Page 6 of 7 FirstFirst ... 4 5 6 7 LastLast
Results 61 to 72 of 76
Thread: AWWA Standards Please
  1. #61
    Re: AWWA Standards Please
    Guy's do u have AWWA C-602 2011 edition thanks
  5. Re: AWWA Standards Please
    Please see the attachement for AWWA C602-2006.
    Greetings
    Abo Khaled
    Attached Files Attached Files
  6. #64
    hi. i attached AWWA C602 - 2011 edition
  7. Re: AWWA Standards Please
    please share AWWA C200-2012
  9. #66
    Feb 2009
    Jubail KSA
    Blog Entries
    1
    Quote Originally Posted by hamid1469 View Post
    i have 1997 ver
  10. #67
    I have 2005
  11. #68
    Jul 2009
    Karachi, Pakistan
    Please share
    AWWA C203-08 Coal-tar Protective Coatings & Linings
    Thank you.
  12. Re: AWWA Standards Please
    any one please upload c 516
  13. #70
    Hi
    Does anyone have this Standard:
    AWWA C215-5.4
    Please Share it.
  14. #71
    C215- Section 5.4
    Coated-Pipe Tests
    5.4.1 Electrical inspection for continuity. Each coated pipe section shall be electrically tested with a suitable holiday detector as approved by the purchaser for flaws in the coating. The detector shall impress a minimum voltage as specified by NACE RP0274.The electrical inspection shall be performed on the extruded coating system. Defects disclosed by the holiday detector shall be repaired at the coating plant according to Sec. 4.5 of this standard. If the number of holidays exceeds an average of one per 10 ft2 (0.93 m2) per length of pipe, the pipe shall be double coated and reinspected as specified in Sec. 4.5.1.
    5.4.2 Coating-thickness measurement. The thickness of the coating systems shall be measured according to ASTM G12. The thickness shall be as stated in Table 4 and shall be checked at a frequency specified by the purchaser. Measurements less than specified shall constitute failure and shall require double coating as specified in Sec. 4.5.1.
    AWWA C215-2004 Extruded Polyolefin Coatings for the Exterior of Steel Water Pipelines
  16. #72
    I have 2008 Ed.
    Quote Originally Posted by ra_junaidi View Post
    Please share
    Thank you.
  1. Replies: 13
    Last Post: 07-24-2019, 06:46 PM
  2. AWWA Standards
    By mohsenkalantar in forum Materials Science &Corrosion
    Last Post: 03-27-2017, 01:28 PM
  3. AWWA Standards
    By subin in forum Pipeline And Fluid Flow
    Last Post: 06-26-2014, 02:24 PM
  4. Awwa
    By cristof1913 in forum Pipeline And Fluid Flow
    Last Post: 04-16-2014, 03:30 AM
  5. Awwa c203 & awwa c214
    By turbosri_mech in forum Mechanical Engineering
    Last Post: 11-08-2009, 05:59 AM
