Does anyone knows where can I find any of this:
• ASTM A27 / A27M – 17 Standard Specification for Steel Castings* Carbon* for General Application
• ASTM A668 / A668M – 17 Standard Specification for Steel Forgings* Carbon and Alloy* for General Industrial Use
• ASTM A781 / A781M – 17 Standard Specification for Castings* Steel and Alloy* Common Requirements* for General Industrial Use
• ASTM B311 – 17 Standard Test Method for Density of Powder Metallurgy (PM) Materials Containing Less Than Two Percent Porosity
• ASTM D86 – 17 Standard Test Method for Distillation of Petroleum Products and Liquid Fuels at Atmospheric Pressure
• ASTM D92 - 16b Standard Test Method for Flash and Fire Points by Cleveland Open Cup Tester
• ASTM D97 - 17a Standard Test Method for Pour Point of Petroleum Products
• ASTM D445 - 17a Standard Test Method for Kinematic Viscosity of Transparent and Opaque Liquids (and Calculation of Dynamic Viscosity)
• ASTM D975 – 17 Standard Specification for Diesel Fuel Oils
• ASTM D2500 - 16b Standard Test Method for Cloud Point of Petroleum Products and Liquid Fuels
• ASTM E23 - 16b Standard Test Methods for Notched Bar Impact Testing of Metallic Materials
• ASTM E649 – 17 Standard Test Method for Bromine in Chlorine
thanks in advace
These are old collections* I will not reload them* go to the Telegram channel for the latest. (I will not explain any more how to get there* it has been stated too many times on here already)
Hi Marty*
Do you have Concrete Society Technical Report TR61* please?
Thanks*
Kind Regards*
Binod
Hi Friends
Please I need 05.06 Gaseous Fuels; Coal and Coke; Bioenergy and Industrial Chemicals from Biomass
but the link for not found
Could you upload again* please?
Thank you
Hello Friends*
I need ASTM Volume 03.01 Metals -- Mechanical Testing_ Elevated and Low-Temperature Tests_ Metallograph 2015/2016. Please share link so that I can download. Can anyone please upload it?
Thank you in advance.
Dear friends*
Do anyone have the latest ASTM D4814 Standard Specification for Automotive Spark-Ignition Engine Fuel? Appreciate if this can be shared.
Thank you and regards
You can find all on the Telegram GroupEgpet D4814-17 5.02
Thanks Marty.
Dear Friends
All ASTM 2015
Updated link
Dear
I have require ASTM E 23-2016b plese give me pdf file
