Page 6 of 10 FirstFirst ... 4 5 6 7 8 ... LastLast
Results 61 to 72 of 110
Thread: Epcon - API Technical Data Book - Oil and Gas industry
  1. Thanks for sharing!
    Quote Originally Posted by Mohamed View Post
    The Brains Behind the Business™
    Beginning in 1966 some of the brightest minds in the Oil and Gas Industry put together the best available phase equilibrium and thermophysical property data and published the first edition of the API Technical Data Book. This work of the API Tech Data Committee has continued for 40 years. Now, all of that data and information from four decades of hard work have been distilled into the 40th Anniversary Edition of the API Tech Data Book (the 8th Edition).
    A Software Solution
    API’s flagship product is deployed as an easy to use software package covering the fundamentals of thermophysical properties and process engineering. The API Technical Data Book allows you to accurate evaluate hydrocarbon processing systems with it’s 130+ recommedned API methods and 20 + software programs – a must-have resource that engineers working in the Oil and Gas industry rely on to further their know-how and careers.
    A Re-Mastered Printed Data Book
    You can navigate quickly to find desired API procedures, review their recommended use and application, and then directly access software specifically designed to implement those procedures. All of the API Technical Data Book figures and tables have been included and digitally optimized for best quality in both the electronic and printed 3-volume desk reference set.
    The 40th Anniversary Edition of the API Technical Data Book is a result of the top U.S. oil and natural gas experts’ working together. As the standard for Phase Equilibrium and Thermophysical Properties, the API Technical Data Book 8 is a vital engineering resource you need to help you get the job done right.
    With unmatched accuracy, the 40th Anniversary Edition of the API Technical Data Book can help you optimize your plant for profit and safety. This powerful software suite was built on a rock-solid foundation:
    40 Years of API-Funded Research and Development
    Participation by 127 Leading Thermodynamics Experts
    Development of 161 API Physical Property Methods
    Based on 2,000+ Technical References and Resources
    Rigorous 3-Phase Flash/Mixture Calculations
    We filled a book with all of the data you need to get the job done right. Get API’s know-how, right now with the API Technical Data Book 8 – 40th Anniversary Edition.
    The Birth of the Electronic Version
    Upon completion of the thirteenth revision package in 1998 by Penn State, API and the Tech Data Committee openly solicited bids to convert the API Technical Data Book into an interactive software application with a modern interface design. The objective was to enhance the usefulness of the API Technical Data Book and generate income to support the ongoing research and development of the Tech Data Committee. EPCON International was selected to develop this new electronic version of the API Technical Data Book. In 2005, EPCON released the Seventh Edition with full software coverage and a re-mastered, printed Data Book.
    Software Development Effort
    The first phase of this software development effort provided a Windows based application for Chapters 1 through 4 of the API Technical Data Book in 1998. The second phase of the software development provided a flash/mixture module for applicable methods and a new method for pseudo component generation in 2000. The third phase of the software development provided complete coverage of all 130+ methods recommended by the API Tech Data Committee and included EPCON’s rigorous 3-phase flash along with a scanned graphical file of all chapter introductions for all computerized/recommended methods in 2002. In the fourth phase of this software development effort, the printed API Technical Data Book was re-mastered from the non-searchable graphical form of the Sixth Edition. The Seventh Edition provided true text, searchable format to provide direct interaction between the documented procedures and the software implementation of these procedures. Additional improvements were made in the implementation of the computer methods as software applications in this first fully electronic API Technical Data Book software product. The fifth phase of the software redevelopment included correction of any reported bugs and additional features requested by the committee
    Download all three files and save them in the same folder
    after click on Epcon_API_TECHNICAL_DATA_BOOK_7.rar
    and extract the cont.
    Is all in one file link
    (240MB)
    Splitted Archives to three links
    Splitted Archives each less than 40 MB
    thanks a lot.
    Muhammad Khurram
  6. Thank a lot....
    good working
    Regards....
  7. #65
    Thank you. Can I calculate the solid phase using this program?
  9. #66
    Does any one can share this book if possible?
    Title: Pipeline Rules of Thumb Handbook - A Manual of Quick, Accurate Solutions to Everyday Pipeline Engineering Problems (6th Edition)
    Publisher: Elsevier
    Author/Editor: Edited by: McAllister, E.W.
    Mechanics & Mechanical Engineering
    Oil & Gas Engineering
    Many thanks and regards,
    Kaushlendra
  10. #67
    thank you
    Appreciate your kindness
  11. #68
    Dear Mohamed,
    Thanks a lot for your posting. Could you please send me some other link where I can download these files because these links are not opening with me?
    In case if possible please mail me on shuklak.25@gmail.com.
    Many thanks
    A Software Solution
    (240MB)
    Thanks & Regards
    Kaushlendra Shukla
  12. amazin tool thank you for you help !!!!
  13. ******** cannot apply. please inform exact procedure. at begenning of installation which option to select? complete install or license server?
    please help.
  14. Excellent work gentle man... In the same way i've been looking for a book "petroleum refining in nontechniccal language by william lefller". Could you please provide me the link for the same book or similar books... Thank you.....
  16. #72
    why need License(s) ?
  1. API Technical Data Book
    By panos in forum Petroleum Refining
    Last Post: 06-23-2024, 06:38 AM
  2. 6000 Technical Book Collection
    By budi666 in forum Oil And Gas Process
    Last Post: 11-15-2016, 02:26 PM
  3. EIREDA (European Industry Reliability Data Bank)
    By safer in forum Safety And Environment
    Last Post: 05-17-2014, 06:38 AM
  4. Replies: 4
    Last Post: 10-03-2013, 09:46 PM
  5. API - Petroleum Refining - Technical Data Book 6th Ed
    By jpl860iq in forum Petroleum Refining
    Last Post: 08-17-2013, 06:07 PM
