Guys,
Please refer to my post and provide any help if you can. I'm not able to access anything b/c the site that loads up when you click on the .exe file is not available. Any suggestions?
Guys,
Dear msaad2
I downloaded shell DEP 25 and tried the following two options:
1- Unzipped the rar files in one folder then clicked dyncd.exe. Website[link Point to another website Only the registered members can access]
2- Followed same procedure as above but operating system was windows vista without internet connection (i.e. off line).
First option worked perfectly but second option didn't work and same message appeared in second option as you have mentioned.
So two possible reasons of failure are compatibility problems with windows vista and working off-line. I believe second reason is the valid reason as dyncd.exe attempts to open the webpage with the address given in your text. This page cannot be opened off-line. I don't know content of this page are available within the download stuff or net. But even if this page is available off-line with the downloaded contents, atleast dyncd.exe doesn't direct to local file because in this case browser will show address like C:\Shell DEP\dyncd\depsweb.asp i.e. address of the folder where this file must be present.
Our friend Polaris44 advised that contens can be explored even off-line. I couldn't succeed. I'll require further advise in this context.
I'll conclude by saying that please try on-line. If you are online but still unsuccessful then you must be using windows visata. If this is also not the case then let some other friend help us.
Thanks and Regards
Processor,
I reinstalled all the files, extracted all 5 files and I'm still getting nowhere. I do not have Windows vista, and my connection is Cable so I am always online. The offline option is not working either. I am actually curious to see how other people got this to work. Please if anyone has any inpute please let me know!
Thanks,
msaad2
Dear Guys,
I tried both online and offline in windows vista but not working in either case as you said. Is there any settings to be modified in windows vista to open these files?
I heard by Turn OFF - The User Authorisation Control in vista will help but really don't howfar that is true.
Help us in getting this work.
Aisnop
AISNOP,
you might need to install IIS from the windows installation CD.
This is a link of an older version DEP V23 if you wish to download from :
May take a while to download. The file size is about 150 Mb
Dear Friends I too had problem in accessing the DEP with vista. But with XP it is working fine.
suresh
i need too please
I need this information please
Thank you
