Page 7 of 8 FirstFirst ... 5 6 7 8 LastLast
Results 73 to 84 of 88
Thread: Chemstation's ChemCAD v6.1.3
  1. Dresden,
    in the start menu you must click on "run". Then write cmd and press ok. You will prompted in DOS mode. Write ipconfig then press enter. It will be displayed your local machine IP address like xxx.yyy.z.ttt.
    Superandy
  3. Thanks for info Superandy !!!
    Part 1 is available
  6. #76
    thanks superandy, but I haven't a network (wireless or lan) on this partition. please help
  7. #77
    thanks you
  9. #78
    Install Chemcad and license server on the same machine and use the machine IP address
  10. #79
    the mac-adress?
    thanks a lot
  11. #80
    For my 6.3.1 ******** you define server with IP address not the mac address. You don't need a network, at a minimum your localhost 127.0.0.1 should even work
  12. #81
    chemcad 6.3.1 is running.
    Thank you very much, you are great
  13. I'm sorry, I've tried the installation and ******** until step 6 in the instruction text. But when it is said to "Open Chemcad" in step 7, the Chemcad encounter problem and need to close....
    Is there any problem to installation file or the ********??
  14. #83
    You should open Chemcad it should show license setup screen, if you have an error before this then something wrong with the install. Try restart machine, and if does not work try reinstall
  16. No, when I open ChemCad, it didn't show license setup screen. It tell that something wrong with Chemcad and need to be closed. I download the chemcad from ifile.it link But, when setup ******** for IP address, you use your IP adress (from run cmd>ipconfig) or just typing 127.0.0.1??
  1. Chemcad
    By shkene in forum Pipeline And Fluid Flow
    Last Post: 10-05-2013, 06:58 PM
