Long time to see you Shakespear
How are you?
Next month, I will go to Dynamic modeling so need some help from you.
Have a good time.
Bratek
How are you?
Have a good time.
Bratek
Has anyone got "Streamline Simulation: Theory and Practice by Datta-Gupta and Michael J. King"? thx
Learn from others regarding History Matching.
Good material here,
—Big Oil Executive
hi all,
I encounter some errors trying to rerun a simualtion in eclipse 2009 as below. The case was created in the 2005a version.
what is the cause of these errors and how do i resolve the problem? thanks for helping.
Info: Environment is NON-PVM LOCAL
Info: Eclrun option is now available with Office
Error: Executable c:\ecl\2005a\bin\pc\eclipse.exe read from the project file not found. The default executable will be used.Info: Current Grid File is H:\XEMII_StrimSim\XEMII_E100_INIT.GRID
Info: Exporting file XEMII_E100_INIT
Info: XEMII_E100_INIT Output File is Unformatted and Unified
Info: Run 1 : Simulation Waiting
Error: c:\ecl\2005a\bin\pc\eclipse.exe command not found, or the path is not correct
Info: Run failed
Info: Run 1 : Simulation Failed
Info: Case XEMII_E100_INIT finished.
Error: XEMII_E100_INIT.MSG not foundInfo: Simulations Finished. Timer Stopped
Info: Closing INIT module
reading it just like everyone else - seems to appear that your project is pointing to your old (and no longer available) 2005 Eclipse executable rather than your new 2009 executable. How are you launching the runs?
I opened the initial project in Eclipse (Office) 2009, included another region of the reservoir for simulation by resetting ACTNUM, saved the progect to a new directory and ran an initialization with NOSIM which resulted in the errors above.
shakespare; I need the pass of archives Please. many thanks
Not sure I understand what you want.
—Big Oil Executive
Please, There are some Heriott_Watt files which need pass for extract. Please let me know. Sincerely yours. Dr rafik
Sorry but I don't have any files with passwords![]()
—Big Oil Executive
I simply looks like you are launching against the wrong version of the Eclipse run-time.... When you are about to launch, check which version it is referencing, and try a different one
