Page 56 of 63 FirstFirst ... 6 46 54 55 56 57 58 ... LastLast
Results 661 to 672 of 751
Thread: Etap-16
  1. Re: Etap-16
    what's ZSTAR?
    Re: Etap-16
    distance protection module in ETAP 16
    no distance module in etap
  6. #664
    Re: Etap-16
    its on etap 17
  7. #665
    Oct 2009
    Dehli, Delhi, India, India
    Blog Entries
    1
    Re: Etap-16
    Dear Friends*
    Am facing an issue with DC Arc Flash* Voltage level is 1250 V DC. ETAP error Bus Voltage>1000V. Is it limitation of ETAP or something else in my settings. Please suggest.
  9. #666
    Oct 2009
    Blog Entries
    1
    Re: Etap-16
    Quote Originally Posted by raj151857 View Post
    Dear Friends*
  10. Re: Etap-16
    Is there a way to disable ETAP from checking license key once its opened? (Opened with proper key lincensed- then removed) After sometime it will check again that the key was remove and will close after 15 minutes. Would like to disable it from checking again. Thanks
  11. Re: Etap-16
    TRy using the windows fire wall to prevent outgoing connections from ETAP
  12. #669
    Quote Originally Posted by gh0stx View Post
    if you are using the key* the usb* it will check and thats their security feature. it prevents you from transferring or sharing the key.
  13. Re: Etap-16
    Quote Originally Posted by surgeArrester View Post
    But I can still use it after being removed for almost 30minutes. Is there no way to stop it from rechecking the key from time to time?
    I mean if the dongle was removed and etap notices it at once* then I'd think differently but thats not the case. I can still use it for a brief period* enough to do some work.
    So basically there is no way* is that the case? How bought prolonging the time it will close after it detects etao key is gone? Thanks
  14. #671
    Re: Etap-16
    If you don't use internet connection* wifi off and ethernet cable unppluged works??
    chinesse and their solutions
    1. [link Point to another website Only the registered members can access]
    2. [link Point to another website Only the registered members can access]
    3. [link Point to another website Only the registered members can access]
    4. [link Point to another website Only the registered members can access]
    5. [link Point to another website Only the registered members can access]
    6. [link Point to another website Only the registered members can access]
    7. [link Point to another website Only the registered members can access]
    Quote Originally Posted by jichangan View Post
    what's ZSTAR?
    Impedance protection on star module
  16. #672
    Yes there is not. If you using a usb key* original etap* there is no way unless you pirate it.
  1. Etap 14
    By gussww in forum Electrical & Power Engineering
    Last Post: 04-13-2016, 10:19 PM
  2. Etap 11
    By goldwincs in forum Electrical & Power Engineering
    Last Post: 03-01-2014, 12:29 PM
  3. eTap
    By saga1972 in forum Electrical & Power Engineering
    Last Post: 06-18-2013, 11:57 AM
  4. Need etap --------
