you must put google chrome auto translate function.
register and log in* later you can see the post and the links.
Hello Guys !
I'm a beggeiner in etap and I am doing a load flow study* but I am having a problem with the cables* every time I set the parameters and press 'OK' and reopen the cable editor all the parameters resetting to 0!!!
Please Help !!!
ETAP 17
You already have this himmelstern?
Do this really follow the relay's algorithm? or it is just a simple impedance calculation* just like the 87 feature* just a simple differential calculation - no magnitude and angle compensation.
No I followed etap at youtube; check the lastest webinars at youtube channel* that content is on it.
Hi. Anyone know if ETAP can draw the busbar of a U-shaped board so it is not so long?
You can use connector
Sent using Tapatalk
source
