3rd Edition
    Re: Chemical Process Safety: Fundamentals with Applications, 3rd Edition
    Thanks for sharing
  1. Replies: 2
    Last Post: 08-12-2015, 01:18 PM
  2. Chemical Process Safety: Fundamentals with Applications, 3rd Edition
    By selmagis in forum Safety And Environment
    Last Post: 01-20-2014, 11:45 AM
  3. Chemical Process Safety: Fundamentals with Applications
    By Mohamed in forum Safety And Environment
    Last Post: 08-15-2013, 08:45 AM
  4. Chemical Process Safety, Fundamentals with Applications
    By orquidea in forum Safety And Environment
    Last Post: 05-27-2013, 05:57 AM
  5. Chemical Process Safety: Fundamentals with Applications
    Last Post: 05-12-2013, 11:51 AM
